“Frankenstein” is DEAD! ** The Autopsy report is in **
#1574597
02/05/14 08:03 PM
02/05/14 08:03 PM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
You may have read in one of my previous post I broke a rod going through the traps at our final bracket race (I got the win light but I’d trade it for 8 more passes to finish the year as I had planned on replacing the rods this winter). It knocked the side out of the Mega block, messed up several cylinders, broke the cam and of course destroyed the other rod on that journal and put shrapnel on all the other pistons.
I assumed the Mega block was gone but we were able to repair it since the damage was non-structural, just pain rail and side, so as long as it welded up well enough to hold in oil and the pan, we were good. Since I was only at 4.380 on the bore, we were able to go to 4.440 on the bore and that cleaned up the cylinders. (we also pressure checked the block and it held pressure, even though there was some pretty major damage to the bottom of the cylinders)
We turned/off-set ground the K1 crank from 4.15 stroke with Mopar rod journals to 4.25 and Chevy 2.2 rod journals. I pick up a set of used Eagle rods from a friend (only had 69 passes on them). Bought new set of Diamond Pistons. I also picked up a damaged roller cam and had it re-ground.
So I’m wondering how much it will pick up, I’m thinking .15 or .2 with the extra 26 cubic inches, longer stroke (4.25 from 4.15 with 7.100 rods) and roller cam and wanted to see what you guys thought?
Old combination: “Old Faithful” (has been together for 6 year with about 1,500 passes on it, has been as fast as 9.40 at 145 with different heads (fully ported Zeekers) but with current combination best was 9.58 at 142) 500” Mega Block - Indy 440-1 Heads that flow Int 309/ Exh 221 @ .700, (42/12 cfm improvement over out of the box head on my machinist flow bench) - Harland Sharp 1.6 rockers (well I found out this winter that 6 of the 8 intake rockers were 1.5 ratio….) - Scott Brown/Straight line Performance Solid Cam with EDM lifters .648/.640 lift, 274/280 @.050 duration, 112 Lobe Sep, Centerline 108 (installed straight up) - Isky 9005 springs – 180 seat and 450 open pressure - Ti retainer, Manley lash caps - Indy single Dominator Intake - K1 4.15 stroke with Mopar rod journals - 440 Source I-beam 6.76 rods - 4.380 Diamond Pistons (standard ring pack, 1/16, 1/16, 3/16) - 12 to 1 compression - Cometic 4.410 .040 head gaskets - 1050 Chuck Nuytten Alcohol Dominator - 2 1/8 headers, 4” exhaust with Borla 4” x 18” oval Sportsman Mufflers
-- Non-Motor info/setup -- - Evacuation system, no vacuum pump - Moroso Center Sump oil pan with Milodon’s windage try, single line Static pickup and Pump cover with Melling HV oil pump - J&J sportsman diaper with removable pig mat - Australian Motorsports belt drive system - MSD 7AL3, Pro Power Coil, Taylor 409 wires (moving to FireCore 50 wires) - AR3911 plugs - Enderle Mechanical Fuel Pump - Shogun external water pump - 1 wire chevy alternator - ARC Pro Stock overhead Switch panel 3700 - 2 Red Top Optima AGM Batteries - MasterLube 3 Qt Oil Accumulator System set at 75psi - Castrol Syntec Synthetic 20w50 with 1 pint of Hughes Engines Extreeme pressure lubricant (Zinc additive) going to Rotela T6 synthetic 5w40 with roller cam this year - 1/4” aluminum front motor plate, 1/8 steel mid plate and an engine limiter/strut that runs horizontally from the frame to the passenger side lower bell housing/tranny mount/bolt - Powerglide (vlasco input, 1.80 straight cut gears, JW Ultra case, JW Ultra bell, JW/Mezire 8 bolt billet flex plate, TransKing electric shift Pro-brake valve body, roller bearing governor support, reworked/enhanced BTE stock case pump, external cooler with 10” fan) - Dynamic 9” converter, stalled 5,500 but was slipping 13% and wasn’t locking up spinning the motor 7,600 in the 1/4 - Strange Engineering Chromalloy 3.5” drive shaft w/ 1350 u-joints - Strange aluminum GT double adjustable 6” travel front struts with 4 piston caliper brakes, 28” Goodyear front runners - Ladder bars with double adjustable AFCO struts with 120lbs QA1 springs (non-adjustable but putting in new rod ends and having a chassis guy make them adjustable for me this winter) - 4.56 pro gears in a Dana 60 with stock drum brakes and strange billet 1350 yoke - Moser 35 spline axels (10 years old and still look perfect, 1 was cut down and re-splined 2 years ago and swapped sides when we straightened up the Dana housing, housing was longer on one side than the other, now both axles are the same length) - 14 x 32 Goodyears -1984 - Centerline Warrior Wheels 3.5” front and 12” rear – they are 18 years old, planned on replace them this year until I hurt the motor, need to move to 14” wheel and was thinking Weld V-Series, maybe next year… -3,200 lbs race weight
New combination: “Frankenstein” - 526” Mega Block - K1 4.25 with 2.2 Chevy journal (Mopar width) (reusing the main bearings, they looked perfect) - Eagle 7.100 rods (used but only had 69 passes and I know the motor they came out of, also reusing the bearings) - 4.440 Diamond Pistons (standard ring pack, 1/16, 1/16, 3/16) - 12.6 to 1 compression - Fel-Pro 1039 .051 composite head gasket - Lunati Roller Cam .678/.678 lift, 278/286 duration @.050, 112 Lob Sep, 108 Centerline (~.030 more lift, 6 degrees more duration on both int & exh, same Lobe Sep and Centerline) (This was a damaged Lunati roller cam that I picked up in 2012 at Monster Mopar for $25 and had it reground using 53714LUN specs but keeping LS/IC) - PAC 1325-16 Springs – 314 Seat and 752 open pressure (644lbs spring rate, installing at 1.910, bind at 1.150) - New Valves but no porting, just standard valve job - Harland Sharp 1.6 rocker (not mismatched 6 - 1.5 and 2 - 1.6 intake rockers) - Milodon 31161 dragster/chassis pan, dual line swinging pick up, Muscle Motor Oil Pump cover, Milodon 21815 oil Pump with external fitting for 2nd pick-up line - Dynamic 9” converter sent in to tighten it up on the top end but leave the stall around 5,500, want to shift at 6,800 and go through 1/4 at 7,000 – 7,200.
