Hotchkis 76 Dart Build *Updated 20 March 2014
#1592870
03/14/14 05:02 PM
03/14/14 05:02 PM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
I think the cat is pretty much out of the bag as to Hotchkis building a 76 Dart for Kevin on this site. The guys working on the car are the same folks who assemble all of our components we sell as well. So I think it is time for some pictures! Hotchkis Performance East is our all-new facility in Mooresville, North Carolina that specializes in custom fabrication, cooling system optimization, racing safety equipment design and installation, and race car prep in addition to manufacturing and installing Hotchkis Sport Suspension products. It is headed up by Kevin Bryde, a designer and fabricator with over 17 years’ experience in motorsports. Kevin’s career has let him work with some of the most talented drivers in the industry including Dick Trickle, Tony Stewart, Sterling Marlin, Dario Franchiti, Juan Pablo Montoya, Martin Truex Jr., and Jamie McMurray. Most recently Kevin worked for Chip Ganassi Racing in its Engineering Department where his duties included design, fabrication, and prototyping for NASCAR, Indy Car, and Rolex Sports Car race cars. Kevin also has over ten years’ experience in all aspects of driver safety, including seat, head restraint, and race car cockpit design. Introduction:Hotchkis Performance East's latest project is a complete buildup of this 1976 Dodge Dart for Kevin Wesley, creator of the Hotchkis Autocross Taxi and avid driving enthusiast. Kevin's goal for this car is to have a car that he can take to compete in events like Targa Newfoundland and Pikes Peak, so this car has to be fast, but it also has to be safe. It will be receiving a full FIA-based roll cage, a modern 6.4L Hemi and Legend GT-700 transmission transplant, full Hotchkis TVS suspension, and more. Stay tuned to this thread as we continually update it with new pictures of the build as we overhaul this former Mopar econobox. As you can see, when the car first rolled in the shop it was already stripped down and had an old roll cage in it. Though it looked a little rough, it was in fairly good shape and the body was straight and mostly rust-free. Even the roof was rust-free and only had the adhesive residue from the original vinyl top. [SIZE=3] Step 1: Engine Mounts[/SIZE] The first thing we had to do with the Dart was to get its new Mopar 6.4L HEMI and Legend GT-700 transmission into place. Once we determined how much clearance was needed for the oil pan, headers, steering rack, etc, we were able to begin to design the mounts. Once we got all of our measurements, it was off to the drawing board. What we came back with was this beautiful piece: Now we were free to create the frame mounts and test fit the mounts together. Here's the passenger side: And here's the driver's side: As you can see, the clearance is perfect and the new HEMI looks quite good in its new home. More photos of the engine mounts here: http://www.flickr.com/photos/hotchkis/sets/72157639748590773/[SIZE=3]Transmission Crossmember:[/SIZE]The final step to marrying the modern 392 HEMI and Legend transmission to the car was the fabrication of a new transmission crossmember. Here you can see one of our master welders and fabricators working on the end plate to the new crossmember: And here's a close-up of his steady hands at work: More welding: Here's the finished product. Gotta love the color of welding: And now to fitting the newly fabricated crossmember to the car: More photos of the crossmember here: http://www.flickr.com/photos/hotchkis/sets/72157639747282175/[SIZE=3] Step Two: FIA-Based Roll Cage[/SIZE] Now that the engine and transmission have been mounted, it was time to construct the roll cage. Because of the different races the owner wants to be able to use this car for, we needed to make sure that all of the safety equipment conformed to the necessary regulations so that it could be raced anywhere in the world. After consulting with the Rally America Competition Director Mike Hurst, it was time to begin the construction. But before we could do that we had to cut out a few sections of the existing cage. Once the parts of the old cage were removed we began by constructing diagonal bracing and rear kicker braces that connect to the main hoop. Because this is going to be a leaf spring car, the rear kickers had to extend all of the way to the rear mounting points of the springs. Now that the basics were covered it was time to add the increased protection required by the higher levels of motorsports. First up were the door bars, which help protect the driver and passenger from cabin intrusions from contact during wheel-to-wheel racing or from collisions with other objects. After laying out the design on the table, we bent the bars to match the pattern before fitting them to the car. After the bars were tacked into place, we double checked all of the measurements and angles for compliance before fully welding all of the joints. To make this cage as strong as possible, the main joints all received additional bracing and “taco gusset“ reinforcement. A good roll cage will tie into the unibody structure in as many places as possible. Not only does this make the vehicle safer, but it dramatically increases the rigidity of the unibody, reducing chassis flex during hard cornering. Here you can see the installation of the A-pillar gussets that are critical for driver safety in the event of a roll over. More photos of the safety cage construction