Re: 833 tranny fluid
[Re: b54406barrel]
#1576831
02/10/14 09:33 PM
02/10/14 09:33 PM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
I've gotten sucked into this debate before. General opinion was they should use ATF. I've always (since the mid 70's) used 80W90 gear oil. Have never had a problem with it, even in cold weather driving, which is where I think the ATF discussion originated from. Purely my own opinion and experience.
Lead, follow or get the hell out of the way
[Re: 66HEMICORONET]
#1576834
02/10/14 09:48 PM
02/10/14 09:48 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Anyone have any recommendations as to the type of lube to use in my 4 speed tranny? We've heard some say synthetic and others not. Any opinions?
80w-90...end of story IMHO
[Re: 66HEMICORONET]
#1576835
02/10/14 10:00 PM
02/10/14 10:00 PM
Posts: 1,357 central Florida
VL21
central Florida
Waaay back when, I had a '66 Formula S, 4spd. Lived in Vermont. In the cold of the first winter I had it (used) I would go out to start it and let it warm up. Push clutch, start engine. Let clutch out, it would stall the engine. Had to rev it up, ease out the clutch. I checked around, then drained it and put dexron in. End of problem. I "believe" all the other four speeders that I had were factory filled with dexron. The 4 gear in my VL21 will have 80/90 if it ever gets on the road, now that I live in Fla.
It takes gasoline to interest me.
[Re: 68LAR]
#1576839
02/11/14 10:33 AM
02/11/14 10:33 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
My 65 uses 80w 90.Has since new.Every one Ive had had the same.Ive had my 65 since 69.Drove it in the winter for years and never a problem.Rocky
Chrysler Firepower
[Re: therocks]
#1576840
02/11/14 11:41 AM
02/11/14 11:41 AM
Posts: 2,366 Wheatfield, NY
Cuda340
Wheatfield, NY
I fully agree with the 80w-90. Also make sure it is GL-4 Rated NOT GL-5. GL-5 has too many friction modifiers in it and will not let the syncro grab the hub enough to slow the gear down. GL-5 is made for rear ends.
[Re: DaveRS23]
#1576846
02/11/14 11:25 PM
02/11/14 11:25 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
In this thread I have read the downside or possible downside to ATF and Synthetics, so why chance it? No one has mentioned a downside to 80w90 except maybe the cold weather. I have always used gear oil but I cant say I have had any with original fluid and of course most if not all have been from down here.
Careful, your character's showing!
[Re: mopar346]
#1576848
02/12/14 12:21 AM
02/12/14 12:21 AM
Posts: 21,819 Kirkland, Washington
Pacnorthcuda
Ok...you're asking for the downside, I will provide it. 80w90 is fine.....IF its a GL-4, not GL-5 lube, and 95% of the 80w90's available ARE GL-5's.
GL-5 has extreme pressure additives in it, highly desireable in a rear end (ring and pinion). The problem is these additives are not long term compatible with the brass synchros in our 833's.
That's the downside, but many people do use it.
[Re: Pacnorthcuda]
#1576849
02/12/14 12:53 AM
02/12/14 12:53 AM
mopar346
Since I haven't looked at the GL-4/5 factor is Gl-4 readily available? How about farm use? I've run gear oil in manuals with brass for years with no known issues, of course I am not running them 20k a year either and cant say I have more than 40k on any of them in many years of use.
[Re: mopar346]
#1576850
02/12/14 01:04 AM
02/12/14 01:04 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Brad Penn Penn Grade Pennsoil Gear Plus Amsoil Valvoline
All offer 80w-90 in GL-4 grade
[Re: DAYCLONA]
#1576851
02/12/14 02:03 AM
02/12/14 02:03 AM
Posts: 43,123 Bend,OR USA
Cab_Burge
The downside to the early first generation NP833 with the OEM synchors was hard shifting, cold weather or not. ATF help alleviate the hard shifting problems The third generation synchors, 1971 and later versions, help a bunch also I have replaced the early syncho asemblys with the later version along with the steel shifting forks for several customers You can to There are three differrent versions of the NP stock synchro assemblys I've seen, 1964 to 1966, 1967 to 1970 and 1971 and later Two different side covers and two different versions of shifting forks also in those
[Re: DAYCLONA]
#1576853
02/12/14 12:09 PM
02/12/14 12:09 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
X2. I drive my Dart until they salt the roads and it's been driven in some pretty cold weather...no problems at all.
