Re: Old Cam cores gone and new pricing..ouch
[Re: BradH]
#1564514
01/17/14 12:44 PM
01/17/14 12:44 PM
Posts: 20,145 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Glad i saved all my 750 lift roller cams from the 1970's.
[Re: Sammy]
#1564518
01/17/14 02:02 PM
01/17/14 02:02 PM
Posts: 307 OH
TheBlackCar
OH
First I've heard this. Current Summit pricing does not reflect this.... Perhaps someone quoted you cam and lifters? Maybe Chase will see this and confirm.
[Re: sasquatch]
#1564522
01/17/14 03:47 PM
01/17/14 03:47 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Not true. I ordered some this AM and same price as always. SOME specialty cores are going up but not that much. COMP has had no recent cost increases to speak of. Todd
Specialty cam and 55mm ones got the increase is what I was told Not the off shelf ones
[Re: TheBlackCar]
#1564523
01/17/14 04:26 PM
01/17/14 04:26 PM
Posts: 137 Daytona Beach, FL
cknight
Daytona Beach, FL
Crane had their first steel cam price increase in seven years last July, roughly ten percent on standard journal type cams. Iron gear, larger journal, 9310, and tool steel cams certainly cost more. Regards, Chase
[Re: cknight]
#1564524
01/17/14 05:12 PM
01/17/14 05:12 PM
Sammy
Wind Gap,Pa.
And there you have it. Can't believe a $395.00 comp cam is going to cost me $813.00
[Re: Thumperdart]
#1564527
01/17/14 06:23 PM
01/17/14 06:23 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Try Isky.............I thaught they ground their own cams on their own cores.............
Blanks are forged or cast, not ground. Blanks are like anything else though, not as cheap as they used to be, so just depends on how many blanks "X" company has on hand. Special firing orders, like an LS firing order, require a custom blank, so those are always high. And certain grinds, needed for certain motors, just physically won't fit on older design blanks. So in that case, you are looking at a custom blank or a billet cam. Either of those will set you back a grand
Monte
[Re: Monte_Smith]
#1564528
01/17/14 06:30 PM
01/17/14 06:30 PM
Posts: 2,128 Salt Lake City
camastomcat
Salt Lake City
Monte
Case in point....55mm, 2347 swap, LSM billet, custom grind, $700
[Re: Monte_Smith]
#1564529
01/20/14 11:26 AM
01/20/14 11:26 AM
cknight
Daytona Beach, FL
Good quality roller blanks are machined from steel bar stock. There are many choices of materials, depending on the usage. Regards, Chase Monte
[Re: cknight]
#1564530
01/20/14 05:27 PM
01/20/14 05:27 PM
Monte_Smith
North Alabama
I was speaking of blanks in general as being forged or cast.......While it is true that roller blanks are machined from steel bar stock, there are still "standard" blanks, correct? And when you deviate from this "standard" in lobe selection and it requires a "custom" blank, things get pricey.
I know in my own dealings with BBM nitrous stuff, the lobes I WANT, do NOT fit on the standard blanks that everybody has and we need a custom blank.
Monte
[Re: Monte_Smith]
#1564531
01/20/14 07:59 PM
01/20/14 07:59 PM
Sammy
Wind Gap,Pa.
Monte
That's exactly correct Monty. But now the old stock is gone for the custom lobe cams and those have the sticker shock on them. I'm getting ready to hold my ankles on my invoice from comp cams on my new ground cam with new cores. Stay tuned
