wiper linkage problem #1555868
12/30/13 02:18 PM
12/30/13 02:18 PM
Creedmoor, NC, USA
74Charger Offline OP
Creedmoor, NC, USA
The bar that connects the wiper motor shaft to the linkage on a '74 Charger came loose and is laying in the cowl area. What do I need to repair and re-attach, and where can I find the hardware?
The end of the bar that attached to motor shaft had part of a nylon clip in it, but other end at wiper arm linkage was conmpletely empty.
THANKS!!!
Re: wiper linkage problem [Re: 74Charger] #1555869
12/30/13 02:28 PM
12/30/13 02:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I think you need either Dorman 49447 or 49449 bushing kit. Do a quick online search for those and see if they look like what you need
Re: wiper linkage problem [Re: stumpy] #1555870
12/30/13 02:58 PM
12/30/13 02:58 PM
North Carolina
cjskotni Offline
cjskotni  Offline
North Carolina
Those kits are assortments of bushings of which two will be close to what you need. I am going through this right now and the bushings in this kit are close but just a hair off where my linkage keeps popping out.
I ordered these and am waiting for a couple myself:
http://www.ebay.com/itm/400624894843?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
The linkage takes 4 total of these (assuming 3sp wipers). I would replace all of them if you take the time to pull the linkage.
Re: wiper linkage problem [Re: cjskotni] #1555871
12/31/13 03:02 AM
12/31/13 03:02 AM
MNobody Offline
MNobody  Offline
I found mine on the "help" rack at the parts store
Re: wiper linkage problem [Re: MNobody] #1555872
12/31/13 05:14 AM
12/31/13 05:14 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I have some NOS ones if you can`t find them locally.