here: http://www.flickr.com/photos/hotchkis/sets/72157639747044065/But a proper safety cage doesn’t just end at the firewall. It extends all the way through the engine bay to reinforce the front clip and add stiffness to the front of the car. This added rigidity helps handling by allowing the suspension to do its work without having to control chassis flex while also delivering improved driver safety. Regulations require the mounting points to be 18 square inches, so to maximize area we developed a compact mount with multiple fingers to better fit the unique curves at the corners of the engine bay while also helping to spread the load over a larger area. The next step to reinforcing the front end was to tie these new bars into the upper shock mounts. Like the star-shaped mounts on the firewall, these mounts are fabricated out of 16-gauge sheet metal and are designed to disperse the tremendous forces the upper shock mounts will see during racing events. Here is the finished product with completed firewall, frame, and shock mounts: Now it was time to work on the bay bars that will tie the two shock towers together. But before we could start designing those we had to check how much clearance we had between the engine and the hood. Even thought he clearance was tight, there was still ample room to fit the bars without contacting the hood or the intake manifold. Now it was time to take our measurements and begin constructing the bay bars (which act similar to a bolt-in strut/shock tower brace in street cars). After creating the basic structure of the bay bars we reinforced them with new gussets. Here is the finished product with the ends trimmed down for access to the bolts for easy removal: More photos of the Engine Bay Bar construction here: http://www.flickr.com/photos/hotchkis/sets/72157639746540665/
Re: Hotchkis 76 Dart Build
[Re: BigBlockMopar]
#1592873
03/14/14 09:42 PM
03/14/14 09:42 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Beautiful
If you guys has a TV/Internet show just showing this build in a professional manner (not clown like) it would be awesome.
[Re: SattyNoCar]
#1592879
03/15/14 02:44 PM
03/15/14 02:44 PM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
Looks great. Is it going to done in time for Carlisle?
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
[Re: Dan@Hotchkis]
#1592882
03/15/14 06:00 PM
03/15/14 06:00 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Kevin has teased me with this hot rod for a while now and its also being shown on PT.com. Really good ideas from this build and to me that is the best part and why I appreciate you guys sharing what you do. Now if I could get David Barton to share a few details about his 850hp Gen III engines we would be golden lol...Oh and this thing is getting an electric assist steering setup from what Kevin has divulged in a couple posts elsewhere.
Mopar to the bone!!!
[Re: Gavin]
#1592888
03/19/14 01:00 PM
03/19/14 01:00 PM
Posts: 256 USA
Consulier
USA
Details on the electric steering conversion I posted on FABO. _________________________ You shove the unit from a Vue/Cruze/Equinox under the dash and run a controller available on eBay. I'm using a Hower 2:1 steering quickener between the column and the manual box. That will give me 12:1. If I want faster I can switch to a 20:1, or 16:1, box to speed it up more and even go to fast ratio idler/pitman to adjust even further. Since $$$ seems to be a hot topic in the thread, let's look at how much is going into this solution. Used Vue column $100 eBay controller $65 Howe Quickener $92 U Joints/Couplers/Steering Shaft $325 Borgeson Manual Box $380 Wow... $962 for a complete electric steering solution with steering box. Price out a new FFI box (or Borgeson), rebuilt column, pump, pulleys and it's pretty much a wash. What really drove this decision? The headers... 2" TTI Gen3 will not clear any power steering box. It's a heck of a lot cheaper to put in this solution than have a set of custom headers built. Plus, better packaging, adjustable, etc...
[Re: Consulier]
#1592890
03/19/14 06:12 PM
03/19/14 06:12 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
I like this solution better than the electric assist as part of a rack since you can retrofit to more cars. Interested to see how you mount this up under the dash, assuming you need to add some extra support to counter the forces from the assist unit (tie into the pedal box/dash/firewall)? Also cool since it removes some weight from the front of the car and one less belt driven accessory. How much current does one of these pull? - wait I found it. 80A. So other than packaging, the only upgrade would be a high amp alternator it looks like.
[Re: PHJ426]
#1592894
03/20/14 03:41 PM
03/20/14 03:41 PM
Posts: 256 USA
Consulier
USA
Is electric power assist steering better or just different?
It's definitely high tech either way.
I know my Ford Flex will parallel park itself with no driver input. I don't live in the city so I never use that feature of the electric power assist steering controls.
To me it's both. Different because you dump all the hydraulics and engine driven stuff. Better because it's adjustable (dial in the assistance), it fits and less weight.
There is still going to be a draw on the engine with the alternator, so not sure what the difference in HP would be between the two.
[Re: 72Swinger]
#1592897
03/20/14 04:44 PM
03/20/14 04:44 PM
Posts: 256 USA
Consulier
USA
6.4 cover must be different than 6.1, my alt clears good with lip removed off frame.
