cheap 318 build.. need some pointer's
#1606653
04/13/14 04:41 AM
04/13/14 04:41 AM
Posts: 256 libby mt
lifted85
libby mt
hey guy's, well last year i drove the d150 with the mostly stock 318 beside's the normal bolt on's ( long tube header's, performer intake, 600cfm carb) i want a little more giddy up & go. so im getting a comps XE256H cam (thanks to a member here) I dont want to yank the motor & do a complete rebuild but what else could be done to get a little more power?? i am swapping to 355 gear's which should help.. i am kickin around replacing the head's with a set from areoracing, i dont want to go throuw the hasle of the magnum head swap, i do got a pair of 89-90 tbi head's but last time i checked it was well over $500 to get them rebuilt.. any info would be great guy's
drive fast, drive hard, DRIVE MOPAR
Re: cheap 318 build.. need some pointer's
[Re: Kern Dog]
#1606655
04/13/14 07:07 AM
04/13/14 07:07 AM
Posts: 256 libby mt
lifted85
libby mt
truck is a 81 d150 2wd... i hate 360's so thats why opted for a 318.. truck has duel 2.5" exhaust along with long tube header's... i got a set of 308/302 head's but like i said the shop wanted well over $500 to just rebuild um.. the onse from areo heads are 1.88-1.60 IIRC
[Re: lifted85]
#1606656
04/13/14 07:47 AM
04/13/14 07:47 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Around here Magnum 5.2's are cheap, picked up my last one for $150
Consider swapping one in with a carb intake.
"I think its got a hemi"
[Re: lifted85]
#1606657
04/13/14 11:50 AM
04/13/14 11:50 AM
RapidRobert
I would reconsider the mags. JY ones are cheap & you'd just need a mag compatible intake & possibly different pushrods. If you're dead set against them then the 302's with some home porting. You desperately need compression which the closed chambered mags/ 302's would provide. A cam from Hughes and alot of time tweaking the dist subsytems in order: initial/total to 35 (31 if mags)/springs/vac adv. May I ask why you dislike 360's? as you desperately need torque (more cubes) for your app.
[Re: RapidRobert]
#1606658
04/13/14 12:13 PM
04/13/14 12:13 PM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I would like to know why you would pass on the 360 too? Big mistake in my opinion.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
[Re: Copper Dart]
#1606659
04/13/14 06:46 PM
04/13/14 06:46 PM
Posts: 256 libby mt
lifted85
libby mt
spent a fortune a 360 i had built & it was a dog. every 318 i have owned has been good.. like i said i got my mind set on the comp XE256H dont want to go through spending a fortune on a new intake, push rod's, lifters with the mag head swap.. looks like i will pick up a set of areo & do a little porting & call it good....
[Re: lifted85]
#1606660
04/13/14 08:57 PM
04/13/14 08:57 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
You do know that the 302 and 308 are totally differnt castings, right? The 360 was a dog? If you build a 318 and a 360 with identical specs, the 42 extra cubic inches will always win.
[Re: Kern Dog]
#1606661
04/14/14 01:18 AM
04/14/14 01:18 AM
Posts: 256 libby mt
lifted85
libby mt
ya i know they are differnt lol... not a fan of 360s just me... would the #308s be worth rebuilding compared to the areo heads?
[Re: lifted85]
#1606662
04/14/14 01:29 AM
04/14/14 01:29 AM
RapidRobert
Aero heads are Indy's garden variety rebuilt heads & been a few bad reports on them tho probably not any more than anyone else (we're in the business of solving problems here on Moparts) so we get way more bad reports than good but they are open chambered. I would strongly consider finding some 302's (closed chambers) & open em up a bit. FYI 308's are the best of all the iron open chambered heads
[Re: RapidRobert]
#1606663
04/14/14 02:48 AM
04/14/14 02:48 AM
Posts: 256 libby mt
lifted85
libby mt
i will have to double check but im sure the head's i pulled of my 89-90 w150 318 was 308's.. might have to run to the next town & see what they will charge to rebuild um... whats the normal rate you buy's pay to get them rebuild
[Re: Kern Dog]
#1606665
04/14/14 10:25 AM
04/14/14 10:25 AM
Posts: 15,487 Florida
scratchnfotraction
Switching from 302s to 308s is a tradeoff. The 308s flow better but they also have larger chambers resulting in a 1/2 point loss in compression.