Essentially 26 more cubic inches, a little more stroke & bore, a little more compression, a little more cam(roller vs solid), better oiling system and a little tighter converter.
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
Re: Predictions on ET increases with new motor?
[Re: WadeMetzinger]
#1574598
02/05/14 10:14 PM
02/05/14 10:14 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Those are some decent changes.More Cubes, comp, and cam. That cams going to be a bigger change then it looks numbers wise because its a roller.
Id say a Minimum of .2 maybe more like .3 to .4 Just a guess though because at 9.4 it does take alot more hp for gains to happen.
[Re: Sport440]
#1574605
02/09/14 10:08 PM
02/09/14 10:08 PM
Posts: 903 Saskatchewan, Canada
cudabin
MCH's 345cc CNC ported -1's flow around 382cfm, and can support 955hp... I think the combo with a glide will like the stroke and compression increase and pick up .2 to .3 Good luck with it! Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: WadeMetzinger]
#1574606
02/09/14 10:27 PM
02/09/14 10:27 PM
Posts: 16,916 NC
440Jim
NC
The heads have a lot left in them, I think my head porter's flow bench is a little stingy so that's why I include the from/to #'s and increase numbers.
I noticed that in your original post, so I am guessing on another flow bench your heads might flow 340 or more.
I think 0.20 is there, and maybe a little bit more. I would have liked to see you add more CR by milling the heads or something. I am thinking the roller cam will like the finish line rpm better than the flat tappet did, so you will see a mph increase. (7600?, 4.56, 32", 142 mph)
Will your KB block be 4.500" bore? That should get your CR close to 13.0 and the alcohol will support much more. I would mill the heads when you build that motor.
[Re: WadeMetzinger]
#1574608
02/10/14 02:26 AM
02/10/14 02:26 AM
Sport440
Canton, Ohio
Thanks guys for the input, sounds like I wasn't too far off.
Jim, no I'm starting out with a 4.360 bore, I really don't want to go much faster. It will be a 496" 4.15 stroke with these heads, cam, lifters and belt drive from the "Frankenstein" motor so it'll make less power but be 150 to 200 lbs lighter so it will probably another .10 faster still. I'm keeping the compression around 12:1. I may be off here but I've always thought that compression above 12.5 is harder on parts and makes power but not enough to justify to the abuse to me because I want to put a lot of passes on the motor without major maintenance. But that's just my theory I've picked up from my machinist. But I agree you need much more compression to make much more power.
Okay, now your losing me. The New engine was going to be a 526 ci. with 12.6 comp.
But now its a 496 with 12.1 comp.???
Your heads flow more then that stingy flow bench shows as others have mentioned.
So your new combo is not the 526 ci motor.????
[Re: WadeMetzinger]
#1574609
02/10/14 02:29 AM
02/10/14 02:29 AM
Sport440
Canton, Ohio
[Re: WadeMetzinger]
#1574610
02/10/14 10:24 AM
02/10/14 10:24 AM
WadeMetzinger
Tulsa, Ok
I'm good with .1 to .15 increase, it's fast enough as it is. I have a KB block on order so that 200lbs reduction will pick it up another .1 to .15.
Sorry for the confusion, in one of my replies I mentioned that I have KB on order and Jim noticed and asked me about that but that motor will not be built for a while. This post and motor info is about the 526" repaired Mega block motor.
[Re: WadeMetzinger]
#1574611
02/21/14 12:23 AM
02/21/14 12:23 AM
WadeMetzinger
Tulsa, Ok
Assembly is coming along, just a little slower than I'd like but this isn't the time to take short cuts and get into a rush.
Rotating assembly has been balanced, rods and pistons put together, rings filed (I got in a hurry and broke one..... One set was $30 so I just bought a full set for $102, I think I stretched one or two others so I may replace a few others)
2365 bob weight with eagle h-beam rods Piston 596 Pins 178 Locks 5 Rings 58 Little end 242 Big end 593 Bearing x 2 48= 96 Oil 4
Degreed the cam in at 104.5. My machinist thinks the cam is to big with my 12.5 compression so we advanced it 4 degrees to increase the cylinder pressure at low RPM and give a little more bottom end.