VVT cam moves it out 1/2 inch of something like that, so you can't use the 6.1 or earlier 5.7 alternators.
[Re: Consulier]
#1592898
03/20/14 08:51 PM
03/20/14 08:51 PM
Posts: 3,456 Fly Over States
PHJ426
Fly Over States
If you go by the physics of it....energy cannot be created or destroyed. ...only change forms. I see it as different and cool from my geek electrical / electronics / instrumentation background. Depending on how much you can tune it for the response you like and for the feedback you get is what I will be keeping a look out for. Are there other vendors selling controllers for this as well or is this option currently a one vendor deal?
Re: Hotchkis 76 Dart Build *Updated 20 March 2014
[Re: Pale_Roader]
#1592901
03/22/14 11:54 AM
03/22/14 11:54 AM
Posts: 256 USA
Consulier
USA
Neat build, but you guys sure aren't worried about weight are you...??? Starting with the heaviest A-body ever made and adding a LOT ov weight.
If FullMetalJacket wandered in here from the race-only section he'd have a stroke looking at those pictures...
Whats it going to weigh? Any idea?
Under 3000. It started as a Dart Lite, so far from the heaviest a body.
[Re: mopardamo]
#1592906
03/22/14 09:29 PM
03/22/14 09:29 PM
Posts: 256 USA
Consulier
USA
Hello,
Love the build. What were the factors that made you go with the GT-700 trans? Did you consider the T56 and if so why did you choose not to use it?
It started as a car that was all bolt together with no extra fab required. That has changed a bit. So, I already had the trans based on that.
Ultimately it didn't fit courtesy of the final engine position required for the headers and that required some tunnel mods. Since it was getting cut out anyway, might as well make it removable. Plus I needed good seat mounts and just tying something into the stock tunnel isn't very stong.
[Re: 72Swinger]
#1592907
03/22/14 09:36 PM
03/22/14 09:36 PM
Posts: 256 USA
Consulier
USA
Is this thing going to have glass panels Kevin?
Not to start. We'll see where the weight shakes out and if I need to put it on more of a diet.
Since it's a Dart Lite, the hood and decklid will only save about 40lbs.
[Re: Dan@Hotchkis]
#1592908
03/28/14 02:48 PM
03/28/14 02:48 PM
Posts: 2 Albuquerque, NM
perlhaqr
Albuquerque, NM
Now it was time to work on the bay bars that will tie the two shock towers together. Here is the finished product with the ends trimmed down for access to the bolts for easy removal:
Well, dang. That's sure some amazingly pretty fabrication.
Please keep updating as you go along!
[Re: perlhaqr]
#1592910
03/28/14 04:03 PM
03/28/14 04:03 PM
Posts: 256 USA
Consulier
USA
What's the extension on the front side of the engine mount for?
Just mock up stuff.
[Re: jcc]
#1592912
03/28/14 08:00 PM
03/28/14 08:00 PM
Posts: 256 USA
Consulier
USA
So is the plan to ballast up to 3000? I see Mig and Tig going on here, so I assume this MS and not CM? With such an extensive build I would have thought Cm was a more favorable solution or is that not FIA approved? I wonder what vertical movement/flex might occur with the front bent tower connector brace under dynamic loads.
Your fabricators are talented.
Chromoly is not allowed by the rules where I will run.
The only class to ballast up to would be that SCCA CAM class. I doubt this car will see much action in that class. Plus, I think that is with driver anyway, so it wouldn't be an issue.
USCA is "dry weight" or less driver as I read it and that would put me in the under 3k class.
If I really want to start taking weight out, I figure there is another couple hundred pounds moving to all fiberglass. Plus I could still do an alum block as well. Don't think I'll need it, unless I move to a small motor for some reason.
[Re: Consulier]
#1592913
04/02/14 02:29 AM
04/02/14 02:29 AM
Posts: 704 USA
rftroy
USA
Kevin, I saw this as a great alternative to running a manual 16:1 box in my Challenger since the factory power unit is an increase of almost 40 pounds. That was before yesterday's news when GM recalled close to a million and a half cars for this faulty electric power steering unit.
So, first, do we know what the flaws in this unit are (they seem to have been corrected after 2010, judging by the recall parameters. Unless this box was discontinued after 2010) and can we, the users, implement any fixes?
Second, would you show us the structure you fabricate to mount the unit under the dash? This would save some wheel reinvention when I go to put mine in an E body.
I wouldn't think it would be too complicated. With the factory setup all the torque is provided by the driver and reacted by the steering box. The column mounts only have to take the lateral reaction loads. With this electric box a lot of the torque, and a smaller reaction load, is now taken by the dash structure. Since people aren't too strong, I would think that the structure to react the loads would not need to be too hefty.
