Steel B/RB distr gear from Crane - Anybody used one? #1584972
02/27/14 02:44 PM
02/27/14 02:44 PM
Alabama
W
WarEagle1 Offline OP
W
Alabama
I want to use the Crane 66970-1 coated steel distributor gear with my hyd roller, rather than bronze. They come without the shaft. Has anyone assembled a shaft to one? Which shaft do you recommend buying? I'll have to buy a complete intermediate shaft and disassemble it, I guess. Let me know. Havent seen this discussed in a couple of yrs. Thanks.
Re: Steel B/RB distr gear from Crane - Anybody used one? [Re: WarEagle1] #1584973
02/27/14 09:08 PM
02/27/14 09:08 PM
I'd wanna a shaft that has a good rep for minimal wear on the hex end. Here's a BTT for ya
Re: Steel B/RB distr gear from Crane - Anybody used one? [Re: WarEagle1] #1584974
02/27/14 09:49 PM
02/27/14 09:49 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Hughes sells them separately. I'd want a hardened tip like this one.
http://www.hughesengines.com/Index/produ...mp;partid=28019
Re: Steel B/RB distr gear from Crane - Anybody used one? [Re: 80fbody] #1584975
02/27/14 10:47 PM
02/27/14 10:47 PM
League City, TX
BlueGhost Offline
BlueGhost  Offline
League City, TX
Huges also sells the coated gear and shaft already assembled.
OIL PUMP DRIVE SHAFT W/COATED STEEL GEAR
1958 Plymouth Suburban
Re: Steel B/RB distr gear from Crane - Anybody used one? [Re: BlueGhost] #1584976
02/28/14 02:40 AM
02/28/14 02:40 AM
Alabama
W
W
Alabama
Excellent! I have the gear so I'll order the bare shaft from Hughes. Thanks guys.
Re: Steel B/RB distr gear from Crane - Anybody used one? [Re: WarEagle1] #1584977
02/28/14 05:48 AM
02/28/14 05:48 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
High volume, or high pressure oil pumps are not recommended as they accelerate wear on the cam gear and oil pump drive gear.
Re: Steel B/RB distr gear from Crane - Anybody used one? [Re: JohnRR] #1584978
02/28/14 11:03 AM
02/28/14 11:03 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
I bought the Crane composite gear but the instructions that came with it said it should not be used on a cam that has already been run with a bronze gear.
Re: Steel B/RB distr gear from Crane - Anybody used one? [Re: TooMany62s] #1584979
02/28/14 01:41 PM
02/28/14 01:41 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I'm guessing with respect to the Crane gear, they're concerned about existing brass particles wearing thru the coating. If you have the cam out & scrubbed the teeth clean with scotchbrite, etc it would be fine as the brass gear shouldn't have worn the harder cam gear. I'm sure this has been covered but maybe Chase would chime in on this.
Re: Steel B/RB distr gear from Crane - Anybody used one? [Re: 80fbody] #1584980
02/28/14 02:17 PM
02/28/14 02:17 PM
Alabama
W
W
Alabama
Everything is new in my case. Still wondered about John's quote above regarding HV and HP oil pumps. I think I saw it in Crane's catalog too. Can't imagine a steel gear not being able to handle a HV pump (???)
Re: Steel B/RB distr gear from Crane - Anybody used one? [Re: WarEagle1] #1584981
02/28/14 02:51 PM
02/28/14 02:51 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
HV pumps apply alot of pressure to the gears basically due to the higher resistance to turn the larger HV pump gears. This is even worse with thicker oils. I would guess it just accelerates the coating wear.
Re: Steel B/RB distr gear from Crane - Anybody used one? [Re: 80fbody] #1584982
03/01/14 05:30 PM
03/01/14 05:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
