Re: 318 small block build recomendations
[Re: gtx6970]
#154914
11/22/08 03:26 PM
11/22/08 03:26 PM
Posts: 20,493 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Magnum heads
Raise the compression ratio
Roller cam - not a necessity, but if the money is available...
4" crank - would really run nice, but I wouldn't bother making the engine larger with 318 exhaust manifolds.
Start with a 318 magnum core engine to begin with????
[Re: 68Bullit]
#154916
11/22/08 03:58 PM
11/22/08 03:58 PM
If He isn't opposed to going big block but would rather keep the obvious brackets, etc, then go with a 360 painted 318 red or whatever color it's supposed to be. Still would need headers though. With a 318 or 360, gotta have the headers
This. Truth is, you'll pretty much always get more power for the money if you just build a 360 and drop it in.
[Re: tpabayflyer]
#154918
11/23/08 03:54 AM
11/23/08 03:54 AM
Don't know your budget, but my version of cheap is $1000 or less, so if you go with a 4" crank, pistons would be required, and a basic stroker kit would run you $1500+. Then cost of machine work if needed for an overbore. You could find a 360 from a wrecking yard for $350 or cheaper, freshen it up with rings, bearings, gaskets, to bring you to $500. You would also need a 360 torque converter because the balance is different, so $50-$350 depending on what you want, stock from wrecking yard or basic aftermarket.
If you wanted to stay with the 318, 1992-newer magnum heads can gain you 50hp just by bolting them on, but require a different intake, shorter pushrods, newer style lifters (great time for a mild cam kit, 260-280 degree range, about .470 lift) and 10 bolt valvecovers (which wont look stock.) The magnum valvetrain has an increased rocker ratio of 1.6:1, which turns a .474" lift cam into .506, which is about the max the stock magnum springs can handle anyway. These heads are a closed chamber design, which would raise a stock compression ratio of about 8.2 to 8.8, or somewhere close to that.
Have Fun!! JJ
Edit: 1971 318s had higher compression to start with, 9.0 I think, so the end result may be 9.5-9.7, and the higher compression pistons may be close to hitting the valves in the .510" neighborhood, don't know for sure. And don't bother putting 360 heads on the 318. They do flow better, but have bigger combustion chambers, which will lower the compression ratio, nearly cancelling out any improvements from increased flow.
[Re: Moparmal]
#154920
11/23/08 10:37 AM
11/23/08 10:37 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Basic 318 upgrade.
better cam, small 4bbl carb, good exhaust.
Anything more is ridiculous on a 318.
You want more cubes, don't fool with stroking a 318, you are just turd polishing. Might as well stroke a 360, about the same cost, more cubes, better bore sizing, better choice all around and a virtual bolt in for a 318, a couple of minor issues to deal with.
[Re: gtx6970]
#154922
11/23/08 10:56 AM
11/23/08 10:56 AM
RapidRobert
I'm assuming that it's a running/driving car right now. I would build a 360(same size/all brackets fit) w magnum heads(looks stock) proper piston/head gasket selection to get .035-.040 quench with a CR in the 10's(gives you max efficiency/power) & 68-70 340 HP ex manifolds(you said no headers). mag neads have 318 sized ports so bear that in mind as you select an intake manifold(sb street dominators work well 60-75$). When it's ready to go drop it in & there's less down time & the customer is out the door(& happy) quicker.
[Re: Supercuda]
#154924
11/23/08 02:15 PM
11/23/08 02:15 PM
Posts: 1,586 Tampa, FL
tpabayflyer
Tampa, FL
Basic 318 upgrade.
Well... turdly 318's are avialable usually for free..... a 360 block gives you 408 cubes which is 18 more than the 318 stroked to 390. For any given combo assuming you make 1 hp per cube or a little more you are looking at about 20-25HP less. Does that make it a turd? Is a chevy 383 stroker a turd??? SBC 350's stroked to 383 are probably about the most common stroker combo on the planet and Chevy guys love them. Yet the Mopar crowd seems to turn up their nose at a 390? I just don't get it.
A 390 can be built very cheap. 4" cranks can be had for $325.00 Cheap Eagle SIR rods for $250.00 KB forged pistons for $395.00...... So the reciprocating assembly can be had for less than $1,000 and a 318 stroker with the Eagle rods will not need to have the expense of having the block clearanced. All this can be internally balanced by drilling the counterweights with no expensive mallory metal like the 360 based combo's.