Have you got this structural reinforcement planned out yet?
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#1592914
04/02/14 02:58 AM
04/02/14 02:58 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
Robert
I have a 2012 Mustang with electronic power assisted steering and to be honest it has done a few strange things in the last few years. In the summer if you take a bunch of hard corners it sometimes will shake the steering wheel in your hand after you would pull it straight. And this winter I had the car out maybe 5 times and twice while driving it the steering stuck to the point I had to give it a hard snap to get it to turn, Ford did just put out recall for some of their other cars but not the mustang. It does have good feel and you can change the steering effort with the push of a button.
A new iron curtain drawn across the 49th parallel
[Re: rftroy]
#1592915
04/02/14 09:16 AM
04/02/14 09:16 AM
Posts: 256 USA
Consulier
USA
All the news I have seen revolves around the ignition switch for the recall and the power steering issues are for a different system (Cobalts, HHR's, etc...). There are some known issues and known fixes with the one I selected, but those are well documented and simple. When GM fixes it, they just swap out the entire unit, so the entire assembly is labeled as "bad". Typically you will see a burned up motor is this unit, which is available for replacement. Don't lump the Equinox/Vue unit in the with the Cobalts and HHR's. Different system that is being recalled.
One thing to remember, this system is adjustable. The motors burn up from slow parking lot, lock to lock, daily driver stuff. This thing isn't a daily driver. If you are worried about burning the thing up in slow stuff like that, turn the thing down. What's left? Your usual Mopar manual steering.
We'll see how it goes, but I'm not losing sleep over this. It's a very well documented swap in Europe on a lot of cars.
When I have pics of the mounts they come up with I will post them up and detail the build.
[Re: Consulier]
#1592916
04/03/14 01:03 AM
04/03/14 01:03 AM
Posts: 704 USA
rftroy
USA
Yep, you're right, I checked the recall list; I'm not up on GM vehicles. Good to know. Thanks, Kevin. Time to hit the wrecking yards.
Looked up specs on Saturn Vue and Chevy Equinox. Saturn is about 3500 lbs., and the Chevy is 3926 per Chevy's website, so the power steering unit should be a decent match to a lightened Challenger, even with big tires.
Robert
[Re: dangina]
#1592919
04/23/14 11:02 AM
04/23/14 11:02 AM
Posts: 256 USA
Consulier
USA
When they get the next round of pics loaded the details should be in there. I was down for seat and steering column placement a couple weeks ago and looked at it. The rear shock upper mount was all cut out. A new bar between the rails was fabbed and tied into the down tubes of the cage. It moves the upper mount out more so that the shocks are more vertical. Super beefy and reinforced so there shouldn't be any issues with durability. You can see a little bit in this pic how far out the upper mount was moved.
[Re: Consulier]
#1592920
04/23/14 11:12 AM
04/23/14 11:12 AM
72Swinger
Nebraska
Looks like the rails are moved in a tad. That car should be rediculous.
[Re: 72Swinger]
#1592921
04/23/14 12:45 PM
04/23/14 12:45 PM
Posts: 256 USA
Consulier
USA
Framerails are untouched. Wheel wells are opened up to the outside and you can see the inner tubs are stock.
[Re: Consulier]
#1592922
04/23/14 01:01 PM
04/23/14 01:01 PM
72Swinger
Nebraska
I was looking at the trunk supports and they're different on the Duster trunks. That makes it look like the inner tubs are moved in further. Optical illusion.
[Re: NV69B7RR]
#1592924
05/15/14 09:59 AM
05/15/14 09:59 AM
Posts: 256 USA
Consulier
USA
[Re: Consulier]
#1592925
05/15/14 10:28 AM
05/15/14 10:28 AM
Posts: 256 USA
Consulier
USA
[Re: Consulier]
#1592928
06/09/14 01:18 PM
06/09/14 01:18 PM
72Swinger
Nebraska
Looks just right Kevin, what wheels? Can we put a 71 Demon nose on her?? That would require a hood change, not really something that is probably a priority.
[Re: 72Swinger]
#1592929
06/09/14 02:43 PM
06/09/14 02:43 PM
Posts: 12,375 SoCal
MuuMuu101
I got lucky at Woodward!
SoCal
Hey, stop trying to make it so mainstream with a Demon front end. It's a '76 Dart Sport.
And I agree, those are nice looking wheels.
