homemade tool for V/P checking with out removing spring #15799
07/25/05 05:06 PM
07/25/05 05:06 PM
USA
max Offline OP
super gas
max  Offline OP
super gas
USA
here is a photo of a homemade valve to piston checking tool that i came up with.
it is for use with a hyd cam and stock rockers with light to moderate size springs and you don't have to remove the valve springs to use the tool.
just mount it in place of your stock rocker arm shaft and use a pry bar to force the spring down and use a dial indicator on the spring retainer to measure the distance of travel as the valve hits the top of the piston or when you get coil bind.
Re: homemade tool for V/P checking with out removing spring [Re: max] #15800
07/25/05 05:10 PM
07/25/05 05:10 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Cool idea..I like it..
Re: homemade tool for V/P checking with out removing spring [Re: moper] #15801
07/25/05 05:21 PM
07/25/05 05:21 PM
USA
max Offline OP
super gas
max  Offline OP
super gas
USA
thanks, i posted it thinking it might be of some help to others that are looking for an alternative to taking off the valve springs.
