Page 3 of 6 1 2 3 4 5 6
Re: Update: making progress on color change [Re: roe] #1602034
06/22/14 01:27 AM
06/22/14 01:27 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
just like mine!!
Re: Update: making progress on color change [Re: Golden-Arm] #1602035
06/22/14 01:43 AM
06/22/14 01:43 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I didn't see this pic until after I had decided on a color, but I like the look of this truck. It belongs to a member here, coronet1966d. I thought about blacking my grill and bumpers out, but decided against it. I can always do it later if I change my mind. I like the look of his truck though.
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Update: making progress on color change [Re: roe] #1602036
06/25/14 01:04 AM
06/25/14 01:04 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Great news. I stopped next to a body shop to take a look at a dog house that was for sale. Bought the dog house and started chatting with a guy wearing a t short with the logo on it from the body shop. Figured he worked there. Told him about how I was interested in learning paint and body, that I was working on a truck, yada yada and small talk. Nice guy. Turns out he's the owner and he offered to let me come in on the weekends to learn the trade, teach me some tricks etc. I'm pumped, can't wait.
Re: Update: making progress on color change [Re: roe] #1602037
08/24/14 04:46 PM
08/24/14 04:46 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Next update. Finally had a chance to put in some more work. This is coat #3 after doing some sanding. I sanded too aggressively in a couple of spots and went too low so you'll see that, especially where I was trying to sand away a run by my passenger door. I think I'm going to be a lot less aggressive sanding from here on out and either stay away from edges as I knock down the little orange peel that I get, or not even worry about orange peel and only scuff it enough for the paint to grab every two layers.
Starting to get better coverage and I figured out how to get better coats with less roller lines. Before I was working smaller areas maybe 36x36" as I worked my way around the truck. That particular area was really smooth but you would see lines from area to area because of the paint starting to set. This time I would work really fast to cover an entire panel then go back over to knock down bubbles/level the paint. It made for much better smoothness and uniformity on the panels without that segmented look.
Re: Update: making progress on color change [Re: roe] #1602038
09/05/14 12:13 AM
09/05/14 12:13 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Next update. Here is after coat 4 with everything prepped to do the black accent at the bottom of the body, and the DODGE on the tailgate. Im still deciding on a butt stripe as well. Im leaning towards yes... It was late so I just took these to show the prep work. I haven't decided if Im going to do another coat of gray to the body or not. It looks good but because I was less aggressive with my sanding, there is a pretty good level of orange peel. Not a lot, about equal to the factory job on modern cars. Its just that I know that I can get it smoother if I want to, which will make my final buffing/polishing turn out a better shine/reflection. Im just so ready to drive it that I don't wanna wait. Decisions....
Im either going to leave it like it is, or go back and wetsand with 600 grit, then one final coat. This black should go really fast because its such a small area, I can get 2 coats in per day about 12 hours apart. Then I can move on to the rustoleum roll on bedliner, and I want to have my sliding back glass replaced with a one piece.
Overall I think Im leaning towards sanding and doing one more coat of gray with less peel.
Oh, and I still have to do the cowl vent.
This part was time consuming, taping it up and then cutting the letters out with a razor blade was nerve wracking. I'd never done anything similar to this.
Re: Update: making progress on color change [Re: roe] #1602039
09/05/14 03:22 PM
09/05/14 03:22 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
don't know if you know, but you can get decals for the letters. looking good, and don't sweat the 'peel, it will go away with some cut & buff action.
Re: Update: making progress on color change [Re: Golden-Arm] #1602040
09/05/14 09:18 PM
09/05/14 09:18 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Haha, no I didn't know that. Might have kept me from being so nervous as I cut away the tape. All I kept picturing was my hand slipping and leaving a long slice in my nice paint
Re: Update: making progress on color change [Re: roe] #1602041
09/06/14 01:58 PM
09/06/14 01:58 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i know the feeling. on my last li'l red express truck, i repainted the dodge letters on the grill, using the same method you used on the tailgate. i also did the black bars, between the horizontal grill pieces. it was like, 3 hours of taping and cutting, for 2 minutes of painting.
Re: Update: making progress on color change [Re: Golden-Arm] #1602042
09/09/14 12:57 AM
09/09/14 12:57 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Ok, here are some pics of the truck as it sits now. So far Im happy with the results. The finish right now is without sanding, polishing or waxing. Its just the natural gloss of the paint. Im probably going to lightly sand and hit the black with two more coats, then see where it stands. But so far Im happy with my $100 paintjob.
