Page 5 of 8 < 1 2 3 4 5 6 7 8 >
#1592950 - 09/27/14 06:22 PM Re: Hotchkis 76 Dart Build [Re: Consulier]
RichV Offline
Loc: Seattle WA
http://www.slantsix.org/forum/viewtopic....36d3a48960c8886
If anyone knows how to get a column shift to work with a four speed in an early a body and still have reverse, post it up. I want one for an upcoming project after the Dart.
Here's some info on this subject.
#1592951 - 09/28/14 12:13 PM Re: Hotchkis 76 Dart Build [Re: RichV]
ns1aar Offline
Loc: ontario calif
Some early 60s chevy vans had a 4sp column
#1592952 - 11/17/14 05:23 PM Re: Hotchkis 76 Dart Build [Re: dangina]
Consulier Offline
Loc: USA
Some stuff I added to the thread on FABO today...
Some sheet metal work on the doors...
Thanks,
Kevin Wesley
#1592953 - 11/17/14 05:28 PM Re: Hotchkis 76 Dart Build [Re: Consulier]
Consulier Offline
Loc: USA
Bulkhead on the Hotwire Harness... yes this will all get wrapped when finalized.
Brake Bias mount...
Leaf Spring front hanger support...
Thanks,
Kevin Wesley
#1592954 - 11/17/14 06:21 PM Re: Hotchkis 76 Dart Build [Re: Consulier]
RylisPro Online   laugh2
Loc: NorCal
Very nice!
/Drive
Instagram: @rylispro
YouTube:RylisPro
www.rylispro.com
925-214-9192
Tremec T56 Magnums & Quick Time bellhousings
Lightened Billet Steel Flywheels
#1592955 - 11/21/14 10:50 AM Re: Hotchkis 76 Dart Build [Re: RylisPro]
70blackfish Offline
Loc: SO. CAL.
VERY NICE WORK!!!!!
10.30 @132mph
496 big block, Solid Roller, Ported Victor Heads.
8 inch converter, pro trans. Cal-tracs.
dana 60 4.10 w/locker.
Street Car. SOLD...........
#1592956 - 11/21/14 12:05 PM Re: Hotchkis 76 Dart Build [Re: 70blackfish]
NV69B7RR Online   content
Loc: Reno, Nevada
Beautiful! The level of fab work on your car is amazing! More pictures please!!
68 AMX track car
72 Demon 340
71 Duster 340 Resto http://board.moparts.org/ubbthreads/show...part=1&vc=1
#1592957 - 01/12/15 11:28 AM Re: Hotchkis 76 Dart Build [Re: NV69B7RR]
Consulier Offline
Loc: USA
Wheels are on and the car is on it's suspension at the moment...
I went cheap on the wheels to start with since I'm not sure where this will end up for tire size. They will always make good rain wheels. Got them from American Muscle. They are 18x10 at 24mm and weigh 20.9 lbs for $210 each. Didn't think that was too bad for a wheel of that weight and size.
Thanks,
Kevin Wesley
#1592958 - 01/12/15 11:45 AM Re: Hotchkis 76 Dart Build [Re: Consulier]
Consulier Offline
Loc: USA
Some more fab shots and details...
Wiring with OBDII Port that will be used for the RacePak.
Dual Battery switch and isolator that is used for the FIA legal kill switch. There is a button on the cowl and on the dash that is used to kill the car. Details on their site Armtech .
At least I have a piece of Carbon Fiber on the car...
Racepak and Dash layout
Fuel Cell and pump leads
Dual pumps mounted in a surge tank. Switch on the dash to flip between if one fails.
