Pacifica engine removal questions #1583361
02/24/14 02:37 PM
02/24/14 02:37 PM
Cruising!
Q
QuickDodge Offline OP
Q
Cruising!
I've read (on another website) that the recommended way to remove an engine from a Pacifica is to take it out the bottom. I don't have access to a lift. Can the engine be removed by pulling the front clip instead?
The car in question is a 2005 Pacifica with the 3.5 engine.
Edit: How difficult is it to swap one of these engines.
Re: Pacifica engine removal questions [Re: QuickDodge] #1583362
02/25/14 02:10 AM
02/25/14 02:10 AM
massachusetts
X
xs29l9g Offline
xs29l9g  Offline
X
massachusetts
just did one,actually twice. yes u can get engine out the top. pull bumper cover and beam,headlites,rad and condenser. pull plenum. its tight, but it does come out. mine was also a 2005,3.5,fwd pacifica. good luck.
