Page 3 of 22 1 2 3 4 5 21 22
Re: Let the Hemi swap begin [Re: haddixj] #1577379
02/22/14 04:24 AM
02/22/14 04:24 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I wonder if EFI source would build a system out of the new MS pro? That unit is designed to be able to get wet and mount in the engine compartment. I really like the kit form of MS that has come out. That should make it alot more popular with people
The MS3 Pro is over hyped IMHO. It's more expensive and doesn't have the built in coil drivers. Yes, it can get wet but thats about the only upside.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Let the Hemi swap begin [Re: AlexP] #1577380
02/22/14 01:56 PM
02/22/14 01:56 PM
CO
Twisted Offline
Twisted  Offline
CO
The 3g Hemi is built around Speed Density. I'll be using a factory sensor in the back of my 6.1 intake.
The ECU will make judgements based on the MAP sensor and the intake air temperature sensor. Here is a breakdown of the features on this box.
MegaSquirt MS3
Gen3 Hemi Gold Box Standard features
· Controllers are factory configured for your Gen3 Hemi engine
· Start up program factory installed
· USB, RS232 and CAN communication
· Onboard SD card for Data logging
· 8 High Impedance injector drivers
· 8 High current ignition outputs. No additional boxes or coil drivers needed.
· Fuel pump output
· Fan output
· Stepper and PWM Idle Air Control outputs
· 2 Nitrous outputs
· Variable Valve timing output
· 12 volt tach output
· Two Step Input
· 2 Oxygen sensor inputs
· 2 Knock sensor inputs
· Nitrous input
· Data Log switch
· Dual table switch
· 3 additional general purpose inputs (on/off or frequency)
· 1 additional analog input
Does the VVT driver on this properly control the cam phaser on '09 up engines or is it pretty much just fluff? That would make this a very good prospect in that area. If not maybe it could be used for MDS since that functions similar to VVT. Not that I am concerned with that.
Thank you
Aaron
69 Dodge Polara 4DHT
70 Plymouth Duster
03 Dodge Neon R/T
05 Dodge Grand Caravan SXT
Re: Let the Hemi swap begin [Re: AlexP] #1577381
02/22/14 03:33 PM
02/22/14 03:33 PM
Santa Fe Springs, CA
Dan@Hotchkis Offline
I'm not one of those people to care about having ford or chevy parts on a mopar, but I can't see why someone would spend $2000 to have LS1 stuff on their car when there are better and cheaper options out there...unless you identify with the reasons I stated above.
Holy smokes, I didn't know that guy was asking that much for the kit. I was going to call him Monday for pricing info.
Re: Let the Hemi swap begin [Re: AlexP] #1577382
02/22/14 03:38 PM
02/22/14 03:38 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Spray Plastidip on it and viola! Water proof...
Mopar to the bone!!!
Re: Let the Hemi swap begin [Re: Dan@Hotchkis] #1577383
02/22/14 04:53 PM
02/22/14 04:53 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I don't feel that using a factory ecu and designing a reluctor wheel justifies that price. Just my .02.
Re: Let the Hemi swap begin [Re: Twisted] #1577384
02/23/14 05:47 PM
02/23/14 05:47 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
The box has the capability to control VVT, etc, but AFAIK, no one has done that or even tried to with a Hemi yet.
same with the knock control...
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Let the Hemi swap begin [Re: AlexP] #1577385
02/23/14 10:33 PM
02/23/14 10:33 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I've been dying to update progress on my swap from a Big block to a 3G Hemi.
I had a perfectly fine running 69 HP 383 with 915HP heads, a DP4B/650DP, HP Manfiolds and a 4 speed with 3.23's. I drove it like that for about 1000 miles and it bored me. The combo that I thought I wanted and I'd always dreamed about. I didn't like it for the type of driving that I do.
So, I pulled the 383 and parted all my big block stuff on Craigslist and on here. Sold all of it for a fair price and decided that it was time for a new hemi. I was just upset with bent pullies, leaky valve covers and general old car quirks.
I worked from 2006-10 for a shop that worked on and modified the LX Hemi cars, so I know my way around them quite well. I fell in love with the powerplant in a 4700lb station wagon, so my 3600 lb B-body would be ridiculous fast with just a simple head and cam 6.1. I started with just a bare 6.1 block. Literally nothing else at first. I knew about what I wanted, and I had really big dreams at first. I was looking to build a motor that would compliment all the handling stuff that I've done to the car.
