Page 2 of 48 1 2 3 4 47 48
Re: Modern Bullitt build [Re: Keepat] #1614701
06/30/14 04:59 PM
06/30/14 04:59 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I skinned the charger and found a little rust around the back window but the front window channel looks great!
I also pulled the motor and Trans, as I sold it. With the motor in the car and still running I put it on Craigslist with a video and the 2nd called bought it! The 1st called was pissed.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614702
06/30/14 11:20 PM
06/30/14 11:20 PM
MO
cdp Offline
cdp  Offline
MO
who are you sending your vent window parts off to for rechroming?
Re: Modern Bullitt build [Re: cdp] #1614703
07/01/14 12:10 AM
07/01/14 12:10 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
The past three cars I used Paul's Chrome And this will be the 4th car! Not cheap but I'm not sure you'll find better chrome work and pot metal repair work anywhere else.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614704
07/13/14 09:13 PM
07/13/14 09:13 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Went to Chrysler Carlisle and picked up a AMD trunk floor and US Car Tool chassis stiffening kit and mini tub kit and a few other things. It was hot but a great day!
Re: Modern Bullitt build [Re: Keepat] #1614705
07/13/14 10:10 PM
07/13/14 10:10 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Removed the glue and green paint from the fuel fill pipe and sanded the lead coating with 400- 600 and 800 then clear coated it. Note use a respirator and glove when sanding lead.
Re: Modern Bullitt build [Re: Keepat] #1614706
07/21/14 01:09 AM
07/21/14 01:09 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
With the car still on all 4 I started fitting the US car tool frame connectors and after a little grinding they fit pretty well.
I also started on the only part of the frame that was rusted. The right side of the cross member needed a small section cut out and replaced so I found a donor frame rail to graft in the frame.
I will weld up after I finish cleaning the undercoat off.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614707
07/21/14 10:17 PM
07/21/14 10:17 PM
Looks good.
You're moving right along.
Re: Modern Bullitt build [Re: Keepat] #1614708
07/22/14 09:16 AM
07/22/14 09:16 AM
STL
cdstl Offline
cdstl  Offline
STL
I have been trying to restore the parts as I remove them instead of at the end of the project. The left side vent box is the last item I did and it cleaned up nicely. Here are a few before and after pictures.
Thanks!
Pat
Where did you get the rivets for the vent box? I am thinking about tinning and leading the galvanized parts on a heater box. Is that what you did with these pieces?
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: Modern Bullitt build [Re: cdstl] #1614709
07/26/14 05:33 PM
07/26/14 05:33 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thanks!
Pat
I didn't remove the rivets just cleaned and cleared the parts
Pat
Re: Modern Bullitt build [Re: Keepat] #1614710
07/26/14 05:34 PM
07/26/14 05:34 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Evod said the wheel should ship late next week and sent a picture of one of the center sections.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614711
07/27/14 12:52 AM
07/27/14 12:52 AM
MO
cdp Offline
cdp  Offline
MO
sweet! Would love to see the same thing done with the 1970 dodge full wheel cover.
Re: Modern Bullitt build [Re: cdp] #1614712
07/27/14 11:55 PM
07/27/14 11:55 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I installed the US Car Tool core support today and fit great with just a little grinding. I order it without the holes as I like the original look. Next to the subframe connectors and torque boxes it is one the best stiffener you can add to a Mopar! I ground down and radiuses the weld so it would look original. You could jack the car up from the core support now!
Pat
Re: Modern Bullitt build [Re: Keepat] #1614713
07/28/14 08:09 PM
07/28/14 08:09 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I received another picture of my wheels today. This one with the complete center cap.
Thanks!
pat
Re: Modern Bullitt build [Re: Keepat] #1614714
07/29/14 02:51 PM
07/29/14 02:51 PM
MO
cdp Offline
cdp  Offline
MO
Hmmm.... wouldn't it be nice if Ma-Mopar (Fiat) made available the new 707 HP supercharged Hemi as a crate motor with wiring/electronics for resto mods?
That would be a Bullitt for sure!
Re: Modern Bullitt build [Re: Keepat] #1614715
07/31/14 10:52 AM
07/31/14 10:52 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I received a few more pictures of my front wheels. The red and black paint in the center cap should make them pop!
Thanks!
Pat
Re: Modern Bullitt build [Re: Keepat] #1614716
08/09/14 12:15 PM
08/09/14 12:15 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Received the wheels Friday and they exceeded my expectations. I will paint the red and black details in the center cap soon and hope to get the tires mounted next week.
Pat
Re: Modern Bullitt build [Re: Keepat] #1614717
08/09/14 02:27 PM
08/09/14 02:27 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
So, are those centers going to be reproduced? I bet that will be another way to get the haters against big wheels to join the dark side. The Year One Rallye and Magnum wheels worked a little, but these things just look awesome.
Re: Modern Bullitt build [Re: MuuMuu101] #1614718
08/10/14 05:48 PM
08/10/14 05:48 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
As it was a Dodge only hub cap for just a few years I'm not sure there will be enough demand for this wheel on the market to justify putting it in production. Selfishly I hope not ;-)
Pat
Re: Modern Bullitt build [Re: Keepat] #1614719
08/19/14 09:55 AM
08/19/14 09:55 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Received some of the parts I sent to Paul’s Chrome here are a few before and after pictures
Pat
Re: Modern Bullitt build [Re: Keepat] #1614720
08/19/14 08:32 PM
08/19/14 08:32 PM
SoCal
MuuMuu101 Offline
MuuMuu101  Offline
SoCal
Pat
Remove the Dodge logo off the center and you won't have a Dodge only wheel but a good looking, aftermarket 5-spoke wheel.