Gapped the rings .020 top and .025 second to help keep the alcohol from washing the cylinders down.
Main clearance was .0015 to .002 so I got a set of King x bearings to get .003.
Rod clearance is .003 so they are good to go.
Rod side clearance is .032
Pistons are .011 in the hole
Ran out of time to check piston to valve and measure for push rod clearance. So I've only got 2 pistons installed. Hoping we don't have to cut the pistons for valve clearance because I've already put all the rods and pistons together and I'm running out of time. Our first points race is March 22.
Here are a few picture of the rods and pistons and the piston build card. They are diamond part number 52030 but changed to 4.440 bore. (4.25 stroke, 7.100 rod and 1.480 compression height) pins are standard pins, I've always upgraded the pins but when talking to diamond they told for my application the standard would work just fine.
[Re: WadeMetzinger]
#1574615
02/21/14 05:09 PM
02/21/14 05:09 PM
Posts: 16,916 NC
440Jim
NC
A reliable source told me that several years ago most shelf pistons came with a 0.155" wall pin, but now-a-days Diamond is using 0.185" wall pins and your 178 gram weight confirms what you have. The 0.990 x 2.93 pins with 0.155" wall were around 150-155 grams.
[Re: 440Jim]
#1574616
02/22/14 10:23 AM
02/22/14 10:23 AM
Posts: 9,963 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I think the changes are going to surprise you, and you will be a solid .20 or more quicker. You are increasing the motor size by five percent, the heads flow that much more, and the cam is bigger by more than that for sure. If rest of the package is close, the motor will pull very hard down low, and you may be able to shift it below 6800 and still go as fast. You could also run less gear. My 528 with 2.30 intake valves and full porting only wants 7100 rpm for best ET. I am also thinking that glide is going to love the extra cubes and compression.
[Re: WadeMetzinger]
#1574617
02/23/14 02:53 PM
02/23/14 02:53 PM
BradH
"... ET increases..." I think you mean ET reduction or improvement since an increase in ET means the car slowed down. /
[Re: BradH]
#1574618
02/23/14 03:40 PM
02/23/14 03:40 PM
Posts: 698 Alberta Canada
Edge
Alberta Canada
As mentioned above not likely to pick up a great deal of hp but torque will move up for sure. Should improve in the 60 foot however may not see MPH increase much more than 1 mph unless your converter was leaving alot on the table. I would guess .1 to ,15 increase. Maybe more depending on how the converter likes the converter changes. FWIW I have had best luck just getting a new converter as opposed to tweaking old ones.
76 Duster
work in progress
[Re: Edge]
#1574619
02/23/14 09:43 PM
02/23/14 09:43 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
Looks like a nice build Wade I do have one question, is there any reason your leaving the piston to head @ .062" ? I see your piston's are in the hole .011" and your using a .051" gasket.
[Re: roadhazard]
#1574620
02/23/14 11:28 PM
02/23/14 11:28 PM
Posts: 656 Kokomo, IN
540dust
Kokomo, IN
One question, you stated "- Lunati Roller Cam .678/.678 lift, 278/286 duration @.050, 112 Lob Sep, 108 Centerline (~.030 more lift, 6 degrees more duration on both int & exh, same Lobe Sep and Centerline)". Is this spec'd with 1.5 or with 1.6 rockers? If its .678" lift with a 1.5 rocker and you are using a 1.6, I think the spring will be very close to binding at lift. Documentation on those springs (PAC 1325) say bind at 1.150" which would make it real close, too close I would think. Just something to check.
The build looks cool to me I would put my money on at least .2 sec. quicker.
[Re: roadhazard]
#1574621
02/24/14 01:57 PM
02/24/14 01:57 PM
WadeMetzinger
Tulsa, Ok
The pistons just ended up .011 in the hole and I just thought I'd go with the Fel-Pro 1039 composite head gaskets. They work well for this bore and compression and were a lot cheaper than Cosmetics.
I didn't know where the pistons were in the block before ordering them. I'd rather run a .030 or .040 but I "think" .062 will work ok, let me know if you guys think I'm making a mistake and should go ahead and get a .040 Cometic gasket.
[Re: 540dust]
#1574622
02/24/14 02:02 PM
02/24/14 02:02 PM
WadeMetzinger
Tulsa, Ok
I already did the conversion for the 1.6 rockers. The cam spec is for 1.5 and lift is .636 so with 1.6 the lift will be .678. When I spoke to PAC about the cam and springs they are the ones who told me to shoot for 1.910 install height so it would be a little closer to coil bind.
I didn't know I needed to add any more to the duration, so if your saying I need to add 6 degrees for the 1.6, my duration will be 284/292 rather than 278/286. Thanks for pointing that out.
[Re: WadeMetzinger]
#1574623
02/24/14 02:31 PM
02/24/14 02:31 PM
Posts: 1,664 North Sweden
RT540
North Sweden
For better quench and to bump up the CR for the 112 LSA, yes I would buy .040 Cometics, or even .035 if they are available that size? If your block surface and head surface are not smooth, maybe it is time to fix that to.
