How fast with a stock 8 3/4
#1593873
03/16/14 03:09 PM
03/16/14 03:09 PM
Posts: 952 Stockholm, Sweden
MrSixpack
Stockholm, Sweden
How fast have you been with a stock 8 3/4. 60 feet and et. Weight/Hp/tire size Just want to know when I will break my 8 3/4 Looking for a 9" or Dana,but they are hard to find here. I wonder if my 68 B-body Dana will fit my 1980 F-body that has stock frame rail and no modifications to the wheel wells. I will run 275 Micky T's drag radial. Let the bashing begin
1970 Super Stock Challenger ex. Paul Rossi 1968 Dodge Dart GT 340 1968 Dodge Charger /6 3 speed manual 1966 Chrysler 300 Loaded 1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: How fast with a stock 8 3/4
[Re: MrSixpack]
#1593874
03/16/14 03:21 PM
03/16/14 03:21 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I will assume you will back brace it... I was running mid 9s with a totally stock center... had just over 600 passes on it when the cap broke.. thats when I changed over to a alum center... on the stock one I was 2400# with 620 hp, 1.23 60', 13.5 X 31 slicks.. if you were to put load bolts on the back to touch the caps it helps alot
[Re: 1974 474 Duster]
#1593877
03/16/14 05:03 PM
03/16/14 05:03 PM
MrSixpack
Stockholm, Sweden
Yes it is back braced, but still original axels and pumpkin with a 3.91 gear and clutch type limited slip. It will be exciting to see how it will work, I think twisting the axels are what will happen first. Thanks
1968 Mini Cooper
[Re: MrSixpack]
#1593878
03/16/14 05:08 PM
03/16/14 05:08 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have run 10.70's at 3700 lbs with an all stock 8-3/4. I know I am pushing my luck and want to go with a Dana some time when I can afford it. I use a Dynamic 9.5 street/strip converter as my car does not launch real hard but hard enough for me which I am glad as it does not seem to be to hard on the rear. But I only race a few times a year. Ron
[Re: 71yelladustr]
#1593881
03/16/14 07:42 PM
03/16/14 07:42 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
My 100% stock 8 3/4 went best of 1.50 60ft in a 3700lb car. I took the axles out and they were all twisted up. Also, I tried (well accidentally tried) to leave REAL hard on it the last time out. Sheared the pinion off, but the stock axles survived. IMG_20130823_200437_896-1 by wright2305, on Flickr
[Re: dizuster]
#1593882
03/16/14 08:37 PM
03/16/14 08:37 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
My experience was the differential itself broke, side gears sheared. Mine now is backbraced and has a locker in it with Dr.Diff axles. So far so good.
[Re: StealthWedge67]
#1593883
03/16/14 09:25 PM
03/16/14 09:25 PM
9.98 @ 139. No back bracing.
[Re: mopar65]
#1593887
03/16/14 11:18 PM
03/16/14 11:18 PM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
Back braced housing, Mark Williams spool and 35 spline axles. 742 case. Richmond 3.91 gears. Leave the line at 2000 rpm. Runs a 10 teens, 10 twenties. Race weight is 3750 lbs. Still going. Where's Quicktree? LOL..
[Re: MrSixpack]
#1593888
03/17/14 12:59 AM
03/17/14 12:59 AM
Posts: 102 NC
onefastindy
NC
I've been 5.80's in the 1/8 with 1.29 60ft with stock axles and sure grip before it twisted the housing. Now it's got a new one that's back braced with moser axles and spool with billet caps.
[Re: Thumperdart]
#1593890
03/17/14 01:24 PM
03/17/14 01:24 PM
Posts: 4,064 Mo.
racerx
Mo.
Tell us more.................
^^^What he ask^^^
[Re: actionange]
#1593891
03/17/14 01:30 PM
03/17/14 01:30 PM
Quicktree
I can tell you he's not wasting money on an 8/3/4 thats for sure
[Re: MrSixpack]
#1593892
03/17/14 01:53 PM
03/17/14 01:53 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
It is relatively easy to build a Dana 60, because all you have to do is to narrow the axle tubes to fit your application, and they are straight, no curves. Moser, Strange and others have the housing ends you need. You just have to decide what brakes to use. I built the latest one from a Jeep J20 rear axle that was 40 years old. It came from a wrecking yard with a 4.10 gear on a PowerLock carrier with 35 spline axles and tapered Timken bearings, 12" drum brakes, 5 on 5.5" bolt pattern that will easily fit my '87 D100. The Dana had been rebuilt (new bearings, clutches & brakes) when I got it for $400.00. I put another $400.00 into it having 1 tube shortened and 1 axle shortened and resplined. Your experience may differ, but I am pleased
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Quicktree]
#1593893
03/17/14 02:00 PM
03/17/14 02:00 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
8 3/4's are super strong and I wouldn't worry about it. I would recomend axles, gears and spool, back brace wouldn't hurt either.
67' charger 499 RB
10.57 at 127
[Re: onefastindy]
#1593900
03/17/14 11:19 PM
03/17/14 11:19 PM
Posts: 4,064 Mo.
racerx
Mo.
Car weighs 3260. It's a foot brake car. Stock stuff lasted about 25 passes with that 440. In that pic it had a 1.29 60 ft.
Footbreaken a 3200 lb.car witha 1.29 60's is hookin
[Re: Thumperdart]
#1593901
03/17/14 11:27 PM
03/17/14 11:27 PM
Posts: 4,064 Mo.
racerx
Mo.
Thumper are u trying to stir the pot?lol
No sir, I just trip on the fact that some 11-12 second cars kill em and these guy`s and myself run 9`s and faster and they live.........But as Quick pointed out, guess I`m not totally hooking.............
Thump. doesn't your car has the MW cap on it?I think the op.was referring to a stock rear.With that said,i think that the reason so many 8.75's or in the 9's,8's along with other modification that they do to these rearends
[Re: FastmOp]
#1593907
03/18/14 10:54 PM
03/18/14 10:54 PM
MR_P_BODY
Hi 6's in the 1/8. Anything past 6.80 is gambling on stock everything. I went 6.00 with my 8&3/4. But the trans break is the week link finder.
I've been using a trans brake from day one.. like I said I got over 600 passes on a stock center.. even with the cone style posi.. all with the trans brake but my car is lite... each pass was from 5200 rpm or up launches...weight tends to kill them
[Re: 70dusterjohn]
#1593910
03/19/14 10:25 AM
03/19/14 10:25 AM
Posts: 13,345 Marion, South Carolina [><]
an8sec70cuda
I broke something in the stock sure-grip running 11.40s at 3700#. Found twisted axle splines when I took it apart. Changed to a spool w/ 35 spline axles and all was good until I started running mid 10s at the same 3700#. It took the teeth off the ring and pinion. Car never 60 footed all that well (1.49-1.51) w/ a best of 10.40 at 129 mph. Once that happened I put a Dana in it. That was in 2003...haven't touched it since.
[Re: an8sec70cuda]
#1593911
03/19/14 10:51 AM
03/19/14 10:51 AM
Posts: 4,064 Mo.
racerx
Mo.
Wish i knew at what weight kills them as i broke one bout 20 years ago on the street.Tore it apart and it was the spider gears,Went to a spool 33 spline with the street/stripe axles broke an axle,upgraded to a 35 spline/race axles all was good ran with that setup for about 10 years never broke a gear or anything(wish we had a wood knocking icon )but went to a different gear(4.56 to 4.10)which kind of raising my worried factor cause the 4.10 ring gear seems a little thin we shall see.
