Re: CNC Ported Iron heads
[Re: Brian Hafliger]
#1556990
12/31/13 09:10 PM
12/31/13 09:10 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
.100 68 .200 142 .300 201 .400 249 .500 281 .550 290 .600 296 .650 293 .700 294
28" on a 4.030 bore...4.125 bore added 3 cfm at .500 and 4 cfm at .600 and then went backwards but still flowed 295 cfm at .650 lift. Brian
Brian Hafliger
#1556991
12/31/13 09:34 PM
12/31/13 09:34 PM
Posts: 7,506 Az
Crizila
Az
Looks great Brian and the flow numbers are awesome. Mopar Magnums or aftermarket?
Fastest 300
#1556993
12/31/13 09:46 PM
12/31/13 09:46 PM
Posts: 7,506 Az
Crizila
Az
Got a CnC program for the exhaust side too?
Fastest 300
[Re: FastOne]
#1556999
01/01/14 03:13 AM
01/01/14 03:13 AM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Looks good, what does the air speed sound like on the flow bench?, just right, slow, fast, coarse, manometer staying steady, think you know what I mean
Port is very stead up to .600 and then is a bit up and down, not horrible though. Port is pretty smooth actually, very balanced port design
At .700 lift it's not too bad either...just at .630 to .680 it's a bit rough. I can't shape the short turn any better due to water close by.
I'm putting a set on a 392 short block soon with 13:1 and a solid roller so we'll see what she does
Brian Hafliger
#1557000
01/01/14 03:24 AM
01/01/14 03:24 AM
Posts: 20,145 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Did you happen to check runner cc?
[Re: sshemi]
#1557003
01/01/14 06:26 PM
01/01/14 06:26 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Just as the eddy heads are not a full on race head, neither are these! I'll have all the info you guys want tomorrow nite. I'm off today and going to enjoy my family. No matter what they cost, they will always be cheaper than ANY other aluminum head out there and they will hold their own...I hope we shall see. Cost as always will be much cheaper than anything else out there making similar power with better components!!
Brian Hafliger
#1557004
01/02/14 10:57 AM
01/02/14 10:57 AM
Posts: 1,048 The Great White North
RAMM
I too am very curious on the price point and how long these take to machine. Brian, What machine are you using? Also-Will this program fit into an EQ casting? J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
#1557006
01/02/14 05:37 PM
01/02/14 05:37 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
Intake MCA is 2.200 at the pinch.
Intake port poured right at 200cc.
Brian Hafliger
#1557010
01/02/14 10:17 PM
01/02/14 10:17 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Brian, if you'd like some EQ guienna pigs, I have a pair ready to ship. Uh umm, cough, cough...
Seriously, I'd be curious of the pricing with your VJ and valves, if the program was applicable to the EQ's
If you want to send them down, I'll sonic test them and then go from there. I might be able to have EQ send me a head to test...I'll let you know.
PM-ed ya to not clutter up this thread...
#1557011
01/03/14 06:23 AM
01/03/14 06:23 AM
Posts: 429 Washington
skrews
Washington
[Re: BradH]
#1557018
01/03/14 06:10 PM
01/03/14 06:10 PM
Posts: 5,484 SoCal
Brian Hafliger
SoCal
SB right now...I might look at the Victor BB stuff since I have a head but the STD port version seems like a waste of time since everyone's building large cid engines these days....
Brian Hafliger
#1557019
01/03/14 07:16 PM
01/03/14 07:16 PM
Posts: 2,077 Oklahoma City
Jwilli500
Oklahoma City
Since I have a new set of the EQs on the shelf, I would be very interested in this as well! Quote:
#1557039
01/05/14 02:08 PM
01/05/14 02:08 PM
BradH
The thing that bothers me about the Eddy victor BB head is no headers work on the tall deck...I know some headers can be made to work, but a lot of guys like to bolt on headers and go...
The Victor's exhaust port location is identical the MP Stage VIs (I've lined up both heads side by side to confirm this). I have TTI's 2" B/E-body headers for my Challenger that I used w/ my old Stage VIs and it'll be a bolt-in / no-change-required installation when my Victor-headed RB 452 goes back in w/ the TTIs.
The TTI 2" w/ Victor or Stage VI heads are actually a better fit clearance-wise than my previous Hooker 1-7/8" Comp headers w/ OEM iron heads. The only downside is that the starter is captured by the routing of the tubes, requiring the driver-side header to be loosened up and pulled away from the engine to remove it. "Been there, done that."
Also, TTI says their 2 to 2-1/8" Indy RB step header will also work, although I haven't looked into all of TTI's footnotes re: the application w/ Victor or Stage VI heads. I know the standard 2" header is a "no brainer" in my case and don't feel any need to change. I'd actually like to have seen a 1-7/8" to 2" step design offered, but that's just me.
[Re: mopster]
#1557040
01/05/14 02:22 PM
01/05/14 02:22 PM
BradH
I'll probably pi$$ off somebody here, but for this sort of application I think some of you are getting way too hung up thinking Brian's heads having FPS readings being too high and exceeding their "theoretical" max flow limits. Is it "better" if your port design results in measurements that fit within these ideals? Probably. Is it going to kill the head's performance if they don't? Nope. Example: My old Stage VIs were only 213-215cc ported, had a standard 2.20" x 1.20" entry w/ a pinch significantly less than that due to the nature of the port. They flowed 305+ at .600" and made over 600 HP on a pump-gas 440 (10.8 CR) w/ a .600" solid flat-tappet cam. That was enough to push my 3755# (w/ driver) street car to 10.5s at 126 w/ a full exhaust on DOT tires. FPS? Almost 400 over the short turn. Yeah, it would have been nice if the air speed was more in line w/ the ideals and "should" have performed better if they were. But that's what they were AND how they performed, regardless. This ain't Pro Stock stuff here...