Re: “Frankenstein” is almost alive!
[Re: WadeMetzinger]
#1574624
03/11/14 02:03 PM
03/11/14 02:03 PM
WadeMetzinger
Tulsa, Ok
Finally got all the machine work done and assembled the motor this weekend. We installed it in the car last night. Tranny is supposed to be finished tomorrow so we will put it in Thursday and then I’m taking Friday off to try to get everything hooked up and started and might be able to make it to Test-n-Tune Saturday. The chassis guy is also coming over Friday to install the modified ladder bars and scale/setup the car. (I had him make my not adjustable ladder bars adjustable without having to take them loose to adjust them).
Measured for pushrods and found that I needed to make some additional clearance for Pushrod in the heads and also for 2 of the HS rocker arms, the pad under the shafts (they weren’t touching but I couldn’t see day light either).
I hate doing clearance on the heads after they are fully assembled and ready to go from the machine shop (new Manley valves/locks/lash caps, PAC 1325 springs/Ti retainer, set up at 1.910 315lbs seat and 750 open) but it’s much better than doing it on the motor and in the car… Blew them off, washed in the parts washer, blew them off again and again.. Then I switched #1 spring with light springs so I could check pushrod clearance and see how much aluminum shavings were still there and they were pretty clean.
Ring Gap (running alcohol) 4.440 bore - .020 top and .025 2nd and oil rings pulled about 15lbs with the fish scale so I left them alone. Total Seal Plasma Moly and ductile Iron rings 1/16 1/16 3/16 standard tension oil rings
Degreed the cam in at 104.5 (162 .05 after intake high lift + 47 before intake high lift = 209 /2), which is 4 degrees advanced from the cam card but it was set at 108 and said it was also 4 degrees advanced so I guess it’s in at 7.5 degree advanced. Machinist thought the cam was too big so he wanted me to install it at 104 to increase the cylinder pressure and get it to make good power down low. (.680/.680 284/292 @.050 112 lobe sep & 108 Intake center line (I bought it for $15 and had Lunati regrind it using 53714LUN specs but kept the LS/IC per Lunati for $150)
Rod Clearance .003
Main Clearance .003 (I had to order some x bearings because with the standard bearings I only had .0015 to .002)
Piston to Valve Clearance: .100 Exhaust – (.060 measured + .25 lash + .15 for roller springs since I was using light checking springs) .140 Intake – (.100 measured + .25 lash + .15 for roller springs since I was using light checking springs)
Rod side clearance .032
Crankshaft end play .003
Camshaft end play .012
Piston to Head Clearance .061 (.010 in the hole and .051 head gasket)
70 cc Indy 440-1 head chamber volume
13:1 compression (4.440 Bore, 4.25 stroke K1 crank, 7.100 Eagle Rods, 1.480 compression heights, .051/4.590 bore FelPro 1039 head gasket, .010 piston in the hole, -3.4cc piston valve reliefs, 70cc head combustion chamber volume.
Pre-oiled it with the drill motor, it had 80 psi so I adjusted it down to 65 using the Milodon adjustable oil pressure regulator. I’m starting it with Rotella 15w-40 and after a few weekends I’ll switch over to Rotella T6 Synthetic 5w-40. So the pressure will be a little high until I switch over to the Synthetic.
[Re: WadeMetzinger]
#1574625
03/11/14 02:51 PM
03/11/14 02:51 PM
Posts: 655 Huntsville, AL
Airwoofer
Huntsville, AL
So if I uses those number for OOTB -1's 282/185 and he increased flow 42/12 it would be 332/197. Here are my flow numbers:
----- Intake ----- Lift OTB Ported Change 100 65 69 4 200 126 140 14 300 183 195 12 400 232 247 15 450 251 264 13 500 265 278 13 550 270 294 24 600 269 301 32 650 272 309 37 700 274 316 42
------ Exhaust ------ Lift OTB Ported Change 100 61 70 9 200 115 116 1 300 153 150 -3 400 182 181 -1 450 190 192 2 500 196 201 5 550 201 207 6 600 203 212 9 650 206 217 11 700 209 221 12
"Int / Exh %" 101% 83% 77% 73% 73% 72% 70% 70% 70% 70%
This is what my 440-1 heads (CNC 325 from Indy, fixed by Jim LaRoy in Idaho) flow. Before is as recieved, after is after his valve job. They could use bigger intakes to help the mid flows:
lift............before..........after
.100..........69/61.........80/68 .200........144/123......158/134 .300........215/172......226/183 .400........274/217......277/229 .500........321/251......320/265 .600........346/280......349/290 .700........362/301......368/307 .800........372/317......372/327
[Re: WadeMetzinger]
#1574632
03/15/14 06:08 PM
03/15/14 06:08 PM
Posts: 9,791 MI, usa
dvw
MI, usa
I had a little bit of a scare Monday night. When the motor blew last fall I didn't see any water in the diaper or pan so I assumed the damage didn't get into the water jackets. We pulled the header bolts out of the front and back of the headers as they held the diaper strap brackets to get the diaper off at the track so it wouldn't leak oil on the road all the way home (since it was holding 9Qts of oil). But after we got it home and let it sit for a week, when we went back out pull the motor I noticed there was some water/anti-freeze on the floor mixed in with the oil... We assumed it was coming from the header bolts but need to make sure.