-1.24" T bars
-Koni Red Shocks
-AndyF's LCA plates
-Tubular UCA's (Coming off now...)
-New bushings and Poly where I could
-Firm Feel Firmer than stage 3 box from Dick
-11.75" with Firm Feel Carbon Metallic Pads
I ran without sway bars, so a set of fresh leaf springs and F&R Hotchkis or Hellwig sway bars are about all I need to complete the suspension to where it needs to be. All of the above made the car feel amazing, even in it's incomplete state.
I started my motor build parts gathering a few years ago and it all started with a $300 6.1 block that I was going to build a 426 or forged 6.1 out of. I quickly realized that I didn't need that much motor, so after some horsetrading with my friend uhcoog1 (wade) I ended up with a stock bore 6.1 in great shape. I picked up a stock set of 6.1 rods and pistons and started my process of building up a mostly stock 6.1 shortblock. Nothing fancy except for a set of stock rings opened up a little bit to keep the pistons from breaking the ring lands (a common 6.1 issue). Otherwise, the whole motor is stock spec with no after market parts aside from the valve springs (PAC) and the Comp Camshaft.
Here is the motor buid
4.055x3.580 6.1
Stock pistons/new rings
Stock Powdered metal rods with new Chrysler rod bolts (Same as 8.4 viper)
King Bearings
Stock 6.1 Timing set and tensioner
Melling Oil pump
Jeep SRT8 Oil Filter Adapter
Frank Racing 219/231 .585/.585 112LSA
GTP ported 5.7 2009+ Eagle Cylinder heads with PAC 1220 Springs. These are a closed chamber heads and will net 11:1 CR with my stock shortblock. More than do-able with 93 octane all day long
Stock 6.1 Intake Manifold with BBK 80mm tb
SRT4 Stage 1 43lb injectors
Stock 6.1 fuel rail
TTI 1 3/4 Headers to a 2.5" H pipe system with turbo mufflers
Lakewood Bellhousing from a SB
MP/Mcleod Hemi 10.5 Conversion Flywheel
Sachs Diaphragm 10.5 stock clutch
TTI Motor mount brackets with a solid and rubber mount on either side
Mildon Oil Convesion oil pan
It's a bit scary to me how stock and simple this motor is. Nothing fancy at all.
I've just purchased the Megasquirt MS3X kit from Mike @ www.efisource.com as of yesterday and I'm really looking forward to running his system. It is the first kit to come out for a 3g hemi that is a refined harness that is based on megasquirt.
The electronics portion of this build will be a copy of the fuel system that uhcoog1 has on his road race duster. So simple yet it more than makes up for the fact that I'm still running a stock fuel tank. If he can't run out of fuel on a roadcourse, then anyone on here will be fine.
My fuel system will be the following
Carter 4601HP pump (ran both my 383 and 440 with a carb previously)
BCBroncos Accumulator to act as a resivour/surge tank.
Walbro GSL392 Inline pump
Corvette Fuel/Filter Regulator by Wix.
The car already had 1/2" feed and return lines in stainless with a 1/2" stock style pick up that I added a 1/2" return to, so my fuel system is ready for whatever I can throw at it with just a pump change.
Over the next few weeks I'm going to detail my engine build and install for everyone to see.
I'd like to eventually do up a website to help inform people about the process of putting this new style of motor into a classic mopar. I had a cardomain website a long time ago, and I'd like to do it one better.
http://www.cardomain.com/member/themoparkid/
The goal for me is to have a fair weather daily driver that I can hop in and knock out 300 mile day trip while maintaining above average fuel mileage, not smelling like fuel (its a real problem), being able smile from the speed and being able to have a road course worthy classic Mopar.
Here are some already shown pics of my car...
So far, I'm most of the way there.
So us the money for the controller and the fuel system !
How much is this system going to run?
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577386
02/24/14 02:16 PM
02/24/14 02:16 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
What wade said.
Just because it is there, doesn't mean it is compatible with the hemi...yet. There are always expansions looming over the horizon.
And I'm less than $1500 for EFI and fuel system.
The fact that gets me everytime is when someone says they want to save money by going carb on a motor like this.
Even if you have nice carb, the MSD ignition controller is still $800 and then you may or may not have to do anything with your fuel system.