[Re: RSNOMO]
#1576856
02/12/14 09:15 PM
02/12/14 09:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Clunky shifting?
Not in my experience, but then again my nick name is not spaghetti arms.
Wait, even my daughter who's nickname is spaghetti arms had no problem shifting an A833, with gear oil in it.
Must be you.
[Re: GTX MATT]
#1576860
02/12/14 10:36 PM
02/12/14 10:36 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
They have gallon jugs of Sta-Lube 85w-90 GL4 at napa for a really reasonable price. that's what I use and it works great.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: John_Kunkel]
#1576861
02/13/14 01:12 AM
02/13/14 01:12 AM
Supercuda
About to go away
About to go away
up yours
Ever driven a T-10? Muncie?
Yes, and a toploader and a T5 and a A435 and numerous other manual transmissions, foreign and domestic, even ones you have to double clutch.
Question is, have you ever driven a fresh A833 with a new shifter? When I converted my 87 Diplomat over to stick I rebuilt the trans, rebuilt the clutch linkages, put a Holley pitpack on my new Holley Indy shifter, pulled the Indy apart, polished the lever, cleaned and lubed it and reassembled it. Adjusted the shift and clutch linkages and it was sweet.
[Re: Supercuda]
#1576862
02/13/14 04:17 PM
02/13/14 04:17 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Ever wonder why Chrysler developed the "slick shift" modification for the 833?
[Re: John_Kunkel]
#1576865
02/13/14 04:55 PM
02/13/14 04:55 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Agreed....
Even an absolutely PERFECT 833 with all new parts isnt going to be "sweet shifting"..Not in the same way a Muncie or T10 is..Those trannies are as fragile as fine China, though...
The 833 is essentially a truck unit used in car applications...Its VERY strong, but its very heavy, and not meant to be powershifted. And yes, Chrysler knew this very early on, hence the "slick shift" crash boxes..
Use standard 90wt gear oil in most applications...Ive used Sychromesh in race units-but those arent meant for the long haul....I also do NOT recommend synthetic 90 wt...
MB
[Re: 66HEMICORONET]
#1576868
02/13/14 07:35 PM
02/13/14 07:35 PM
Posts: 18,157 Mass
DAYCLONA
Mass
IMHO, if your 4spd had ATF in it, run it with that if you so desire, if it had gear oil (80w-90) run that, personally over the last 30 years I've always run gear oil in my Mopar 4spds I've seen too many guys over the years that say "The FSM says ATF", and they switch out the gear oil, and find that one or more several things happen, the tranny craps out big time, or it leaks like a sieve with the ATF, or it shifts like crap....so after you cut thru the "mustard" of this thread, and pic your poison, report back with your opinion
Mike
[Re: dan9]
#1576869
02/13/14 09:01 PM
02/13/14 09:01 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
I bought mine from Passon's last year. He told me to run 80/90w non-synthetic.
he told You to run any 80/90? Does he not sell his fluid any more? I run his and it's about the weight of 5/30w
[Re: Supercuda]
#1576874
02/14/14 02:43 PM
02/14/14 02:43 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
Yeah, so lesser mortals could try to keep up with Ronnie Sox.
NOT FOR STREET USE.
Here is a little secret...
Sox ran a Toploader in a lot of those cars...
MB
[Re: dan9]
#1576875
02/14/14 03:02 PM
02/14/14 03:02 PM
ademon
IL, Aurora
Yes that is what he said. Any 80/90w non-synthetic. He did not try to sell me his or even mention that he had his own type.
OK thanks maybe ill go with the Red line MTL next