So after we pulled the block and took it to the machine shop we pressure checked it and it held pressure so that's where is must have came from.
So Monday as we are about to put the motor in, I put the diaper on as it's easier to do before you get it in the car and look in the header bolt holes and they all appeared to be blind/solid holes.... (so now I'm questioning if we pressure checked it correctly... if they are blind hole where did the water come from, I have this motor completely assembled, pre-oiled and ready to put in and start this weekend.... am I just going to start it and find out the block is damaged and I'm going to have water in the oil....)
I mentioned this to a friend that was in the shop rebuilding my tranny and he took a look and he pointed out that there was a pin hole on the back/bottom of the front passenger side header bolt hole so I took another look and whew, there it was so now I feel much better now that I know where the water came from. It's just really hard to see. I typically put some silicon on the front and back header bolt just from the past with other heads but that was just out of habit and not because I thought I needed to...
2 of my header bolt holes on my current Indy -1 go into water. I believe they're supposed to be blind. I sealed them with no issue. Doug
[Re: rt66jim]
#1574634
03/16/14 02:52 AM
03/16/14 02:52 AM
WadeMetzinger
Tulsa, Ok
Go green, no KB block yet, expect to see it this next week...
On mine the exhaust bolt farthest to the right as you looking at the motor from the side of the car is not blind and is in water so I just put red RTV on those two bolts.
Jim, I would have but they move test-n-tune from Saturday to Friday night because of the rain forecast for Saturday but it never rained... I was up till 3:30am Thursday night and worked all day Friday to try to make it out Friday night but didn't make it because of a small issuer with the tranny. We fired it up about 5:30 got it warmed up and then checked the tranny and it didn't move so we had to drop the pan and hook up something the tranny guy forgot about, luckily he was still there and was able to fix it.
So it was 7:45 when we were finally ready but by the time I would get to the track and be ready to make a pass it would have been 9:15 and the track would have been starting to get cold and I didn't think that was the best condition to make the first pass. So I just started to tie up loose ends and will be ready for nespxt weekend.
When I was mocking it up I noticed the push rod clearance was tight so I did so e grinding on the heads before putting them on but I didn't do enough so I did some additional clearancing on the heads today, hate doing that with them on the motor but I did all I could to get the shavings out. Thie witness marks in the lush rods told me where I needed to do the additional clearancing.
Started it up on gas and then ran it for about 20 minutes, about 5 of those at 200 so the rings should be good and seated. Then we switched it over to alcohol and adjust the carb, etc for another 10 min.
Checked valve lash and tightened the intake and exhaust bolts as it was cooling down. The cold oil pressure at idle was 60 and 40 hot at idle. Climbed up to 80psi we I rev'd it up.
I'm going to cut open the filter tomorrow and it should be ready to go.
[Re: WadeMetzinger]
#1574635
03/16/14 01:17 PM
03/16/14 01:17 PM
Posts: 16,916 NC
440Jim
NC
Thanks for the heads up about the possibility of the Indy holes leaking water. My old 440-1 heads never leaked water from the header bolt holes. But this year I have a newer set of CNC-345 heads so I just went in the garage and checked them (not on the motor). None of the holes leaked into the water passages. Glad to see it wasn't a "feature" of the newer Indy heads. Seems like only some heads hit water (machined too deep maybe?).
[Re: WadeMetzinger]
#1574636
03/16/14 01:25 PM
03/16/14 01:25 PM
Posts: 16,916 NC
440Jim
NC
I am considering a cam with about the same duration for my new motor. I think the 13 CR should be enough for that cam (more might be better), mine will be 13.4 so it is close to yours. I do have a 3 speed trans so I am going for more hp rather than midrange torque. A good race car has 5500-6000 converter anyway! LOL My old motor had more torque than it needed any way (279/287 at 0.050 cam).
With you installing it at 105ish with 112 LSA that is advanced plenty, I might have only put it at 109. Let us know how the PG does at the launch. Didn't you have a little less CID last year?
[Re: 440Jim]
#1574637
03/16/14 10:35 PM
03/16/14 10:35 PM
WadeMetzinger
Tulsa, Ok
The nice thing about the the belt drive is I can retard it and see if it likes it better than the 104.5 degrees.
Yes last year the motor was a 500 cid so I've increased it 26 cid".
[Re: Bad340fish]
#1574646
03/23/14 01:16 PM
03/23/14 01:16 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
Looks good! That car is gonna fly!
I think you missed a post.....
Well I guess I missed a post too. Did something bad happen?
[Re: Bad340fish]
#1574649
03/23/14 10:51 PM
03/23/14 10:51 PM
rt66jim
Joplin, Mo
So what's the one thing I didn't check (clearance wise) and none of my Moparts buddies asked me about?
It blew up on the second pass if that helps anyone... Chunks of piston made their way up to the lifter valley.
Post above tboomers
Ok I'm old and blind I guess. But I haven't found another post. Point me in the right direction with a link.
