Page 3 of 31 < 1 2 3 4 5 30 31 >
#1614721 - 08/21/14 08:46 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Im still working on the colors but I think it is close to the original hub cap colors. I also ordered the motor today, an aluminum gen III 6.1 Hemi stroked to 426 ci and about 650 hp
Pat
#1614722 - 08/22/14 09:14 AM Re: Modern Bullitt build [Re: Keepat]
6PKRTSE Offline
Loc: Motor City
Those wheels are awesome even though I am not a fan of large dia wheels on musclecars. One of my dream cars is to also have a Bullit Clone 68 Charger someday. I'll bet those were not cheap.... Awesome decision to have them made.
1970 Charger R/T S.E. 440 Six Pack
1970 CHALLENGER R/T, 25.5 Cert, Big Inch Alum 16 plug HEMI twin turbo.
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner.
1996 2500 RAM 488 V-10 4X4.
2012 Challenger R/T Classic.
#1614723 - 08/29/14 09:22 PM Re: Modern Bullitt build [Re: 6PKRTSE]
Keepat Offline
Loc: Maryland
I finished the rust repair on the right side quarter panel, it required 3 small patch panels and a little fender well repair. The trunk floor extensions have some pits but require no repair just a coat of POR 15.
Pat
#1614724 - 08/29/14 09:42 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
I also had the tires mounted on the new wheels but I have yet to cut in the mini tub so I had to put the front wheels on the rear for pictures as the 12 wheel with the 335 tire dont fit the car yet.
Pat
#1614725 - 08/31/14 01:52 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
I plan on testing a 3/16 black line on the outer rim as it is on the original hub cap. Im having 17 7/8x 3/16 vinyl ring made to check the look.
#1614726 - 09/02/14 08:49 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
I installed a vinyl black ring on one of the wheels to match the black line on the hub caps and I like the look. Hard to see the black line in the pictures but I think it finishes the look of the wheel.
Pat
#1614727 - 09/13/14 06:21 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Received my dash and door pads from Just Dashes and they look great. This is the 2nd Charger dash and door pads they have done for me just wish they could replicate the stiching :-( here are a few before and after pictures
Pat
#1614728 - 09/19/14 10:06 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Finished the rear valance and left rear quarter rust repair. One more rust spot on the front side of the left quarter to do then on to the trunk floor.
#1614729 - 09/23/14 08:34 PM Re: Modern Bullitt build [Re: Keepat]
Dan Halen Offline
Loc: Harm City Md.
I've seen your old silver car,
This one will be even better!
#1614730 - 09/24/14 05:56 PM Re: Modern Bullitt build [Re: Dan Halen]
Keepat Offline
Loc: Maryland
The silver Charger was a fun car to build that why I'm doing another one! Did you see the silver charger in person?
Thanks!
Pat
[IMG]http://i264.photobucket.com/albums/ii196/keepat/carstuff001.jpg~original[/IMG]
Edited by Keepat (09/24/14 05:59 PM)
#1614731 - 10/20/14 04:34 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Received a few pictures of the motor Indy is building for the charger. As soon as the 2nd FAST throttle body shows up I will drive out for the Dyno and bring it home.
Pat
#1614732 - 10/20/14 09:59 PM Re: Modern Bullitt build [Re: Keepat]
Superfreak Offline
Loc: the great wet north
That looks pretty.
"Too much to do and not enough time to do it"
#1614733 - 10/20/14 10:09 PM Re: Modern Bullitt build [Re: Keepat]
MuuMuu101 Offline
I got lucky at Woodward!
Loc: SoCal
OoooOoooooOoo... Shiny.
68 Dart GT Project Thread: Linky!
#1614734 - 10/22/14 10:23 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
I de-torsion bar the charger, as Im going to use RMS coil over front suspension.
Pat
#1614735 - 10/28/14 09:09 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Added a cross member just forward of the leaf spring mounts. Used a 2 x 1 C channel cut and welded to fit in the floor tunnel under the rear seat. This should add additional rigidity to the chassis without impeding the driveshaft. Torque boxes are next.
Pat
#1614736 - 10/28/14 11:55 PM Re: Modern Bullitt build [Re: Keepat]
Superfreak Offline
Nice work.
#1614737 - 11/07/14 08:50 AM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Drove to Reilly Motorsports yesterday to pick up the front and rear suspension for the charger. Bill Reilly is a great guy and he had everything ready for pickup! Also stopped in Hazleton PA for the best chili dogs at Jimmys! I will post a few more picture of the RMS part when I get them out of the boxes.
Pat
#1614738 - 11/09/14 02:06 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Assembled the shocks using anti-seize and chased the threads on the upper control arms. Nice working on clean new stuff instead of old rusty stuff.
Pat
#1614739 - 11/12/14 10:24 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
I assemble the new front wheel hubs, hats and the rotors. I used the same Wilwood 13 6 piston brakes on my last 68 Chargers and they worked great!
Pat
#1614740 - 11/13/14 09:47 PM Re: Modern Bullitt build [Re: Keepat]
ihv800 Offline
Loc: CO
Build looks awesome. What is your procedure for metal finishing your welds down on the patch work? It looks fantastic!
25,742 Registered Members
192,975 Topics
USA source for German made tools
by 360view
02/20/19 03:42 PM
I like trains
by bigdad
02/20/19 03:17 PM
Fiddy Three Dodge w/ Hemi
by Neil
02/20/19 03:02 PM
(2) 66 Chargers
by Neil
02/20/19 03:01 PM
