Ignition issues #1610732
04/22/14 08:17 PM
04/22/14 08:17 PM
SoCal
Groucho5 Offline OP
Groucho5  Offline OP
SoCal
69 Roadrunner's got a very narrow band of timing. The timing mark's slipped so I timed it by ear. I've done this thousands of times. 2 of my cars run fine that I've set by ear 6 yrs ago and 10 yrs ago, so PLEASE trust i know what I'm doing and please help me go forward not sideways. I thank you in advance for this. Anyway, time by ear, sounds/runs great but cranks extremely hard when up to operating temp. This with a stout battery and good aftermarket mini starter. If I retard slightly (I'm sure no more than 10 degrees) in runs like crap and backfires thru the carb. I had slight fuel issuse at the same time so i remove th AFB and....... I put the 750HP Holley off my Vette on this thing. It idles better, revs smoother. Still has the very narrow span from too retarded to too advanced. Difference is, while in the good running yet too advanced to crank while up to temp setting, it'll still crank way too slow, but merely for a split second because it lights instantly with this carb each time so far. Thoughts?
Re: Ignition issues [Re: Groucho5] #1610733
04/22/14 08:40 PM
04/22/14 08:40 PM
Happy Birthday RapidRobert  Offline
Thoughts?
OK I will respect your wishes & no comments on the timing by ear. What worked for us on the stock car was to wire the ign hot input to the ECU (blu with yellow tracer) to an on/off toggle switch & get the starter cranking THEN switch on the ign. Unrelated to the cranking you might check/confirm rotor phasing/reluctor gap as there is another issue going on (or 2)
Re: Ignition issues [Re: RapidRobert] #1610734
04/22/14 09:04 PM
04/22/14 09:04 PM
SW CO
HemiSportFury Online content
HemiSportFury  Online Content
SW CO
How about your starter? Does it turn over good with the coil wire pulled when hot? That will confirm it's ignition related or not.
'64 Sport Fury, 528 Hemi, FiTech EFI, 4-speed, 4.10 Dana 60
'57 Belvedere 2dr sedan, current project in process
'19 Cherokee Trail Hawk Elite
'03 Ram 2500 CTD HO, 6-speed 214,000 miles and still going strong
