Re: isolating vibration
[Re: bonefish]
#1578873
02/14/14 12:02 PM
02/14/14 12:02 PM
Posts: 7,506 Az
Crizila
Az
Vibrations like that ( narrow rpm band and go away on ether side ) are often exhaust system related. I'd start there.
Fastest 300
[Re: bonefish]
#1578875
02/14/14 02:20 PM
02/14/14 02:20 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Actually, now that ive got my AFR alot better i can actually feel the vibe at cruz.it pulses.i,m wondering is what im feeling is a drone or a vibe.its not horrible but you can feel it.
Was it super lean on A/F... might be detonation
[Re: bonefish]
#1578877
02/14/14 02:44 PM
02/14/14 02:44 PM
MR_P_BODY
my AFR meter reads 14. to 14.8 at cruz if i give it a little gas it will read about 12.to 13 till it levels out and you still feel the slight vibe at the richer AFR.
You should be fine there..... lets go back to the beginning of the build ... is the engine balanced, what balancer, is it a stick or auto, if auto what flex plate... give us a little info
[Re: bonefish]
#1578879
02/14/14 03:04 PM
02/14/14 03:04 PM
MR_P_BODY
A ATI is a quality balancer but have you checked the zero to TDC... is anything loose(flex plate, conv), have you checked the flex plate for a crack... I had one crack years ago that the buzz gave it a small vibration
