Which rod bearing do use #1594998
03/18/14 10:46 PM
03/18/14 10:46 PM
TN
SCATPACK 1 Offline OP
TN
Which rod bearing do you use and why?
K-1 rods with big block Chevy rod bearing and Mopar width.
Coated or non coated?
How much clearance for street and strip use?
Jerry
Old Geezer Racing
Re: Which rod bearing do use [Re: SCATPACK 1] #1594999
03/19/14 01:10 AM
03/19/14 01:10 AM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
CB743HN And CD743HNX
Buy them coated from Calico. Or if you don't want to mess with having them coated, buy the CB743HNK (K = precoated)
The "X" is .0005 larger to allow for the coating.
It's not unusual to mix HN and HNX halves.
Set the clearance for a street engine between .0025 and .0035, on the high side as you go up in power.
Re: Which rod bearing do use [Re: Mopar_Rich] #1595000
03/19/14 07:55 PM
03/19/14 07:55 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
.0035" on a 2.200" rod?
Wow...I thought I had my stuff loose at .003"