[Re: MuuMuu101]
#1592930
06/09/14 05:23 PM
06/09/14 05:23 PM
Posts: 256 USA
Consulier
USA
No Demon nose. It stays '76 ugly. Might try something with the grill some day, but nothing in the near future. Maybe some scoops where the turn signals are now and move the signals to the headlights or something. Those wheels are quite popular for some reason. Funny thing is that they are just used to roll the car around. Offset is wrong and they are just $189 cheap Chinese wheels from Discount Tire. I actually had them laying around from the Satellite. Had to use them the first couple events because my Weld Wheels weren't finished yet. MB Battle 18x9.5
[Re: AlexP]
#1592932
06/09/14 09:22 PM
06/09/14 09:22 PM
Posts: 256 USA
Consulier
USA
Are those +15 offset?
Yes, with a 275 on the Satellite. They had some minor rubbing at full lock and under hard lateral loads in the rear, but a small spacer would have fixed that. For the price, they are great wheels. Opened up the center with a die grinder. There is a lip that hits on the fronts.
[Re: ScottSmith_Harms]
#1592934
07/07/14 09:36 AM
07/07/14 09:36 AM
Posts: 256 USA
Consulier
USA
Kevin, that build is over the top cool, fantastic work man!
Kevin and the guys at Hotchkis East are doing a great job. Just sorted out the final bit of the timeline and the car should be ready to be fired by mid August.
Good luck with the Valiant. The Brick should be back on the road by spring. That's the current plan anyway...
[Re: Consulier]
#1592935
07/08/14 01:31 PM
07/08/14 01:31 PM
Posts: 256 USA
Consulier
USA
Just a reminder of the type of events this car is being built to run... 2014 Manx Rally I can't wait...
[Re: JAMESDART]
#1592937
07/12/14 07:23 PM
07/12/14 07:23 PM
Posts: 256 USA
Consulier
USA
what size tires are going on the back with just the outer tub removed? offset spring hangers or stock hangers?
295/40 for now with room to fit more and using stock hangers.
#1592939
07/12/14 08:43 PM
07/12/14 08:43 PM
Posts: 256 USA
Consulier
USA
Nice knowing ya!
That type of tarmac stuff is what I love. Very challenging to say the least.
Here's another good one from the same guys...
2014 Manx Rally
#1592941
07/13/14 10:01 AM
07/13/14 10:01 AM
Posts: 256 USA
Consulier
USA
My first question....A manual trans? That should make things less technical.....NOT!
If I could column shift my 5 speed like this guy, I would...
http://www.youtube.com/watch?v=6se7UKjARmY
If anybody knows how to get a column shift to work with a four speed in an early a body and still have reverse, post it up. I want one for an upcoming project after the Dart.
[Re: Consulier]
#1592942
07/13/14 12:39 PM
07/13/14 12:39 PM
Posts: 619 nj
JAMESDART
nj
ok. im going to put 315s on my duster and don't really want to do spring relocation. I was thinking offset hangers, and remove the outer wheelhouse like that. it looks like it could work, but tight.
[Re: brads70]
#1592944
08/04/14 12:46 AM
08/04/14 12:46 AM
Posts: 256 USA
Consulier
USA
Anything new Kevin?
Getting closer. Plumbed for brakes now, wiring soon.
[Re: boydsdodge]
#1592947
09/10/14 11:20 PM
09/10/14 11:20 PM
Posts: 723 Houston Tx
Uhcoog1
Houston Tx
This build is amazing. Keep the pics coming!
-'02 Dodge Viper Ex-World Challenge racecar -'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
[Re: RichV]
#1592951
09/28/14 02:13 PM
09/28/14 02:13 PM
Posts: 1,144 ontario calif
ns1aar
ontario calif
Some early 60s chevy vans had a 4sp column
NS1AAR
[Re: dangina]
#1592952
11/17/14 08:23 PM
11/17/14 08:23 PM
Posts: 256 USA
Consulier
USA
[Re: NV69B7RR]
#1592957
01/12/15 02:28 PM
01/12/15 02:28 PM
Posts: 256 USA
Consulier
USA
[Re: Consulier]
#1592959
01/12/15 05:02 PM
01/12/15 05:02 PM
Posts: 2,432 NorCal
RylisPro
NorCal
I highly recommend getting the clear cover for the IQ3 250-DS-IQ3CVR The one without a flange
[Re: RylisPro]
#1592960
01/12/15 09:56 PM
01/12/15 09:56 PM
72Swinger
Nebraska
Love the build, helps me make up my mind on a lot of nick nack stuff. I will probably resign myself to nixing the glove box compartment for fuse box access and just have a tray in there for my registration and insurance to sit.
[Re: Consulier]
#1592961
01/13/15 02:28 AM
01/13/15 02:28 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
So you can rear mount these calipers... Maybe my rough and dirty approximation of an alignment was a little funky.