From this:
To this:
Its funny how much getting the black on there made the truck look so much more complete.
Those are cloud reflections you see, not paint issues. I'll try to get some pics while its still sunny out.
Cloud reflections
This is the worst spot on the truck. I had sprayed the body line with spray bomb to get in there, and a 10 minutes later while rolling I forgot and rolled back over it and it caused the paint to wrinkle.
Next up is rolling on some Rustoleum bedliner. This whole truck is going to be the product of rustoleum products and a roller
Re: Update: making progress on color change [Re: roe] #1602043
09/09/14 04:02 PM
09/09/14 04:02 PM
scratchnfotraction Offline
swweeettt!!!
I see you in the door reflection..I thought you would have been taller.
that's some pretty good reflections, I know the pics dull it down some but I bet it is real nice up close.
Re: Update: making progress on color change [Re: scratchnfotraction] #1602044
09/09/14 07:36 PM
09/09/14 07:36 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
thats pretty impressive for rustoluem and a roller
Re: Update: making progress on color change [Re: 72d100] #1602045
09/09/14 07:57 PM
09/09/14 07:57 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i'm wondering if it's rustoleum topsider. we've been painting boats with it down here, and if you follow the directions exactly, it comes put looking like a sprayed paint.
Re: Update: making progress on color change [Re: scratchnfotraction] #1602046
09/10/14 12:07 AM
09/10/14 12:07 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Thanks guys. Its been fun learning and trying this method. Best of all it let's me get this truck looking better very cheaply. Right now I'm in this truck for $1500 purchase price and $100 in paint supplies, and about $70 for 2 used tires. It looks really good in person. And because I can touch it up whenever at no cost I won't worry about driving it anywhere or doing anything in it.
As far as the paint its just rustoleum from Home Depot. I used their clean metal primer over the whole truck, the gray is standard rustoleum, and the black is the rustoleum professional. I wanted to get them the same but I had to order the gray and didn't realize it was the standard stuff. But its all worked out so far.
I didn't expect it to look this good but I'm glad it does. I can't wait to see what the cut, buff and wax makes it look like.
Update: almost done [Re: roe] #1602047
09/22/14 12:21 AM
09/22/14 12:21 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Well here are some pics after working on it all day yesterday. I would have more done but I was layed up all day with naseau/vomiting/diarrhea . Please excuse the grass, today was yard day but because of the NVD I didn't get to it. I still need to paint the cowl vent panel,re-install the bumpers, add the chrome drip rail molding, and do the bed in rustoleum. Then I'll start on the interior. Im going to keep it burgundy. The dash is pretty nice so I'll either clean up my door panels and dye them with aerosol stuff from the parts store, or pull some better ones from the J/Y and do the same. Then I'll just shampoo and detail it really well and drive the wheels off. And I want to have a one piece rear glass put in. Im going to have to stop myself so I don't sink more money into this than I planned on.
Im really excited about how the trim came out. The metal portion was really, really bad looking. It was yellowed, and dirty. I honestly didn't think that it would come clean. But I mixed some dawn dish soap with some Purple Power, and used a red scothbrite pad to scrub it and with some elbow grease they came out nice. Just have to hit it with some polish now.
Ok, Im done babbling now:
Re: Update: almost done [Re: roe] #1602048
09/22/14 03:19 AM
09/22/14 03:19 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Good Color Combo!
Re: Update: almost done [Re: 76dodgeboy] #1602049
09/22/14 11:15 PM
09/22/14 11:15 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Good Color Combo!
Thanks. I'm really digging it too.
Re: Update: almost done [Re: roe] #1602050
09/23/14 08:48 AM
09/23/14 08:48 AM
hope you feel better soon. the big 3 is never fun.
that thing looks better every new pic you post.
Re: Update: almost done [Re: scratchnfotraction] #1602051
09/23/14 09:10 PM
09/23/14 09:10 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Thanks. It was some kind of 24hr bug. It was rough but was over quickly. I can't wait till this wknd so I can finish it up.
Re: Update: almost done [Re: roe] #1602052
09/23/14 09:27 PM
09/23/14 09:27 PM
Between Houston & Galveston TX
SattyNoCar Online work
SattyNoCar  Online Work
Wow Roe! That REALLY looks good!
John
Re: Update: almost done [Re: roe] #1602053
09/23/14 09:49 PM
09/23/14 09:49 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
what time can I drop my truck off? It's only a shortbed, so you can probably knock that off in no time. I'll take the grey too
1981 Dodge D150 360 auto
