cruise control servo diap, looking forward to repro it
#1574424
02/05/14 12:43 PM
02/05/14 12:43 PM
Posts: 6,089 Valencia, España
NachoRT74
Valencia, España
Does somebody knows where to find a replacement? two servo units in hands, both with broken diaphragm
Re: cruise control servo diaphragm
[Re: NachoRT74]
#1574425
02/06/14 12:13 PM
02/06/14 12:13 PM
NachoRT74
Valencia, España
it seems, nobody here is interested on fix their CC if broken LOL, just power and tracks LOL
[Re: moparfan53]
#1574429
02/06/14 07:02 PM
02/06/14 07:02 PM
NachoRT74
Valencia, España
nice thread but these ones can't be fixed, need a new diaphragm
and on thread says NOS and used are easy to come by? tell me where and AFFORDABLE!
last ones NOS came out on ebay over $200
[Re: NachoRT74]
#1574431
02/06/14 11:11 PM
02/06/14 11:11 PM
Posts: 1,057 Dallas, Texas
FC7cuda
Dallas, Texas
I have several of the servos, is there a way to test the diaphragm?
Thanks Tom
68 Charger 70 Cuda
[Re: gtx6970]
#1574434
02/07/14 11:50 AM
02/07/14 11:50 AM
NachoRT74
Valencia, España
while I'm agree they could never got serviceable parts, I guess must be around some ppl/shops who rebuilds diaphragms, because servo control is not the only part of the car what it works with vacuum.
i.e.: 68/69 headlight doors actuators, A/C actuators, Big truck brakes systems, Mercedes 116 door lock actuators ( is my case too LOL ), and lot of etcs...
then add to these, lot of medical tools or devices
[Re: NachoRT74]
#1574435
02/07/14 04:12 PM
02/07/14 04:12 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Service parts must have been available at one time because rebuilts were available from NAPA years ago. (NAPA # ECHCCR6085)
[Re: John_Kunkel]
#1574436
02/07/14 05:02 PM
02/07/14 05:02 PM
Posts: 2,914 Calgary, Alberta Canada
a12rag
I have always added the factory cruise unit to anything I got, that did not have cruise . . . kept going through the wrecking yards for the components : Servo, Servo bracket, lost motion link on the carburator, wiring - including brake switch and turn signal stalk switch . . .
Have quite a few of the servo's that didn't work when I tried them. Never thought of taking them apart. You could get the cable as a service item . . . as for the rubber diaphram - if it does have a hole, then why not fix using a rubber patch ??? I am pretty sure most of the electrical stuff, held up well on the servo's, so it would probably be just the rubber diaphram issue ??? . . .
Mark
[Re: convx4]
#1574439
02/08/14 01:33 PM
02/08/14 01:33 PM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
I might have some at the old garage.I pulled a lot of stuff from my Imperials that I scraped.I have to wait for warmer weather though.I dont like going up in the attic till its warm.Rocky
Chrysler Firepower
[Re: NachoRT74]
#1574442
02/10/14 12:05 AM
02/10/14 12:05 AM
Posts: 704 USA
rftroy
USA
I guess sucking throught the hose and checking the diaphragm moving... or not
So you don't make a wrong diagnosis, you can't test the diaphragm by putting vacuum on the tube. There is an internal vacuum release valve that prevents vacuum from building up until, 1. The electrical circuit is activated, and 2. The input rotational speed of the speedo cable is about 25 mph.
You could, conceivably, hook up the electricals, and rig some way to turn the speedo input, while applying vacuum. Just be careful that you don't rotate it too fast or you will grenade the insides. I've never needed to do this on the few that I have repaired, but I wouldn't recommend using a drill motor.
I have the factory speed control manual, which has pictures and gives a thorough description of operations, but it is a 21Meg zip file. I will try and find the link from which I downloaded it and post it later.
Robert
AAR 4-speed 3.91, Tor-Red; 70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy; 68 Formula S conv 383 4-speed 3.23, Electric Blue; 69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue; 78 Lil' Red Truck, Red; 70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
[Re: rftroy]
#1574443
02/10/14 12:23 AM
02/10/14 12:23 AM
Posts: 704 USA
rftroy
USA
Found it! http://www.imperialclub.com/Repair/Lit/Master/index.htmGo most of the way down the page to 1972. It is the "Speed Control and Concealed Headlights" manual. Some very cool stuff on this site. Robert
