Re: BFGoodrich P275/50R15 replacements??
[Re: rabid scott]
#159182
12/04/08 04:38 PM
12/04/08 04:38 PM
Posts: 2,826 NY usa
540challenger
NY usa
I have 295-50-15s on 15x8.5 Cragar SSs on the back of my Challenger right now, no rubbing with me in it.
What backspacing you using.
Also is this the stock rear suspension or moved in leaf etc..
[Re: 540challenger]
#159183
12/04/08 04:40 PM
12/04/08 04:40 PM
Posts: 1,884 Tracy CA
rabid scott
"You're Where?"
"You're Where?"
Tracy CA
Stone stock rear suspension setup, except I added a factory swaybar and flipped the front spring hangers to lower it a little.
I don't have a clue what the B/S is, though. I'll try to measure tonight.
[Re: GTXKen]
#159184
12/04/08 06:03 PM
12/04/08 06:03 PM
Posts: 6,445 Missouri
68KillerBee
Missouri
I'd really like to put those on the back of my 70 b-body on either 8.5 or 10 inch rims but I'm afraid they would rub on my car, I need to find someone in the area that that has them so I could at least try them. Maybe the original poster coiuld do the same?
295/50/15's : rubbing around hard, hard cornering. 15X10 5.5 backspace. i would try to get less of a backspacing though. very close to the leaf springs.
[Re: GTXKen]
#159185
12/04/08 08:01 PM
12/04/08 08:01 PM
Posts: 2,432 NorCal
RylisPro
NorCal
Maybe the original poster could do the same?
I was ready to buy 295/50R-15's on the spot and keep the 275/60R-15's as spares or sell them but the problem is they just aren't making them anymore. I guess they are phasing out 50 series tires because 60 series provide better fuel economy since I have noticed less RPM's at crusing speed. 60 series tires still suck and will never buy them again
oh well I guess I just gotta do more burn outs so that my tires will sit shorter
[Re: DPelletier]
#159186
12/04/08 09:20 PM
12/04/08 09:20 PM
DaytonaTurbo
Manitoba, Canada
I got my 275/60R-15's mounted and to be honest they look awful, too tall and narrow
Never heard anyone refer to 275/60 15's as tall or narrow!
Too tall??? My 275/60's only measure 27" in diameter. If that's too tall for you, maybe you should pick up some donut spares from the junkyard and run those. I agree they are too narrow. Don't have that ballsy look to them.
My brother has a set of 275's on 7" wide buick rallye wheels. Looks awesome, but the tire wears poorly since the rim is really too narrow for that wide of a tire.
I've ran that size on 7" rims for 5 years on the same set of tires and they've been wearing just as flat and level as any other tire...
[Re: 68KillerBee]
#159189
12/05/08 12:54 PM
12/05/08 12:54 PM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
Can I have your wheels and tires?
Seriously thogh do they rub on the leaf springs and if you change the back spacing are you confident that they won't rub on the quater lip?
[Re: RylisPro]
#159190
12/05/08 02:14 PM
12/05/08 02:14 PM
Posts: 502 North Texas
1AARCUDA
North Texas
I have had very goodluck with this brand, They last forever, don't dry rot and are actual size. not that smaller size some tire brands sell. I have 295/50/15 on the back of my 70 Bee and they look great. And thier called Stingers too! Like a Bee Heres a link http://www.vulcantire.com/cgi-bin/tiresearch.cgi?stock=4015&f=stingergts_t.htm
1970 AAR CUDA
1970 Super Bee 383 Auto
1969 Super Bee 383 4Spd
1968 Satellite 500 Stroker
1986 Shelby GLHS
1970 Coronet 500 383 Auto
1996 Indy Pace Truck
1998 Dakota R/T 408 Stroker
[Re: 68KillerBee]
#159191
12/06/08 12:07 AM
12/06/08 12:07 AM
Posts: 797 WA
pro451bee
WA
[Re: pro451bee]
#159192
12/06/08 12:09 AM
12/06/08 12:09 AM
Posts: 797 WA
pro451bee
WA
[Re: GTXKen]
#159193
12/06/08 09:46 PM
12/06/08 09:46 PM
68KillerBee
Missouri
That actually is a really good question. I really don't think they would, but I will check in two weeks when i get home. I'm away at college right now. the fronts are 14x6 i believe but i don't know the tire size. i love how it all looks on my car. stance is awesome
[Re: GTXKen]
#159195
12/07/08 04:50 AM
12/07/08 04:50 AM
Posts: 27,453 So Cal
autoxcuda
So Cal
68-70 Dodge B-bodies have different leaf to quarter panel distances than the 68-70 Plymouths.
[Re: autoxcuda]
#159197
12/07/08 10:51 PM
12/07/08 10:51 PM
68KillerBee
Missouri
i'll check to see what my dad just put on his 68 gtx. i believe his are 275/60/15 on 15 by 8 mag 500. wont be home til next weekend. also if im really really bored i'll put mine on his and see how they fit. my guess is plymouths have a smaller distance, but am not sure.
[Re: 68KillerBee]
#159198
12/08/08 01:00 AM
12/08/08 01:00 AM
autoxcuda
So Cal
Yes Charger and Coronets have more room. The Plymouths are more slab sided. Really apparent if you look at a bare 68-70 Charger door compare to a 68-70 Plymouth Door.
[Re: Alikazam]
#159199
12/08/08 05:42 PM
12/08/08 05:42 PM
Posts: 5,387 Pikes Peak Country
TC@HP2
Pikes Peak Country
You guys checked out the latest Street Radial tires from Mickey Thompson? a 275/50R15 would be a 26" tall tire, about 11" wide. so a 26" x 10" or x 12" on a 15" wheels would work in Mickey T's. The tread pattern looks great too!
That's what I was thinking. The M/Ts have a better tread pattern and compound compared to a TA and they have a higher speed rating too.
[Re: RylisPro]
#159201
12/11/08 02:03 PM
12/11/08 02:03 PM
Posts: 2,432 NorCal
RylisPro
NorCal
here are pics of 275/60's on my car the old 275/50's used to be wide enough to fill out the rim now there is a big gap I should get my Nitto Drag Radials either tommorrow or next week when I get them I'll post pics
