cutting a Dana
#1563212
01/14/14 03:23 PM
01/14/14 03:23 PM
Posts: 21,064 Niles , Ohio
therocks
Niles , Ohio
Going to cut a truck Dana for my 65.I need measurements for the tubes.I believe the center is off set.Anyone have a Dana 60 for a 66 to 67 as they are a bit narrower than the 69 rears.I need measurements for left and right tubes.Im going to make mine 1/2 inch shorter on each side than a stock 65 rear.Rocky
Chrysler Firepower
Re: cutting a Dana
[Re: RobX4406]
#1563214
01/14/14 03:45 PM
01/14/14 03:45 PM
therocks
Niles , Ohio
Thanks that was what I was looking for.I thought they were offset but wasnt sure.I figure with a 1/2 inch shorter and the springs moved in and 1 inch more BS on my rims My 12 inch tires will be happy in the wheel wells.Rocky
Chrysler Firepower
Re: cutting a Dana
[Re: therocks]
#1563215
01/14/14 04:07 PM
01/14/14 04:07 PM
Posts: 4,562 Motor City
6PKRTSE
Motor City
I narrowed mine with the offset as mentioned above. I made my own jig also to keep axle true while welding everything up. I made some aluminum collars that bolted into the carrier with 1-1/2 dia holes. Then some collar for the ends that the new housing ends bolted to also with 1-1/2" dia holes & ran a solid 1-1/2 steel shaft thru the center of everything.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
Re: cutting a Dana
[Re: 6PKRTSE]
#1563216
01/14/14 04:46 PM
01/14/14 04:46 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Over the last 15 years I have narrowed 3 Dana 60s for various projects and if I had the jig like was constructed above, I would be in business doing it in my garage Dana 60s are plentiful in the yards, the basic unit is stronger than anything else out there, the necessary upgrades are cheap, etc.. I have set-up bearings, a chop saw to cut tubes, a case spreader, the experience to build them and the humility to admit that I don't know it all.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
Re: cutting a Dana
[Re: Polarapete]
#1563217
01/14/14 05:20 PM
01/14/14 05:20 PM
6PKRTSE
Motor City
We did it in a garage & for a one time use it worked just fine.
Re: cutting a Dana
[Re: 6PKRTSE]
#1563218
01/14/14 06:19 PM
01/14/14 06:19 PM
6PKRTSE
Motor City
Maybe I didn't exactly word it correctly but essentially it was a knock off of the exact same kit you would by from Mark Williams, Strange or any of the rear ends shops for narrowing a housing.
Re: cutting a Dana
[Re: 6PKRTSE]
#1563219
01/14/14 10:18 PM
01/14/14 10:18 PM
Posts: 3,049 Bowling Green, KY
cudaboy
Bowling Green, KY
Buy the steel rod and find someone with a lathe to make you the pucks. The instructions and dimensions are easy to find.
Dennis
Re: cutting a Dana
[Re: cudaboy]
#1563220
01/14/14 11:19 PM
01/14/14 11:19 PM
therocks
Niles , Ohio
My buddy is a machinist, welder, fabricator with almost 40 years experience.Beside 3 lathes he has all the other equipment in his shop.That and his welds are so good that they look like they are cleaned up after he welds.I guess if you can weld nuclear stuff you must be good.Rocky
Chrysler Firepower