Re: Let the Hemi swap begin [Re: AlexP] #1577387
02/24/14 02:42 PM
02/24/14 02:42 PM
CO
Twisted Offline
Twisted  Offline
CO
Not knocking the system at all. I was just surprised to see it listed on the HEMI specific box as I hadn't heard that anyone figured it out. I hope someone figures it out before I am to that point. I was leaning towards the LS comp only for the fact that if I am 2000 miles away from home and new one is just a junkyard away and a flash from the laptop.
Thank you
Aaron
70 Plymouth Duster
03 Dodge Neon R/T
Re: Let the Hemi swap begin [Re: Twisted] #1577388
02/24/14 04:30 PM
02/24/14 04:30 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
My friend shorted his MS3 box by accident and he had it turned around in about a week with the repair.
You've got a valid point, but I wonder if the ECU they sell for the LS is flashed to be open source and includes softare to tune yourself, or if you still need HP Tuners or EFILive to change things.
Re: Let the Hemi swap begin [Re: AlexP] #1577389
02/24/14 05:00 PM
02/24/14 05:00 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
I wouldn't consider an ECU from a wrecking yard - if the car was in any accident, the ECU will be locked in limp mode, which in our case required a replacement. HP tuner software can't reset it
Re: Let the Hemi swap begin [Re: ntstlgl1970] #1577390
02/24/14 08:43 PM
02/24/14 08:43 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Strange.
We've done several Hemi cars and none of them required ECU replacement.
Perhaps yours took a different kind of hit.
- Stu Harmon
Re: Let the Hemi swap begin [Re: feets] #1577391
02/24/14 09:16 PM
02/24/14 09:16 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Strange.
He is reffering to the LS1 Delphi based EFI kit that Nutter Racing is offering for the 3G Hemi Swap.
I've had static kill one Hemi Ecu, but that was completely the installers fault. Got a good zap and killed the logic that was flashed.
Re: Let the Hemi swap begin [Re: AlexP] #1577392
02/24/14 09:31 PM
02/24/14 09:31 PM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Strange.
What Alex said - was an LS ecu
Re: Let the Hemi swap begin [Re: ntstlgl1970] #1577393
02/25/14 04:33 PM
02/25/14 04:33 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
My cooling system is coming together now.
I'm going to reuse my C-body 440 auto radiator. I purchased a 17" Ford Thunderbird electric fan by Dorman 620-118 for $56 on eBay. It was brand new and only a step down from the Lincoln MK8 fans in terms of CFM. The MK8 is 1500 low and 2700 high. This will be more than enough, and the megasquirt will be controlling it. No need for any external boxes.
Re: Let the Hemi swap begin [Re: AlexP] #1577394
02/25/14 04:41 PM
02/25/14 04:41 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Also, I hate my taxi cab dash. It's never worked and when I went with Painless wiring in the car I never even bothered hooking it up. I was about to wire a bunch of auxillary gauges to keep tabs on things, but I'm not doing that any longer.
I'm going to use Shadow Dash MS for my temp, pressure, voltage, rpm, warning lights and Speedo. All of which will show off of my MS3 box. I might be able to get my fuel sending unit to be read by the MS3 box. I'm just going to make a nice magnetic mount for the Android Device of my choice (Nexus 7 most likely) and use that for the near future. If I leave the car unattended, I'll hide it or put it in my pocket.
This is a Galaxy S3 in a 68 Chevelle.
Youtube Video
Link to MSextra thread
Re: Let the Hemi swap begin [Re: AlexP] #1577395
02/28/14 03:24 PM
02/28/14 03:24 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Here are a few shots of my cylinder heads. They are the 09+ 5.7 heads "Eagles". They are a closed chamber head, with a 6.1 style exhaust port and near 6.1 sized intake port. These will be a perfect match to my 6.1 intake.
Re: Let the Hemi swap begin [Re: AlexP] #1577396
02/28/14 03:26 PM
02/28/14 03:26 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
BBC PAC 1220 Spring with custom spring seats and stock retainer.
Re: Let the Hemi swap begin [Re: AlexP] #1577397
02/28/14 03:26 PM
02/28/14 03:26 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Intake ports.
Re: Let the Hemi swap begin [Re: AlexP] #1577398
02/28/14 03:29 PM
02/28/14 03:29 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Micro Polished chamber
