Re: Hemi Transplant in my '69 Daytona
[Re: bill_greenwood]
#1552117
06/23/14 12:59 PM
06/23/14 12:59 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
Well, did some more this weekend. Put together some of the lower suspension/torsion bars, heater hoses with the proper routing and modified the MSD Blaster coil with one of ECS's coil label transfers. Came out great !!! That was for all the guys who pointed out the white lettered previous coil...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1552118
06/23/14 01:00 PM
06/23/14 01:00 PM
hemi68charger
Houston, Tx
More of the coil resto.. The transfer went on very well..
[Re: hemi68charger]
#1552119
06/23/14 01:01 PM
06/23/14 01:01 PM
hemi68charger
Houston, Tx
More "stuff" put on.. Heater hoses, etc..
[Re: hemi68charger]
#1552121
06/25/14 12:01 AM
06/25/14 12:01 AM
hemi68charger
Houston, Tx
After a nice and wonderful dinner with the family, Kim can cook !!! I decided to pay some attention to the fuel lines, radiator and well, something else. I straightened some if the radiator core fins that were bend and blow it out with some compressed air. Then I installed the rear and front fuel and vent rubber hoses. Finally, I added a nice touch which is more appropriate now..
[Re: mickm]
#1552124
06/28/14 07:29 PM
06/28/14 07:29 PM
Posts: 2,058 NW/Indiana - Chi town
ricomondo
Congrats!! Love how this all came together!! Post some vids to your you tube channel when it's running.
GY3 71 Demon 340
[Re: hemi68charger]
#1552125
07/02/14 04:26 AM
07/02/14 04:26 AM
Posts: 27,451 So Cal
autoxcuda
So Cal
New brake system means new fluid. I went with this very high temp racing fluid. Under the hood of this Daytona, it can get warm....good stuff...
Very good stuff. But way overkill for underhood temps.
High temp brake fluid is for the 400 degree temps a wheel cylinder my see when the pad is seeing exteme temperatures while on a road course track or someone towing downhill and using brakes hard. I know real 440 Daytonas that go on track days.
If you are boiling brake fluid from underhood temps, you should have a fire extinguisher in one hand and calling the fire dept with the other.
[Re: autoxcuda]
#1552126
07/03/14 10:58 PM
07/03/14 10:58 PM
hemi68charger
Houston, Tx
I am not boiling brake fluid. But, this particular winged car used to have extremely hot engine temps due to low air flow. I attributed it to the exhaust manifolds getting hot and transferring heat into an engine compartment faster than it could get out. The white harness straps for the windshield washer hoses would melt. So, I don't want to take any chances.. A winged car isn't your typical car. Over engineered to me isn't overkill in this regard.... Better safe than sorry....
[Re: hemi68charger]
#1552127
07/04/14 01:51 AM
07/04/14 01:51 AM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Absolutely spot-on...
I'd rather have it...
Then wish I did...
