Re: 1969 Coronet R/T Resurrection.
[Re: AZ_A12_BEE]
#1569847
03/01/14 03:58 PM
03/01/14 03:58 PM
Posts: 18,575 Dreaming of the 808
AZ_A12_BEE
Dreaming of the 808
Getting ready to pull the motor and trans
69.5 A12 Bee, first purchased in 1976, car 169 on registry
69 Coronet R/T 440/4 spd
69 Coronet 500 Conv H code 383 4bbl/auto
37 Plymouth PU
Find your spot on earth and ride it.
[Re: AZ_A12_BEE]
#1569848
03/01/14 11:42 PM
03/01/14 11:42 PM
AZ_A12_BEE
Dreaming of the 808
Ready for some 440 plucking
37 Plymouth PU
[Re: AZ_A12_BEE]
#1569849
03/02/14 08:45 PM
03/02/14 08:45 PM
AZ_A12_BEE
Dreaming of the 808
Motor and trans coming out
37 Plymouth PU
[Re: AZ_A12_BEE]
#1569853
03/02/14 08:52 PM
03/02/14 08:52 PM
AZ_A12_BEE
Dreaming of the 808
Car motor is out of, 69 Chrysler 300
37 Plymouth PU
[Re: AZ_A12_BEE]
#1569854
03/02/14 08:56 PM
03/02/14 08:56 PM
AZ_A12_BEE
Dreaming of the 808
Engine pad, E440' assembled 1-2-69, HP2, car was built 12-9-68 but this one is close enough for me
37 Plymouth PU
[Re: AZ_A12_BEE]
#1569859
03/09/14 01:55 AM
03/09/14 01:55 AM
AZ_A12_BEE
Dreaming of the 808
Mostly clean, I also pulled all the block freeze plugs and flushed out as much of the junk that I could
37 Plymouth PU
[Re: OhioMopar]
#1569861
03/10/14 03:34 AM
03/10/14 03:34 AM
AZ_A12_BEE
Dreaming of the 808
Looks like the timing chain has jumped, bent push rods.
37 Plymouth PU
[Re: AZ_A12_BEE]
#1569862
03/10/14 02:02 PM
03/10/14 02:02 PM
Posts: 3,127 tennessee,usa
mattsmopars
tennessee,usa
I hope that doesn't turn out worse than the bent pushrods for you. The last 69 Bee I bought was supposed to be a running project. When I got to the point of working on it, it also had bent pushrods on number 1 and 3 cylinders. I got into it and it had dropped a valve on number 3 and busted the piston and the block. So needless to say I had to put a completely different engine in the car. Matt
