Re: Dry Sump oil pans
[Re: Lance6611]
#1562831
01/13/14 08:23 PM
01/13/14 08:23 PM
Posts: 52,972 Romeo MI
MR_P_BODY
My dry sump pan was a roundy round pan... the pick ups were on the right side but I welded them closed and run the picks through the pan and exit on the drivers side.. pretty easy... I welded the tubes to the AN fittings then welded the fittings to the pan... sorry I didnt take any pics... I run 2 pick ups in the pan with a wall at the #3 bearing area so 1 pick up is in front of that wall and the other is at the back... plus I put in the one way screen for helping windage
[Re: Lance6611]
#1562835
01/14/14 05:40 PM
01/14/14 05:40 PM
Posts: 901 oh
julian2007
oh
just put a dragster pan on it its almost as short as a drysump pan (I know I run them both ) If you are going to a dry sump system for ground clearance only its a very expensive way to do it. 4000.00 for a system that is not a used bunch of crap. I think a friend of mine has a used dragster pan for sale I think he wants 150.00 for it, I will measure it and let you know what it is.
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: Lance6611]
#1562837
01/14/14 08:28 PM
01/14/14 08:28 PM
MR_P_BODY
I get a very uneasy feeling whenever I brake after a run and the oil pressure goes to 0. I thought the dragster pans are designed for motors that are shut off right after the run. I agree that a pan like that if it could control the deceleration oil slosh would be much easier.
Baffles and trap doors in the pan IF there is oil in the pan
[Re: Lance6611]
#1562838
01/15/14 12:53 PM
01/15/14 12:53 PM
Posts: 901 oh
julian2007
oh
They do have trap doors in them to catch the oil when you lift. I had one going 7.50's all day long with no problem and I never shut it off after a run. Sorry I did not get a chance to measure that pan but I will get to it asap
Bruce
[Re: Al_Alguire]
#1562840
01/15/14 10:32 PM
01/15/14 10:32 PM
Posts: 903 Saskatchewan, Canada
cudabin
OK Al,
I currently have a Charlie's pan on my Cuda, but would be interested in a better pan... What do you recommend? Anyone use o-ring seal?
I hate the oil leaks I am having now. Good thing I have a vaccum pump, but it leaks in the trailer.
Still using torsion bars, and draglink goes through the pan.
Ideas?
Arne
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: cudabin]
#1562841
01/19/14 09:46 PM
01/19/14 09:46 PM
cudabin
Bump! Lets keep talking about oil pans... Arnie
[Re: cudabin]
#1562842
01/19/14 11:12 PM
01/19/14 11:12 PM
Posts: 19,360 Las Vegas
Al_Alguire
Las Vegas
Arnie IMO if you need to run a drag link through the pan thee is not much you can do. My suggestion is find a way to use a dragster style pan and then you can begin to worry about oil control. For what you have a scraper and windage tray is about all you can do.
[Re: rickseeman]
#1562844
01/20/14 04:54 PM
01/20/14 04:54 PM
MR_P_BODY
I have this pump I'm selling pretty cheap... I never ran it but it is a used one(came off a Viper build we were doing then they changed directions).. it had dyno time on it
[Re: MR_P_BODY]
#1562845
01/20/14 04:56 PM
01/20/14 04:56 PM
Al_Alguire
Las Vegas
MrP is that a Dialey pump? If so shoot me a PM
[Re: Al_Alguire]
#1562846
01/20/14 05:02 PM
01/20/14 05:02 PM
MR_P_BODY
Pretty sure thats the name... here is the other side
