Re: Im trying to get this! But what does that extra cab
[Re: RUMBLON]
#1603662
04/05/14 10:59 PM
04/05/14 10:59 PM
moparpollack
Lil Herman
Lil Herman
85086
The one ton fenders have huge wheel opening. Make sure the doors open and close good as parts for then are a pain to replace. Check you phone I just texted you a picture of my pick up.
[Re: moparpollack]
#1603663
04/05/14 11:16 PM
04/05/14 11:16 PM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
John, I didnt even realize that the one tons were different fenders, doors,ect? This will require a door for the drivers side. I was kinda hoping that that other cab was a Dodge and that it would fit. I was not there long and was not able to crawl through everything to check things out. I hoping its a 100-$200 purchase. At that price I can hang on to it and collect and search. Im starting to get a bit settled here and this summer hope to search around.
[Re: RUMBLON]
#1603665
04/06/14 01:57 AM
04/06/14 01:57 AM
Posts: 7,992 Escondido, CA. Ron Podsiadly,...
Mopar Ron
Dave the cab and doors are pretty much the same, the fenders are about 1-1 1/2" wider than the PU trucks and the wheelwells have a larger opening but you can re do them to make them smaller., In the next few months I am going to do just that, I have a nice cab and plan to use a 93 Dakota chassis and the big truck fenders that I have Ron...
[Re: Mopar Ron]
#1603666
04/06/14 02:25 AM
04/06/14 02:25 AM
RUMBLON
Cambridge Idaho
Ron, why cant you used then as is?
DAVE
[Re: RUMBLON]
#1603667
04/06/14 11:21 AM
04/06/14 11:21 AM
Posts: 10,525 Freeport IL USA
poorboy
Freeport IL USA
Pickup trucks have 15" wheels and tires. 1 ton and larger trucks have 20" tires and wheels that have a different offset (think dually wheels compared to single wheels) then the pickup wheels. The rear portion of the big truck fenders are also longer then the rear portion of the pickup fenders. Big trucks sit higher off the ground and the running boards attach to the bottom edge of the fenders. The fenders are longer, so the running boards could be lower, to enable easier truck entry. You can use the big truck fenders as they are, but the are wider and have 4"-5" larger wheel openings then the pickup fenders and might look a bit strange with the smaller Dakota wheels. Then the rear portion of the fenders will probably be sitting on the ground (without even lowering the truck). Wouldn't have to worry about any tire rub issues with the big truck fenders though. Gene
[Re: poorboy]
#1603668
04/06/14 12:33 PM
04/06/14 12:33 PM
RUMBLON
Cambridge Idaho
Gene thanks. I just found my "dodge pickup COLOR HISTORY BOOK" and was going to start looking for answers. If I get this thing it will be at the price I need to be into it. I wont use the frame or old stuff and there really is no bed thats usable, just an old flat bed. I could do a 4X4 on a Dakota on this one an fab a bed and look for a half ton verion for a ROD truck. Does anyone know if that other cab looks to be a dodge?
RUMBLON
[Re: RUMBLON]
#1603669
04/06/14 01:02 PM
04/06/14 01:02 PM
Mopar Ron
shouldn't be to hard to find a door for the dodge. and if you did the truck on a 4x4 dakota chassis the fenders would probably work out great. years ago my son RJ put a 46 cab on a ramcharger chassis and he had 36" tires and he opened the wheelwells up about 3" for better clearence, the extra width of the fenders worked out for him... the green cab look like a 35-38? chevy/gmc. here is a 37 chevy and the cab you are looking at notice the body lines.
[Re: Mopar Ron]
#1603671
04/06/14 04:10 PM
04/06/14 04:10 PM
RUMBLON
Cambridge Idaho
here is a 37 chevy and the cab you are looking at notice the body lines. [/quote
Thanks Ron, you are the master on old school. Even if its a chebbie, I can always use it for trading stock with the lesser brand/ minded humanoids.
RUMBLON