[Re: WadeMetzinger]
#1574656
03/25/14 02:06 AM
03/25/14 02:06 AM
Sport440
Canton, Ohio
Wade, did you get a full run in on the first pass, or did you just do a breakin run? I have respect for your honesty on the good or bad that happend to your car. Im about to do the same first run testing. Good or bad I will disclose the outcome too. Some would hide it or disappear out of ego issues. Glad to see your not one of them.
[Re: Sport440]
#1574657
03/25/14 09:42 AM
03/25/14 09:42 AM
WadeMetzinger
Tulsa, Ok
Thanks I've learned a lot from the MOPARTS community so I want to share my buitd with other so they can learn and those that have more experience can comment and ask questions so I can continue to learn as well. (I wished someone would have asked me about the counter weight to piston clearance. Lol)
I did make a full pass, it blew up on the 2nd pass.
It picked up the front wheels and while they were in the air it spun so it wasn't a good pass. If your not one of the first few down the track at test-n-tune the street tire cars destroy the track. It had a 1.38 60' 6.17 1/8 and 9.66 at 138mph which was 2 tenths and 4 mph slower than I expected but it spun off the line so it wasn't a good pass. On the 2nd pass it went 6.15 in the 1/8 and blew up at the 800 to 1,000 foot.
Hope to get it out this weekend and I'll share pictures and more iron on what I learned.
[Re: WadeMetzinger]
#1574658
03/25/14 10:31 AM
03/25/14 10:31 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats a MAJOR bummer Wade... I do have a set of 4.440 pistons with chevy pins... they were for my B-1 that are for sale... they were for a 4.15 crank
[Re: MR_P_BODY]
#1574659
03/25/14 02:51 PM
03/25/14 02:51 PM
WadeMetzinger
Tulsa, Ok
Will the B-1 pistons work on standard heads, like the 440-1s? I think I've heard they will but not sure.
[Re: WadeMetzinger]
#1574660
03/25/14 10:57 PM
03/25/14 10:57 PM
Posts: 16,916 NC
440Jim
NC
The only thing I didn't check, I've never checked and didn't know I needed to, was the crank counter weight to piston clearance.
This was a K1 Hemi 4.15 stroke crank and in the first motor I used it in we cut the counter weights down besause it needed so much weight taken off of it to balance it.
And then when I hurt the motor last fall I had it offset ground to 4.25 and Chevy journals. So with the 7.100 rod and shorter pistons there must have not been enough clearance. It would turn over by hand just fine
Oh No ! I hate to hear that.
This is what I came up with (after the fact):
CWmax = Counter Weight max dia Pthick= Piston thickness below the pin Pin = Piston pin dia Rod = Rod Length
CWmax = 2(Rod - Stroke/2 - Pin/2 - Pthick - Clearance) For example:
CWmax = 2(7.100 - 4.25/2 - 0.990/2 - 0.240 - 0.060) CWmax = 2(7.100 - 2.125 - 0.495 - 0.240 - 0.060 ) CWmax = 8.36" dia
So the piston pin support area should not have been a problem if the crank counter weights are less than that. On a low deck with 6.535" rods it gets close. Typically counterweights are 7.5" plus or minus dia (mine are cut to 7.14" dia). But maybe the skirt?
[Re: 440Jim]
#1574661
03/26/14 12:58 AM
03/26/14 12:58 AM
Sport440
Canton, Ohio
With a 7.1 rod, I dont see that interference happening either. His autopsy should reveal it, chopped pistons or spun bearings or whatever. Wade, I look forward to your autopsy on your motor. I thought you did a great job on that motor! Your results scare me because I feel Ive got a frankenstine motor going together.
[Re: Sport440]
#1574662
03/26/14 01:28 PM
03/26/14 01:28 PM
Triple Threat
Renton Washington
Really Sorry to see this Wade. Hopefully its salvagable.
[Re: Triple Threat]
#1574663
03/26/14 01:37 PM
03/26/14 01:37 PM
Posts: 13,318 Marion, South Carolina [><]
an8sec70cuda
[Re: WadeMetzinger]
#1574664
03/26/14 01:42 PM
03/26/14 01:42 PM
MR_P_BODY
I dont know Wade.... I know how you feel about it breaking with so few runs/time... I had my W-9 blow on its first pass.. it made it to about the 1/8 mile then all hell broke loose...it cost me $3500 to put it back together... a lifter tie bar broke and a valve hung open... that cost me 1 head, 4 pistons and a rod and a set of lifters.. that engine was done with the help of a local performance shop on the first build up... oh yeah.. had to sleeve 1 bore... but since then its been a great engine with almost no issues at all.... best of luck to you on getting it back together
[Re: WadeMetzinger]
#1574674
03/29/14 06:53 AM
03/29/14 06:53 AM
RT540
North Sweden
I made a template of my new CP 4.51" valve reliefs for B1 heads and placed the template on my old Wiseco 4.50 pistons. As I see it, the notches(clearance) will be shallower, would you all agree to my thinking?
On the old Wiseco
[Re: RT540]
#1574676
03/29/14 12:09 PM
03/29/14 12:09 PM
Posts: 877 ky
68roadrunner
ky
would like to know this myself, i know the -1 heads have a 15* angle on the valves
sorry about your problem wade, i feel your pain, been there done that
[Re: 68roadrunner]
#1574677
03/29/14 12:17 PM
03/29/14 12:17 PM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I know I had to get my Wisco pistons that were made for 440-1 heads re-cut for my B1 heads. Different valve angles. It cost me just under 100 dollars but that was years ago.