#308 is a 89-91 360 swirl port/open chamber head and is the best head since the X heads back in the day. they redid the exhaust port to flow more. they only came on a 360 TBI engine.
BUT>>in a JY they are few and pron to cracks same as the mag heads.
I agree with you Zack, 360 are not everyones cup of tea. if you do not build the rest of the truck with the parts to make the 360 work it is always a dog no matter what it is in.
the over the counter LA & mag heads are only 75$ more than my local machine shop can do them for..so for 75$ more I get NEW head castings complete ready to install.
hard to beat next day also. most all of mine are a 600$ rebuilt short block with a 600$ set of heads.
comes out to about the same as a long block over the counter..
300$ 91-318 JY engine with a 400$ roller cam is what I am reving now. runs killer in my 85 stepside 2x truck for 700$
[Re: gdonovan]
#1606667
04/14/14 12:41 PM
04/14/14 12:41 PM
scratchnfotraction
I had already suggested just dropping a magnum 5.2 in, they can be had for dirt cheap, carb intakes are easy to lay hands on and used roller cams are anything from $50-$150 and don't wear out.
Better heads, better cam setup, lower friction rings, win-win all the way around.
I have only had 2 brand new engines at 3500 each...over rated and where nothing but hassle to deal with... granted race engines do not like daily driver duty..
so been doing cheap JY freshin ups and run them as hard as they will go till they give up for daily drivers.
dirt cheap and roller cams are investments for the long run.
[Re: scratchnfotraction]
#1606668
04/14/14 01:01 PM
04/14/14 01:01 PM
dogdays
No 318 ever came with 308 heads, unless it was a factory mistake. If you have heads off a late model 318, they are 302s, or there was another head with different casting number but same heart-shaped combustion chambers.
The 302s I'm running right now are from a 120,000 mile Fifth Avenue and they were not "rebuilt". Guides were still in tolerance and the seats looked good. I did cut down the valveguides so I could run a bigger cam later, and added new valve stem seals and Crane 308 springs which will be okay if I ever get the roller 318 cam reground. Then I did a whole bunch of home porting. I installed them with Mr Gasket thin head gaskets. I'm still working out the carburetion, but on its first long trip it returned something over 21 mpg. If you are absolutely bucks-down, find that late-model Fifth Avenue and pirate the heads, or the whole engine if you can. My shortblock had no ridge and the crosshatch still visible in the cylinders. Bearings were OK, too.
R.
[Re: dvw]
#1606671
04/14/14 10:39 PM
04/14/14 10:39 PM
Posts: 256 libby mt
lifted85
libby mt
well after dropin ina couple thousand it was a dog.. thats just me... the head's are stamped 714 so iirc they are fast burn head's.. are the 714's any good??
[Re: dvw]
#1606673
04/14/14 11:36 PM
04/14/14 11:36 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I took a bone stock 5.9. Added a whiplash cam, intake, headers and a computer tune. Chassis Dyno numbers indicated 360-375 crank HP. ET was 14.2 @ 99 mph with 2.2-2.3 60' times. In a 4,000lb truck
**Photobucket sucks**
[Re: lifted85]
#1606674
04/15/14 12:09 AM
04/15/14 12:09 AM
Posts: 277 Cincinnati, Ohio
chargincharles
Cincinnati, Ohio
Well, for what it's worth: I went through this a couple of years ago for the 318 in my 5th... Basically, the cost of rebuilding a set of 302's (not easy to find these days) and a set of Magnum heads (easy to find) was about the same here in Cincy. So, Upullandpay for the heads ($100) plus porting it with a set of MP templates that a friend of mine had ($0, just my hours of work) plus a used Crosswind intake ($50 at swap meet). Already had a new set of AMC lifters (same cost as factory lifters- got them from Autozone years ago)...and all I needed was the thin Mr Gasket head gaskets and the MP pushrods- MP 5007477, 7.625" pushrods. This is a sticking point as they are no longer available from MP, so you'll have to dig for them. Added a AVS that I had been using for another (now sold and gone) car. I went with a mild Jeg's cam that is an RV Cam: http://www.jegs.com/i/JEGS+Performance+Products/555/200160/10002/-1The advantage is the Magnum lifters are 1.6 ratio, not 1.5 like the factory heads. So a 'mild' cam can benefit with the larger ratio of lift. Car runs like a champ- added a set of used headers and a 2 1/2 dual exhaust and it pulls like a freight train. Not easy on a big, heavy luxobarge like the 5th. It really needs a higher stall converter, but I'm build a 408 now, so that will wait until the new motor is ready to drop in. Everything you need to know to swap the Magnums- http://www.dippy.org/forum2/index.php?topic=295.0No more complicated than a regular head swap. Might as well get a higher lift and more compression for the same amount of hassle..or at least that was my thinking... Hope this helps, CC.
