Re: Think I may have messed up...Help!!!!!
[Re: Supercuda]
#1593679
03/16/14 01:43 PM
03/16/14 01:43 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
Not sure on that one, I did build a 273 a few yuears ago with a hydraulic and I used the original push rods and rockers.
Careful, your character's showing!
[Re: StealthWedge67]
#1593688
03/16/14 08:26 PM
03/16/14 08:26 PM
Posts: 464 KY
Telvis
KY
All of the rockers are oriented correctly. Already checked that. I primed the oil pump and turned the crank to make sure oil was flowing to both sides through all the passages. One thing I did notice this morning. The oil is thick, really thick almost like honey. Like to never got it to filter through the coffee filter. I noticed when I primed the pump before installing the motor that the oil was thick and kind of milky then but figured it was because of the cold temperatures. It was about 35 degrees this morning when I drained the oil and it was still just as thick. It might just be normal for the Rotella. I have never used it for break in before but read it is good. I also used Lucas break in additive. I am starting to wonder if a lighter oil with some break in additive might solve the problem. Would 10W-30 ( something other than Rotella) be too thin? I might give it a try tomorrow. Let it run a few minutes and see if it helps. Any reason this might be a bad idea?
That's King Weenie to you!
[Re: Telvis]
#1593691
03/16/14 08:45 PM
03/16/14 08:45 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
"milky"?? as in color?
Yep, that was before the motor was ever turned. It was cold back when I primed everything. I had my heater on in the garage but it was still pretty cold. I figured to was because of the cold.
if your oil is milky colored then you've got a coolant leak.
[Re: Telvis]
#1593692
03/16/14 08:49 PM
03/16/14 08:49 PM
Posts: 464 KY
Telvis
KY
The oil still had the same milky color to it this morning when I drained it. My initial thought was it's metal in the oil but I found no metal. I checked thoroughly with a very bright light. It's milky...That's the best way to describe it. I had a motor spin a rod bearing once many years ago. I know what metal in the oil looks like. This isn't metal. The oil is really thick and weird colored. It's brown and milkish.... I don't know any other way to explain it.