[Re: MuuMuu101]
#1592962
01/13/15 02:51 AM
01/13/15 02:51 AM
Posts: 27,444 So Cal
autoxcuda
So Cal
But what UCA's is he using? And what diameter rotors and what/who's brake setup?
[Re: autoxcuda]
#1592963
01/13/15 02:58 AM
01/13/15 02:58 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
He's using Dr Diff's, I asked him on FABO. I'd assume he's using Hotchkis' UCA's as they're building his car.
[Re: DoctorDiff]
#1592965
01/13/15 03:13 AM
01/13/15 03:13 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
That is my Stage 4 brake kit with Baer rotors and a slightly shorter caliper. I don't think it will clear the Hotchkis UCA, when mounted toward the rear, however.
My experience proves this to be true... Granted my alignment was pretty rough and dirty, the bleeder was literally sitting right underneath the UCA at full droop.
[Re: DoctorDiff]
#1592967
01/13/15 03:54 AM
01/13/15 03:54 AM
autoxcuda
So Cal
Are those 13" rotors or 14"?
[Re: autoxcuda]
#1592968
01/13/15 04:03 AM
01/13/15 04:03 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
It looks like the same kit as mine with 13" rotors. If they were 14" they'd fill up the wheel almost completely. Have you ever seen OzHemi's setup with 14" rotors on an 18" wheel?
[Re: autoxcuda]
#1592969
01/13/15 10:37 AM
01/13/15 10:37 AM
Posts: 256 USA
Consulier
USA
13", they say it clears, I've not been there to see it. If for some reason it doesn't, then they'll flip them around, or whittle up a new adapter to rotate the caliper down to clear.
Not way up there on my worry list at the moment...
[Re: DoctorDiff]
#1592973
01/13/15 05:39 PM
01/13/15 05:39 PM
autoxcuda
So Cal
The rotors measure 13". I also have offset mounting brackets that move the caliper downward 1".
And that checks out to clear the tie rod and not change any caliper to inner rim clearance?
[Re: DoctorDiff]
#1592975
01/14/15 12:03 AM
01/14/15 12:03 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Yes.
Do you have pictures and how much? Do they work in conjunction with the caliper adapters already provided in your kit or are they separate? Although, looking at the '76 Dart, it doesn't seem like he's using them.
[Re: DoctorDiff]
#1592977
01/14/15 01:21 AM
01/14/15 01:21 AM
Posts: 12,375 SoCal
MuuMuu101
SoCal
Your calipers are longer, so the offset brackets (which you already have) are required.
Ah... So the kit on the '76 is an older Stage 4 kit?
[Re: Consulier]
#1592980
02/16/15 02:28 PM
02/16/15 02:28 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Very Nice! For the RacePak there is a formula to input into the software to program the IQ3 to get a speedo signal from the transmission if it has an electronic output. You have to wire the electronic output on the trans to a USM box and then input a value into the software. The formula for the value or "factor" as the RacePak guys call it is: tire height x 3.14 ÷ 12 ÷ 5280 ÷ rear gear ratio x 60 This is handy to have because the GPS speedo does not always connect when you need it or if you are in cities or tunnels The IQ3 will at times freeze up but I just reset mine on and off and it works fine
[Re: RylisPro]
#1592981
02/16/15 02:57 PM
02/16/15 02:57 PM
Posts: 256 USA
Consulier
USA
This is handy to have because the GPS speedo does not always connect when you need it or if you are in cities or tunnels.
Yeah, it's setup with the GPS pickup in the back window now. I'll see how it goes. I have the pieces to use the pickup in the trans if I want to go that route later.
I'm looking forward to the lap times and such in the Racepak. So glad I went with that instead of standard gauges. It's just so compact and seems pretty easy to deal with.
[Re: RylisPro]
#1592983
02/16/15 03:42 PM
02/16/15 03:42 PM
Uhcoog1
Houston Tx
The car looks great and sounds great! Getting close!
Couple questions: Are ya'll logging / monitoring brake pressure? Did ya'll cut down the front bumper to get it closer to the body on the sides?
Once again - looks and sounds awesome. Can't wait to see it running.
[Re: RylisPro]
#1592984
02/16/15 03:54 PM
02/16/15 03:54 PM
Posts: 256 USA
Consulier
USA
Cool seats by the way! Although I am surprised why you didn't go with a halo style seat to offer extra protection especially since you have a cage?
No Halo seats allowed at the 'Ring on Tourist days. I've got a Halo Sparco if I need to swap it in for anything serious. I had them put the center net in just in case those become required with Halo seats later.
Also I would recommend to install a sturdy back brace to your driver seat that ties to the horizontal bar right behind it. Makes the seating position soo much stiffer!
I've never had an issue with seats moving around too much. I'm ok with it for the moment.