[Re: dvw]
#1606675
04/15/14 06:58 AM
04/15/14 06:58 AM
Posts: 256 libby mt
lifted85
libby mt
the 360 i built a while back was a 81 360, torker intake, ported, shaved head's ect ect, gear's were 355's-410's 727 auto.. was a dog, not getting into a pissin match just need some help, like i said i do not want to swap to magnum head's.. i want to 2 if the 714 head's are any good & worth rebuilding
[Re: lifted85]
#1606676
04/15/14 07:13 AM
04/15/14 07:13 AM
70Cuda383
Marysville, O-H-I-O
If you've already made up your mind on replacing your heads with rebuilt heads by Aero, and have closed off the idea of anything else, then why do you keep asking us for ways to pep up the power under the hood for cheap?
[Re: 65rbdodge]
#1606679
04/15/14 03:22 PM
04/15/14 03:22 PM
Posts: 1,822 Colorado
denfireguy
Colorado
a $50-$100 magnum intake for a carb where can they be found? how do we get the fuel to the carb on the cheap with a magnum on this truck? these "little" things add up. the thread says "cheap 318 build" and as per moparts protocol we have the usual build a 360 or go magnum suggestions, soon it will be build hemi. we have ventured way off course here.
lifted85 if you want to swap heads, pull a set of 302 heads from an 85 up to 91 (premagnum) 318 car/truck/van in a junk yard. get a valve lapping tool(suction cup, very cheap), some valve lapping compound(also cheap) and lap the valves. there are videos on how to do this on youtube. its easy. put some 901 springs on using the stock retainers/keepers. call it done. another cheap upgrade, replace the heavy advance spring in the distributer with a light one(think ball point pen thickness) take the heavy spring to a hardware store and match up the length(cost is probably less than a dollar)
Any 318/340/360 four barrel intake will work if the Magnum mounting holes are redrilled and tapped to accept the manifold. I am running a 5.2L magnum I picked up for 50 bucks. On top of it is a Edelbrock 340 intake I paid $100 from a fellow Mopar guy. On it is an Edelbrock 1406 I paid $75 for on Ebay (New in box). $60 Holley electric fuel pump but you can put an eccentric on the front of the magnum to run a mechanical on an LA timing cover. I am running Engine Quest Magnum heads that were ordered with the LA holes tapped into it so I skipped that step but there are many threads on here on how to tap them yourself. Another 125 for a Beauchillon Engineering throttle cable and plate for the torqueflite and gas pedal and that was it. I believe I have less in it than the OP has already spent. The only high ticket item was for the heads. I had already ordered them for the my original 318 but when the magnum engine popped up, I changed direction in a New York minute. Advantages: roller cam so no zinc in oil worries, higher compression ratio (62cc magnum chambers), better breathing in and out, looks just like a 318 and it has more horsepower than the 318 it replaced. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: denfireguy]
#1606681
04/15/14 04:56 PM
04/15/14 04:56 PM
dogdays
If the 714s have a heart shaped combustion chamber, they are like the 302s. That number sounds vaguely familiar. Later: I did a little websearching and it seems they are brothers to the 302 head. Heart-shaped chambers, use a rocker shaft, 1.78/1.50 valves. No need to use 302s when the 714s are the same head.
And no, they are NOT Magnum heads, at least the type of Magnum that has rockers on studs.
R.
[Re: dogdays]
#1606682
04/15/14 05:45 PM
04/15/14 05:45 PM
scratchnfotraction
correct 714 casting replaced the 302 casting or vis-versa same swirlport fastburn closed comb chamber small port small valve 318 head. dith the exhaust valve rotators for more guide to retainer clearance with a higher than stock lift cam lobe.
[Re: 65rbdodge]
#1606685
04/15/14 06:21 PM
04/15/14 06:21 PM
gdonovan
Oakdale CT
As do used heads, headgasket sets, new pushrods, AMC lifters, etc.