[Re: Cheatham]
#1574679
03/29/14 12:35 PM
03/29/14 12:35 PM
MR_P_BODY
on my 572 in beginning i was planning to start off with a indy ez-1 head but knew i may end up with a b1 so the pistons were notched for b1s which i was told would work with indys
Based on what has been shown here and if he isnt running a max lift the B-1 pistons should work.. mine were made to the B1M/C head so the intake valve is moved but even then it looks like the smaller valve would clear.. and if it isnt a max lift even the angle change wouldnt matter.. but it would have wasted space
[Re: MR_P_BODY]
#1574681
03/29/14 12:48 PM
03/29/14 12:48 PM
MR_P_BODY
Here is the specs on them... see if they would work for you... I'll let them go pretty cheap since I sold off everything else for that engine.... these are CP pistons with the gas ports
[Re: MR_P_BODY]
#1574682
03/31/14 04:12 PM
03/31/14 04:12 PM
WadeMetzinger
Tulsa, Ok
The Autopsy report is in from the “humbled/embarrassed” engine builder (myself)…
All the clearances were fine, it was totally my fault. I put the passenger side bank of pistons in wrong…. Instead of Exhaust, Intake, Intake, Exhaust, Exhaust, Intake, Intake, Exhaust…. I did the complete opposite…
So every intake valve was hitting the piston and probably bent everyone on the initial startup. I made the first pass and it went 7,500 and they all stayed connected but on the 2nd pass, 6.15 at 113mph, and about 800 foot the #8 intake valve head broke off and bounced all around and ended up in #1 intake port. The #8 valve guide ended up holding #6 intake open and the #8 valve seat ended up in #2 intake port so there was a lot of action going on inside the Intake port after the valve head broke a the #8 piston and then traveled back up into the heads. (it went a 9.66 on the first pass with every intake valve on the passenger side bent and not seating, so I bet it would have ran that 9.30 something I was hoping for…)
We heard a noise on startup but thought it was the rocker because we has some push rod clearance issues that I worked on after initial startup and it got much quieter, sort of sounded like the rockers were tapping the valve covers slightly but no, it was the valves hitting the pistons… Basically the noise had almost gone completely away because it was making its own clearance… I attributed that to the work I did to make clearance for the push rods…
From the picture below you can see that #8 head chamber is pretty badly damaged, but repairable. Every piston has shrapnel damage, every head chamber has shrapnel damage, every intake is bent on the passenger side head and I’m not sure if the valves are ok on the driver side yet but with the valve head lodged into #1, I’m guessing I may have bent a few valves on that head as well. Both heads will need some repair work done.
#8 piston has a hole in it and it’s split down the side (at first glance I thought it was the cylinder that was split) but I think the Block, Crank and Rods survived. I’ll need to check and possibly replace #8 rod since it was abused, I’ll check the cranks just to be sure, the #8 cylinder will need to be either sleeved or I’ll just need to bore all the cylinders to 4.50” bore, which is what I will probably do since I need new pistons and I’d rather not sleeve the block.
There wasn’t any damage to the oil pan or windage tray, there wasn’t any metal on the oil pan magnetic plug (most of the shrapnel was aluminum and stainless steel. There was some aluminum in the oil pump rotor so I’ll probably replace them if I can’t clean them up enough to be sure they are fine.
I was hoping I got lucky like I did when the motor blew up last fall and there wasn’t any damage to the heads except 1 bent valve. All I need to complete the KB short block is a set of rods and the mega block will need to be bored, new pistons and probably a rod. Both of those were option and I thought I might be able to swing so I could get another motor going for this season but with the heads damaged I’m going to need to repair or replace them and that will put me out for this year. (Frankenstein was going to be my back up motor once I got the KB motor done but that plan didn’t work out did it…lol
I am fortunate to have my wife ’68 Barracuda that runs 10 and is a blast to drive. So as long as I keep on her good side she will let me double up with her and still get to race some this year.
Moral of the story and what I learned from this experience….
I’ve probably built close 30 race motors and never had a failure, so I was over confident with the basic stuff like getting the pistons in the hole correctly and was more focused on the more technical/advanced items. So my over confidence and rushing to make the 1st points race of the year allowed me to learn a lesson the hard way. Yes the machinist was late getting the machine work done and getting the heads to me but that is no excuse for me rushing to build the motor and getting it into the car in 1 weekend.
I should have taken my time and made sure I did everything correctly, even the stuff I’ve done many of times and shouldn’t have to think twice about, it never pays to rush when you’re building a motor.