[Re: Uhcoog1]
#1592985
02/16/15 04:02 PM
02/16/15 04:02 PM
Posts: 256 USA
Consulier
USA
No, haven't even ventured down that path yet.
When it gets to the body shop we'll fiddle with the bumper mods.
For 2015, other than putting a fiberglass bumper on the rear, there will probably be little to no work done on the interior finishing, or the body work. I'm not going to lose another season to making it look pretty.
[Re: Consulier]
#1592986
02/16/15 04:13 PM
02/16/15 04:13 PM
72Swinger
Nebraska
Awesome! Like the trunk firewall, oh and every damn thing else too....
[Re: Uhcoog1]
#1592988
02/16/15 09:23 PM
02/16/15 09:23 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
Love the car...sounds great as well.
I was curious as to why those lines to and from the master cylinder had to be flexible? I suppose I can understand the ones from the reservoir but not the others. Seems like hard plumbing would have worked fine and had less volume consumption.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Uhcoog1]
#1592989
02/16/15 09:43 PM
02/16/15 09:43 PM
Posts: 256 USA
Consulier
USA
There is what looks like a honeywell type pressure sensor in the brake line. Is that something else? ha maybe I need a tutorial on which master cylinder is which.
Brake light pressure switch. Has Tilton pedals, it was easier than fabbing a standard switch mount.
[Re: goldduster318]
#1592990
02/16/15 09:57 PM
02/16/15 09:57 PM
Posts: 256 USA
Consulier
USA
Because they called the plumbing guy that does all the Cup and Indy car plumbing, so he did it just like those cars. Unfortunately no one asked how much they would be before he made them. My kids found out when I cancelled Christmas to pay for my brake lines...
Sometimes things just get done on these builds and that's the way it goes. When it's at a shop, discussing it costs money, so not every decision is completely reviewed. Some just happen...
And no, I'm not bitter or complaining... it is what it is.
[Re: Consulier]
#1592991
02/17/15 12:09 AM
02/17/15 12:09 AM
Posts: 801 central CT
cudazappa
central CT
Looks and sounds great! Makes me want to build up a gen III hemi for my car!
1971 Challenger
[Re: 68cuda440]
#1592993
02/17/15 10:55 AM
02/17/15 10:55 AM
Posts: 256 USA
Consulier
USA
Quick, drive it and get it out on the track before scope creep sets in...
Scope creep set in many months ago...
[Re: Consulier]
#1592994
02/17/15 11:35 PM
02/17/15 11:35 PM
Posts: 240 Plano, Texas
68cuda440
Plano, Texas
OK... goes something like this. Driver 1968 Barracuda, referred to by some of my friends as "Pro Patina". Car has what is left of the GG1 Forest Green that was applied in May of 1968 in Hamtramck, Michigan. I have owned the car since 1988 and it is a reformed street racer. 440 with ported iron heads + 727 with a Coan converter, 3.90 gears and a 16 gallon plastic gas tank in the trunk.
The wiring harness was a mess. Decided to do something about it. Hate the Jazz Fuel Cell, it has to go. Then, a few other things and, it would be a total pain to do all this work, then pull it apart again to paint it a year later - so we dove in. Nine months later it is at the body shop. Might as well convert it to a stick. Has to be OD, has to be able to handle 600+hp... T-56 Magnum conversion. Then, stumble across a must have intake manifold that I always wanted... and of course it needs to be EFI... do not want to cut the intake to fit the iron heads... time for aluminum heads... and it needs a hood that clears the intake...
Let's just say at least now it is in the assembly stage.
Before picture:
Michael
1968 Barracuda Notchback Coupe
440 EFI 6-pack, T56 Magnum 6-spd
[Re: 68cuda440]
#1592996
02/17/15 11:38 PM
02/17/15 11:38 PM
68cuda440
Plano, Texas
And traded the 325 drag radials and 165R15 fronts for RT615k 295/40-18 rears and 255/40-18 fronts and some sizable brakes to go along with the suspension upgrades. Car now:
Michael
[Re: 68cuda440]
#1592997
02/17/15 11:42 PM
02/17/15 11:42 PM
68cuda440
Plano, Texas
Got to love scope creep. Sorry about the "hijack" back to the regular scheduled program. Engine now:
[Re: Dan@Hotchkis]
#1880223
07/28/15 06:35 PM
07/28/15 06:35 PM
Posts: 351 Spokane, WA
48Heap
Spokane, WA
What are the headlights out of?
