Which rear leave springs would you get?
#1582983
02/23/14 09:52 PM
02/23/14 09:52 PM
Posts: 12,017 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The stock rear springs on my 70 Cuda are sagging and pretty well played out. I run Cal-Tracs on them, and the car is street with an occasional strip shoot-out. It runs 6.9s with a 1.5 60' when I strap on the drag radials. I normally run street tires on the street.
I think I will put new rear springs on it. So would you put the Cal-trac monos on or would you put some stock multi-leaves on? If I go multis, I would use a light 318 style of spring like it has now so that they wouldn't work against the Cal-tracs.
I would appreciate your thoughts. Thanks!
Master, again and still
Re: Which rear leave springs would you get?
[Re: DaveRS23]
#1582985
02/23/14 10:17 PM
02/23/14 10:17 PM
RapidRobert
For a normal (non drag) app there's been alot of good reviews of ESPO springs picking the ones for your vehicle with 1" addit'l ride height over stock.
[Re: 5spdcuda]
#1582986
02/23/14 10:20 PM
02/23/14 10:20 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I thought about that, too. The last time I had springs re-arched, it was about $100 a spring. Does that still sound about right? I just wasn't sure how long 40+ year old springs would retain their new arch.
[Re: DaveRS23]
#1582988
02/23/14 10:29 PM
02/23/14 10:29 PM
RapidRobert
For $200 I think I'd dissassemble em myself with 2 clamps & have the main leaf rearched or just add some leafs as is but 2 bills ain't terribly out of line. No exp how long they last & they may very well last forever. All I can add is I bought a 74 duster from a guy in Iowa who used it to haul blocks etc across country to swap meets & it had at least 8 added leafs per side (I ain't kidding) & it was several inches above normal height & every time I hit a pebble my head hit the dome light so they had to go (I still have em). Not sure if he rearched just the main leaf or some of the leafs or no rearching & just added em (my guess he just added leafs)
[Re: DaveRS23]
#1582991
02/24/14 08:17 PM
02/24/14 08:17 PM
Posts: 5,788 Hamilton, Ontario Canada
Magnum
The Cal trac monos would save you some weight.
You don't need the strong front segment for axle control.
[Re: Magnum]
#1582992
02/24/14 10:42 PM
02/24/14 10:42 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Those are the two primary reasons that the monos were on the list. They are more money, I don't know what the ride would be like compared to the stock springs, and I don't know what the long term durability will be like.
I am going to shop them this weekend at Indy. Then I think I will price new springs from Eaton. And I am considering a rebuild of my current springs.
Not sure which is the best route, just to be honest. Performance vs. longevity vs. cost.
All will work, just which is the best combo of the above criteria.
Decisions, decisions.
[Re: 383man]
#1582994
02/25/14 12:47 PM
02/25/14 12:47 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Valid point. I just wonder what their long term durability is? I guess it will be some time before we really know, but are there any settling issues with them yet?
Oh, and they are expensive.
[Re: DaveRS23]
#1582995
02/25/14 03:21 PM
02/25/14 03:21 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
You might ask over in the race section as I know alot of them run the Cal Tracs and mono spring on their street/strip cars and they could tell you how they work on the street for them. Myself I just use SS springs on my 63. One day I might try Cal Tracs but I will go with the mono spring if I ever do try the Cal Tracs. Ron
[Re: 383man]
#1582996
02/25/14 10:03 PM
02/25/14 10:03 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I have had SS springs on several of my cars over the years. All my cars see street duty and the SS springs make the car ride stiff as he)). The wife doesn't even want to get in.
Nowadays, my cars don't have to ride like a 1 ton dually in order to pull a 1.5 60'.