[Re: WadeMetzinger]
#1574688
03/31/14 04:57 PM
03/31/14 04:57 PM
MR_P_BODY
It turned over by hand with no problems... I wished it hadn't..lol
I guess you didnt clay the pistons to check the P to V clearance.... we all learn... but that one COST
[Re: WadeMetzinger]
#1574692
04/01/14 12:50 PM
04/01/14 12:50 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Wade I am sorry to hear of this. Years ago I was in a hurry to put the engine in the car. Everything was checked. I put the flexplate on the crank & torqued it. Put engine in car, did testing. It kept slowing, then it died on the turn off. It wouldn't crank with starter. Got towed back to pits. Looked things over, then it started. So after it cooled it would crank. Long story short the ARP flexplate to crank bolts were TOO LONG! The bolts jacked all the end play clearance out of the crank. You would think you would hear or feel the bolts rubbing on the block. ARP said oops I guess chevy bolts won't work for that engine. The 1 thing I didn't look at caused that engine to be rebuilt. It wasn't the engine builders fault it was the intaller's (me) ARP made the correct bolts after that. Don
[Re: camastomcat]
#1574697
05/07/14 06:10 PM
05/07/14 06:10 PM
WadeMetzinger
Tulsa, Ok
I just happened to call Ken today and he said the block is basically done and cam bearing installed but they are waiting on sleeves. The supplier that they get the sleeves from is backed up or something. He said they buy "blanks" and then machine the ID, OD, flange, o-ring groove etc to the customer specific block. He said they typically use a 4.700" sleeve and are good to 4.530" bore, if I understood him correctly. I'm starting out with 4.360" bore but they are using the same 5.700" sleeve so I can go to 4.500" later on. He said he had another source he was going to get a few sleeves until the main supplier catches up so I'm guessing it will be another 2 weeks..
“Frankenstein” is almost alive! Let’s try this again..
[Re: WadeMetzinger]
#1574700
10/03/14 04:30 PM
10/03/14 04:30 PM
WadeMetzinger
Tulsa, Ok
Block - Bored the block to 4.50” from 4.44” (.060” bigger, it started out life as 4.320, then 4.380 (dropped valve), then 4.440” (broke rod at 7,200) and finally 4.5” (dropped valve, broke piston because I’m an idiot, I’m sure glad I started out at 4.320, or I would have scrapped the block or had a bunch of sleeves in it by now) They did sonic check it and the thinnest spot on the thrust side was .155 but I think that will be just find since I'm not running 16:1 compression and not running any power adders.
Pistons - Ordered new Diamond pistons, Shelf 4.25” 7.100 rod pistons and changed the bore to 4.5” and had them cut the valve reliefs .030 deeper
Rods - Replace the 1 Eagle rod, no apparent damage but since that piston had a hole in it and was busted all the heck, I figured it had earned early retirement (80 passes).
Rod Bolts - Replaced all the rod bolts (ARP2000), they only had 80 passes on them but they had been torqued at least 6 times so I figured it wasn’t a bad idea.
Crank - checked out ok, just polished it up.
Rotating Assembly - Send the rotating assembly to be balanced with the new pistons but the machinist called and said there wasn’t but 1 gram of difference so we didn’t need to do anything. I did switch from Clevite to King rod bearings and he said there was some difference there so I guess Diamond does some lightening to the 4.5” pistons too.
Heads – I had a local guy repair the head that had the chamber and port damage. And then I had my machinist put new valves in it. The other head just had aluminum shrapnel all over it and I assumed that we would be able to salvage a few if not all the valves but he said most all of them were tweaked from the shrapnel…. So the brand new Manley Sever Duty vales had a whole 1.5 passes on them and then allowed to retire. I think we only saved 1 exhaust valve from both heads… They had to take .025 off the surface to clean them up so now the chambers are 66cc (more compression). Since the PAC 1325-16 springs, TI retainers and locks only had 2 passes on them we were able to re-use all of them. They are set up at 1.910, 215lbs closed and 750lbs open at .700”.
Lifters – I couldn’t see or feel anything wrong with them but a local engine builder told me he would send them in to Isky just to be sure and I’m glad they did, they found 2 that needed repairs. These are the roller lifters with the bushing, only cost $1,250 but they should be the last set I ever buy…
Compression will be bumped up to 13.8. (4.5” bore, 4.25 stroke, 66cc head chamber, 4.590 head gasket bore, .051 head gasket thickness, 4.5cc valve reliefs, .010 piston to deck)
The increased bore size will make the motor 540” cid.
I spoke to Lunati about the cam and they recommended that I put it in straight up and not advance it 4 degrees like I had it installed, it has more duration that I like but he said the cubic inches will each up a lot of that duration. Lift with 1.6 rockers .678/.678 duration at .050 284/292 Lobe separation 112 Intake center line 108 (build in 4 degrees advanced)
Since I blew my motor up the Friday before our 1st points race in March, my wife let me race her ’68 Barracuda in No-E and she raced it in Sportsman. I don’t feel anywhere near as confident in her car as I do mine but somehow I managed to win the No-E Points Championship.
We don’t have any more bracket races, but we have the NHRA Div 4 Team Finals in Dallas, another Team final race up near Joplin, MO and then our local Mopar race in Tulsa Nov 8 so I’m hoping to get the motor built and in the car for the Mopar race (just not enough time to get it ready for the others). So I’ll go into the winter with a completely fresh car, motor and tranny will have less than 20 passes on them.
Re: “Frankenstein” is almost alive! Let’s try this again..
[Re: WadeMetzinger]
#1574701
10/03/14 06:31 PM
10/03/14 06:31 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Takes balls to show everyone a humbling mistake like this. This kinda thing happens often but it gets hush hushed.
Mopar to the bone!!!