15 Chrysler 200S 3.6 15 Challenger R/T 6M STP 74 Duster 360 -> original 4 speed car
a.k.a. DionR
[Re: 48Heap]
#1881229
07/29/15 11:47 PM
07/29/15 11:47 PM
Posts: 256 USA
Consulier
USA
What are the headlights out of? Jeep Wrangler
[Re: Consulier]
#1881471
07/30/15 01:17 PM
07/30/15 01:17 PM
48Heap
Spokane, WA
What are the headlights out of? Jeep Wrangler That's what I Was guessing but wasn't sure. Thanks!
a.k.a. DionR
[Re: Dan@Hotchkis]
#2353692
08/14/17 04:15 PM
08/14/17 04:15 PM
DemonDuster
Whatever happened to this deal ? ? ?
[Re: Dan@Hotchkis]
#2362371
08/30/17 03:44 PM
08/30/17 03:44 PM
67autocross
Manitoba Canada
Did they ever show how the windshield would be installed in the car? The way they welded the cage to the pillars would not allow the factory rubber seal to fit from what I can see.
[Re: Dan@Hotchkis]
#2363106
08/31/17 10:46 PM
08/31/17 10:46 PM
72Swinger
Nebraska
The windshield can still fit fine.
[Re: Dan@Hotchkis]
#2363523
09/01/17 03:20 PM
09/01/17 03:20 PM
67autocross
Manitoba Canada
I just did a windshield in my car and I don't see how you could use the factory gasket the way they welded those cage braces , of course you could just use urethane and stick the glass in like a new car.
[Re: AndyF]
#2367279
09/08/17 12:59 AM
09/08/17 12:59 AM
Posts: 256 USA
Consulier
USA
It would be interesting to see what happened to the car. Seems like something happened to derail the project. Not that that ever happens to any of my projects! It's sitting in my garage on jackstands with the trans out of it. Needs a clutch and put back together. It's been sitting that way for 2 years now. I told them when it was being built that if it got out of hand and wasn't finished when I got it back it would just sit. It got out of hand, clutch was installed wrong and now it just sits. I've been spending my spare time with other programs now, so I have no idea when I'll get to this again. I really should just drop it off somewhere and have it finished... again.
[Re: Dan@Hotchkis]
#2367300
09/08/17 01:51 AM
09/08/17 01:51 AM
67autocross
Manitoba Canada
Thanks for the update, I was hoping you would make it to Targa Newfoundland with it ...that car would be perfect for that event.
[Re: Consulier]
#2367384
09/08/17 11:29 AM
09/08/17 11:29 AM
Posts: 270 Mountain View, CA
68rrunner
Mountain View, CA
It would be interesting to see what happened to the car. Seems like something happened to derail the project. Not that that ever happens to any of my projects! It's sitting in my garage on jackstands with the trans out of it. Needs a clutch and put back together. It's been sitting that way for 2 years now. I told them when it was being built that if it got out of hand and wasn't finished when I got it back it would just sit. It got out of hand, clutch was installed wrong and now it just sits. I've been spending my spare time with other programs now, so I have no idea when I'll get to this again. I really should just drop it off somewhere and have it finished... again. Still waiting for it to show up
[Re: 68rrunner]
#2367396
09/08/17 11:56 AM
09/08/17 11:56 AM
Posts: 256 USA
Consulier
USA
Still waiting for it to show up Why don't you just fly in for a few days and knock it out here? That's a lot cheaper than me shipping it across the country. Plus, if I have to actually package it all up to ship it, I'm sure it will just continue to sit. Zero time, crazier stuff to work on at the moment.
[Re: 67autocross]
#2367399
09/08/17 12:00 PM
09/08/17 12:00 PM
Posts: 256 USA
Consulier
USA
Thanks for the update, I was hoping you would make it to Targa Newfoundland with it ...that car would be perfect for that event. Life has had some interesting turns with amazing opportunities for me the last couple years. I built the Dart to run all the events, that I've currently been running... with other peoples cars. Weird how it has worked out. One of the reasons it's still sitting is because I've not needed it to run events. I've had other stuff available. Good for me, bad for the Dart, unfortunately.
[Re: Dan@Hotchkis]
#2367427
09/08/17 01:31 PM
09/08/17 01:31 PM
Supercuda
About to go away
About to go away
up yours
If your luck is anything like mine, when you need the Dart it won't be ready because you didn't have time to take advantage of it's down time to get it ready because you were busy do what you do.
It's a catch 22
[Re: Dan@Hotchkis]
#2367488
09/08/17 03:03 PM
09/08/17 03:03 PM
67autocross
Manitoba Canada
Sometimes you end up doing things you never expect... I'm loading up one of my cars and leaving to Drag Week today... and I'm not even really interested in drag racing that much.
[Re: Dan@Hotchkis]
#2367520
09/08/17 04:20 PM
09/08/17 04:20 PM
Supercuda
About to go away
About to go away
up yours
Probably be a good idea to keep the shiny side up