I can get a complete magnum engine for less than a set of heads and gasket set.
Here is one I did not even try hard to find-
http://newhaven.craigslist.org/pts/4417893722.html
"I have a v8 5.2 318 dodge ram motor it runs great no leaks around 120,xxx miles fits 94-01 includes alternator, belt tensioner pulley, a.c compressor, power steering pump, water pump, fan, upper radiator hose, wiring harness, ignition coil, exhaust manifold, cruise controll everything works no problems $300 call"
or a 5.9 for $600 from a yard (there are better prices on these, this one found at random.
http://southcoast.craigslist.org/pts/4423034174.html
"5.9 engine taken out of a 97 dodge ram. has 72,000 miles. engine is complete and ran excellent"
[Re: gdonovan]
#1606686
04/15/14 10:32 PM
04/15/14 10:32 PM
scratchnfotraction
Good old fashioned cheap build A set of 1.88 intake heads off a 360
Drops the compression too much, been there and done it.
me too, but the right cam makes up for the low comp ratio
like the whiplash roller cam I stuck in my 91 318, it has short duration/high lift/early intake closing/tight LSA to build cyl pressure and not bleed off torque.
then add a loose TC and some gear the lopo 318 will get with the program.
but it is at a street engine level not a racing engine level of performance.
performance above street level is more $$$ and not so cheap.
#1606688
04/15/14 10:49 PM
04/15/14 10:49 PM
Posts: 9,815 MI, usa
dvw
MI, usa
My last gas truck was a 82 dodge 1/2 ton ,3.91 gear. I swapped in a bone stock 360 magnum. Removed the injection and ran a M-1 dual plane w/600 Holley. With a full fiberglass rear cap it ran 14.80@94.Doug
[Re: 65rbdodge]
#1606690
04/16/14 12:31 AM
04/16/14 12:31 AM
Posts: 256 libby mt
lifted85
libby mt
thanks 65rbdodge hit it right on, sound's like what i will do. to the other member's i was lookin for a cheap upgrade, the magnum head swap aint cheap, the little thing's add up pretty fast, & why would i pulled a motor that run's good for a magnum?? i just want a little more pep. like i said i wanted some cheap idea's.. & as for the 360, sorry IM NOT A FAN!!! just like some folk's aint a fan of the 318's..
[Re: 65rbdodge]
#1606691
04/16/14 01:36 AM
04/16/14 01:36 AM
Posts: 3,009 Covington Georgia
RV2
Covington Georgia
What are 901 springs? Can you elaborate Thanks
[Re: gdonovan]
#1606694
04/16/14 09:32 AM
04/16/14 09:32 AM
chargincharles
Cincinnati, Ohio
A used mag motor complete can be had less than your conversion.
I don't understand the interest in mag heads and not going all the way and running the mag motor. In the long run you will be better off with the mag motor as the cam will never go flat and you can take advantage of better profiles.
I agreed- you can pick one up for less than my conversion... But at the time I had no garage or equipment to get a used mag engine from the junkyard to my home, and then pull the 318 out of the 5th to drop it in. I could however swap heads without having to do any of that. The added plus- I wanted to see what all the fuss was about, if the magnum heads were really that good. Turns out they are.
To answer a question someone else asked- I got a smokin' deal on the Crosswind because everyone at the time was saying they were basically junk, so the guy I got it from sold it for $50 to get rid of it. Brand new, still in the box. Turns out they were wrong. One caveat and to be honest I did give him a factory iron 4-bbl intake off of a mid-70's 360 truck along with the $50. But hey cost is cost. The iron 360 intake was free to me- another friend of mine went Airgap and this was the factory intake. He just wanted it out of his garage along with some other 'useless' items. This is all horse trading fellas- if you can't wheel and deal you aren't going to build anything cheap. Might as well get out the gold card and call Summit.
OP, good luck with the build.
Enjoy! CC.
[Re: RV2]
#1606695
04/16/14 12:14 PM
04/16/14 12:14 PM
scratchnfotraction
comp901-16 springs = single spring/damper are drop on spring with no machine work, uses stock seals/retainers and coves most stock/mild SB cams.
I have used them on 4 Lunati flat tappet VooDoo cams and 1 lunati 60710 roller cam, I just used another set with the Hughes whiplash roller cam, which is almost exact specs as the lunati voodoo roller cam.
nice bang for the buck for SB spring at 80$ a set
