Page 2 of 31 < 1 2 3 4 30 31 >
#1614701 - 06/30/14 02:59 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
I skinned the charger and found a little rust around the back window but the front window channel looks great!
I also pulled the motor and Trans, as I sold it. With the motor in the car and still running I put it on Craigslist with a video and the 2nd called bought it! The 1st called was pissed.
Pat
#1614702 - 06/30/14 09:20 PM Re: Modern Bullitt build [Re: Keepat]
cdp Offline
Loc: MO
who are you sending your vent window parts off to for rechroming?
#1614703 - 06/30/14 10:10 PM Re: Modern Bullitt build [Re: cdp]
Keepat Offline
Loc: Maryland
The past three cars I used Paul's Chrome And this will be the 4th car! Not cheap but I'm not sure you'll find better chrome work and pot metal repair work anywhere else.
Pat
#1614704 - 07/13/14 07:13 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Went to Chrysler Carlisle and picked up a AMD trunk floor and US Car Tool chassis stiffening kit and mini tub kit and a few other things. It was hot but a great day!
#1614705 - 07/13/14 08:10 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Removed the glue and green paint from the fuel fill pipe and sanded the lead coating with 400- 600 and 800 then clear coated it. Note use a respirator and glove when sanding lead.
#1614706 - 07/20/14 11:09 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
With the car still on all 4 I started fitting the US car tool frame connectors and after a little grinding they fit pretty well.
I also started on the only part of the frame that was rusted. The right side of the cross member needed a small section cut out and replaced so I found a donor frame rail to graft in the frame.
I will weld up after I finish cleaning the undercoat off.
Pat
#1614707 - 07/21/14 08:17 PM Re: Modern Bullitt build [Re: Keepat]
Superfreak Offline
Loc: the great wet north
Looks good.
You're moving right along.
"Too much to do and not enough time to do it"
#1614708 - 07/22/14 07:16 AM Re: Modern Bullitt build [Re: Keepat]
cdstl Offline
Loc: STL
I have been trying to restore the parts as I remove them instead of at the end of the project. The left side vent box is the last item I did and it cleaned up nicely. Here are a few before and after pictures.
Thanks!
Pat
Where did you get the rivets for the vent box? I am thinking about tinning and leading the galvanized parts on a heater box. Is that what you did with these pieces?
1972 Cuda 340 auto, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 2001 Ram 5.2 4x4 auto, 1996 Ram 5.9 2x4 auto
#1614709 - 07/26/14 03:33 PM Re: Modern Bullitt build [Re: cdstl]
Keepat Offline
Loc: Maryland
Thanks!
Pat
I didn't remove the rivets just cleaned and cleared the parts
Pat
#1614710 - 07/26/14 03:34 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Evod said the wheel should ship late next week and sent a picture of one of the center sections.
Pat
#1614711 - 07/26/14 10:52 PM Re: Modern Bullitt build [Re: Keepat]
cdp Offline
Loc: MO
sweet! Would love to see the same thing done with the 1970 dodge full wheel cover.
#1614712 - 07/27/14 09:55 PM Re: Modern Bullitt build [Re: cdp]
Keepat Offline
Loc: Maryland
I installed the US Car Tool core support today and fit great with just a little grinding. I order it without the holes as I like the original look. Next to the subframe connectors and torque boxes it is one the best stiffener you can add to a Mopar! I ground down and radiuses the weld so it would look original. You could jack the car up from the core support now!
Pat
#1614713 - 07/28/14 06:09 PM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
I received another picture of my wheels today. This one with the complete center cap.
Thanks!
pat
#1614714 - 07/29/14 12:51 PM Re: Modern Bullitt build [Re: Keepat]
cdp Offline
Loc: MO
Hmmm.... wouldn't it be nice if Ma-Mopar (Fiat) made available the new 707 HP supercharged Hemi as a crate motor with wiring/electronics for resto mods?
That would be a Bullitt for sure!
#1614715 - 07/31/14 08:52 AM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
I received a few more pictures of my front wheels. The red and black paint in the center cap should make them pop!
Thanks!
Pat
#1614716 - 08/09/14 10:15 AM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Received the wheels Friday and they exceeded my expectations. I will paint the red and black details in the center cap soon and hope to get the tires mounted next week.
Pat
#1614717 - 08/09/14 12:27 PM Re: Modern Bullitt build [Re: Keepat]
MuuMuu101 Offline
I got lucky at Woodward!
Loc: SoCal
So, are those centers going to be reproduced? I bet that will be another way to get the haters against big wheels to join the dark side. The Year One Rallye and Magnum wheels worked a little, but these things just look awesome.
68 Dart GT Project Thread: Linky!
#1614718 - 08/10/14 03:48 PM Re: Modern Bullitt build [Re: MuuMuu101]
Keepat Offline
Loc: Maryland
As it was a Dodge only hub cap for just a few years I'm not sure there will be enough demand for this wheel on the market to justify putting it in production. Selfishly I hope not ;-)
Pat
#1614719 - 08/19/14 07:55 AM Re: Modern Bullitt build [Re: Keepat]
Keepat Offline
Loc: Maryland
Received some of the parts I sent to Paulís Chrome here are a few before and after pictures
Pat
#1614720 - 08/19/14 06:32 PM Re: Modern Bullitt build [Re: Keepat]
MuuMuu101 Offline
Loc: SoCal
Pat
Remove the Dodge logo off the center and you won't have a Dodge only wheel but a good looking, aftermarket 5-spoke wheel.
25,696 Registered Members
196,730 Topics
Are cassettes making a comeback?
by DUFFMAN
Yesterday at 10:34 PM
Indoor (home) emergency heating, kerosene, propane, other??
by A12
Yesterday at 10:31 PM
Basic ignition question, using MSD-6AL and MSD-8680 boxes
by Fab64
Yesterday at 10:29 PM
318 head flow
by skrews
Yesterday at 09:35 PM