Remote oil filter mount
Thanks,
Kevin Wesley
#1592959 - 01/12/15 02:02 PM Re: Hotchkis 76 Dart Build [Re: Consulier]
Loc: NorCal
I highly recommend getting the clear cover for the IQ3
250-DS-IQ3CVR
The one without a flange
/Drive
YouTube:RylisPro
www.rylispro.com
925-214-9192
#1592960 - 01/12/15 06:56 PM Re: Hotchkis 76 Dart Build [Re: RylisPro]
72Swinger Offline
Loc: Nebraska
Love the build, helps me make up my mind on a lot of nick nack stuff. I will probably resign myself to nixing the glove box compartment for fuse box access and just have a tray in there for my registration and insurance to sit.
Mopar to the bone!!!
#1592961 - 01/12/15 11:28 PM Re: Hotchkis 76 Dart Build [Re: Consulier]
MuuMuu101 Offline
I got lucky at Woodward!
Loc: Covina, Ca
So you can rear mount these calipers... Maybe my rough and dirty approximation of an alignment was a little funky.
68 Dart GT Project Thread: Linky!
#1592962 - 01/12/15 11:51 PM Re: Hotchkis 76 Dart Build [Re: MuuMuu101]
autoxcuda Offline
Loc: So Cal
But what UCA's is he using? And what diameter rotors and what/who's brake setup?
Spring Fling XXII
April 14 & 15, 2018
Woodley Park, Van Nuys CA
www.cpwclub.com
700 show cars, 300+ swap, manf. midways
Malibu Cruise, Track Day, Cruise-In
Free Spectator Admission!
#1592963 - 01/12/15 11:58 PM Re: Hotchkis 76 Dart Build [Re: autoxcuda]
MuuMuu101 Offline
Loc: Covina, Ca
He's using Dr Diff's, I asked him on FABO. I'd assume he's using Hotchkis' UCA's as they're building his car.
#1592964 - 01/13/15 12:01 AM Re: Hotchkis 76 Dart Build [Re: autoxcuda]
DoctorDiff Offline
Loc: Polson, MT
That is my Stage 4 brake kit with Baer rotors and a slightly shorter caliper. I don't think it will clear the Hotchkis UCA, when mounted toward the rear, however.
Contact info
#1592965 - 01/13/15 12:13 AM Re: Hotchkis 76 Dart Build [Re: DoctorDiff]
MuuMuu101 Offline
Loc: Covina, Ca
My experience proves this to be true... Granted my alignment was pretty rough and dirty, the bleeder was literally sitting right underneath the UCA at full droop.
#1592966 - 01/13/15 12:29 AM Re: Hotchkis 76 Dart Build [Re: MuuMuu101]
Dan@Hotchkis Offline
Loc: Santa Fe Springs, CA
I'll call the HPE guys tomorrow and get the skinny.
#1592967 - 01/13/15 12:54 AM Re: Hotchkis 76 Dart Build [Re: DoctorDiff]
autoxcuda Offline
Loc: So Cal
Are those 13" rotors or 14"?
Spring Fling XXII
April 14 & 15, 2018
www.cpwclub.com
#1592968 - 01/13/15 01:03 AM Re: Hotchkis 76 Dart Build [Re: autoxcuda]
MuuMuu101 Offline
Loc: Covina, Ca
It looks like the same kit as mine with 13" rotors. If they were 14" they'd fill up the wheel almost completely. Have you ever seen OzHemi's setup with 14" rotors on an 18" wheel?
#1592969 - 01/13/15 07:37 AM Re: Hotchkis 76 Dart Build [Re: autoxcuda]
Consulier Offline
Loc: USA
13", they say it clears, I've not been there to see it. If for some reason it doesn't, then they'll flip them around, or whittle up a new adapter to rotate the caliper down to clear.
Not way up there on my worry list at the moment...
Thanks,
Kevin Wesley
25,247 Registered Members
188,851 Topics
...the cool Dads at daycare
by GoodysGotaCuda
04/20/18 08:50 PM
Marine 440 distributor restorers?
by gss
04/20/18 07:55 PM
O/T any forklift mechanics or know of anyone who is?
by mod381
04/20/18 07:52 PM
71 CUDA 340
by CARMAN
04/20/18 07:24 PM
