Re: NEED PICS OV VERTICALLY MOUNTED SHOCKS.................
[Re: Thumperdart]
#1555723
12/30/13 02:51 PM
12/30/13 02:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I dont have any pics with leaf springs but its the same as doing a coil over... I use a moly 1 5/8 tube going across the top between the rails... you can cut out the old upper shock mount if you want... on the tube I weld on 2 brackets per shock for a bolt through.. this one is the P-Body
[Re: Thumperdart]
#1555726
12/30/13 03:27 PM
12/30/13 03:27 PM
MR_P_BODY
This one is the Rampage
This looks easier for my application.............Figured instead of a bar goig across from frame to frame I`d weld a plate w/a stud but that also limits any up or down shock adjustments..........
In a coil over type(or even a non coil over type) we normally do any shock adjusting at the bottom to change the body height but then you would have to get rid of the stud mount on the bottom... this pic shows the bottom shock mount(I use the long bracket then once I set the body height to the proper location with the shock travel correct, I cut off the extra length of the bottom bracket)
[Re: MR_P_BODY]
#1555727
12/30/13 03:59 PM
12/30/13 03:59 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Just be sure to keep some distance between the housing and shock/spring assy. You get some housing rotation with a leaf spring, and you can do some damage if there is contact. That last pic would not work(space wise) with a leaf spring.
[Re: MR_P_BODY]
#1555728
12/30/13 04:01 PM
12/30/13 04:01 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Makes sense...........Didn`t really wanna weld on the housing but may as well just do it right the first time and be done w/it plus if I get a Dana, nothing really changes as long as I put em in the same location as the 8 3/4......... Thankxxx........
[Re: mopar65]
#1555731
12/30/13 06:11 PM
12/30/13 06:11 PM
MR_P_BODY
Hey mike you missing a wrench? lol good job on the car build and sorry you didn't make DW.Mopar65
I remembered the wrench... that day I was setting the body height... I still need to replace the coil springs on all 4 corners.. front are too stiff and the rears are a bit weak to have the shocks in the right position.. there is more clearance than you think between the spring and the back brace... but yes a leaf would probably just touch with the extra rap up
[Re: MR_P_BODY]
#1555732
12/30/13 10:05 PM
12/30/13 10:05 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
dont have pics but i mounted mine in front of rear tilted back at 5%, real soft ride, would hook on snott. forgot to say these were Koni-coilovers. 4-link, i'm getting slow at 64
[Re: Thumperdart]
#1555736
12/30/13 11:38 PM
12/30/13 11:38 PM
MR_P_BODY
So does the 6" make the shock vertical ... I never cared for that spacer... all to often it was rusted to the bolt and was a BITSH getting the bolt out.. but might not be a issue out in the dry heat... LOL
[Re: Thumperdart]
#1555739
12/31/13 10:31 PM
12/31/13 10:31 PM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
still using same shocks? just changed angle?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