Yes the 3.940 bore is somewhat smaller but there is no problems running even a 2.02 intake valve at all. My 390 uses EQ magnum style iron heads with 2.02 intake valves and it pulls like a big block. TBF
71 Challenger 528 Hemi project 09 Gr Cherokee 5.7 hemi in da house!!
[Re: tpabayflyer]
#154925
11/23/08 02:17 PM
11/23/08 02:17 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Basic 318 upgrade.
I agree, not many people complain about the Ford 289, and definitely not the infamous 302. Mopar guys tend to trash the 318 pretty quick.
[Re: GoodysGotaCuda]
#154926
11/23/08 02:44 PM
11/23/08 02:44 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Popular hot rodding has a 477 hp 318 in it that looks like it would be sweet motor. Peak HP was at 6500 (may have made more past that but thats as high as the test went). It made 427 lbs tq to boot and it used iron heads I have been gathering parts for a stroked 340 for my 68 cuda but I have a real nice 318 short block in there now with SCAT I beam rods and KB167 flat tops to make it nice and light, I am thinking about porting some RHS Iron magnum heads I have and throwing them on and running it that way. Mine would probably be a touch less hp because I have a little smaller cam but I have the parts so I might just do it. PHR says the build is on there site but I can't find it
[Re: tpabayflyer]
#154927
11/23/08 03:37 PM
11/23/08 03:37 PM
Supercuda
About to go away
About to go away
up yours
it's only saving grace
yes, your assumptions are off the mark.
ah, let's bring the most polished turd on the planet into the conversation. The only reason the Chevy 383 is so "loved" is because the even bigger SBC, the 400, is a larger turd than the 350. YOu'll note the only way the SBC 383 makes any decent power is if you dump most of the OEM parts for aftermarket.
probably because ANYTHING you do to a 318 will, I repeat will, show more of an improvement on a 360, including stroking it.
Which will make zero power with 318 heads. Polish away. Cheap crank, cheap rods, hmm, you get what you pay for I guess. BTW, same rods can be used in a 360. BTW, stock 360 pistons weigh less then stock 318 pistons, so why does the 360 need to be externally balanced? The STROKE. If thwe 4" 318 crank has enough weight in the counterweights to allow for internal balance then the 360 4" crank should too. Unless your buying a cheap crank, oh wait.
Ever hear of valve shrouding? 2.02 might fit the bore, but the valves are substantially more shrouded in the 318 bore. As for pulling like a big block, ah no. It pulls like a stroked small block. Put it up against a 440, or a 413, or a 426W and you'll see what a big block pulls like.
Point is you can spend money anyway you want but my OPINION is that your wasting it on a 318 unless that is your only option.
[Re: Supercuda]
#154929
11/23/08 03:57 PM
11/23/08 03:57 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
Get a 360 and build it. For what you'd spend to get 400 hp out of a 318, you could build dang near 2 360's with 400 hp. Built a 390 for a buddies dart and had my little 360 in mine. Same gears and everything and I could walk away from him easy in high gear even if he dropped back to 2nd. Dont even wanna know what happened from a dead stop. As far as the 289's and 302's well they came with some compression and would scream with mild mods, a 318 aint gonna happen like that with out decking the block or changing the pistons to get some compression. 383 Chevys are popular cause they were one of the first strokers and used common GM parts. SB 400's are worthless???? Ha, got a 406 in a 69 Nova sitting here in the driveway, all GM except the pistons. Wanna come show me how worthless the 400's are? Them wheels on the wheelie bars aint skinned up for nothing.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: 70dart360]
#154930
11/23/08 04:23 PM
11/23/08 04:23 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Ok all you 318 mopeds…you need to park your car and stop wasting fossil fuels and most of all bandwidth.. You should not post questions concerning rebuilding a worthless engine, even though it may be the only thing you have at the time because unlike other people, you might have a wife …kids…mortgage and sometimes like to eat… You are not allowed to post any further questions concerning your under powered 318, you should use all your resources that you don’t have cause of items listed above and get that 340/360 engine that you dream about every moment of the day and night Until you have a mighty arsenal of 6 340 blocks…7 360 blocks…6 set of W2 heads…2 set of W5 heads and several set of eddy heads your questions about increasing the performance of a 318 is a waste… And I always thought hot rodding was about doing what you want to do with what ever you have to do it with….also…being a mopar person is being different….so fire up those 318 and run up the rear end of those you say you cant do it…. Ok…I am done ranting….
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Supercuda]
#154931
11/23/08 04:25 PM
11/23/08 04:25 PM
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
I hope you talking about a modified big block. I don't think a stock B,RB, or Hemi can even run with a reasonably built 4" crank smallblock.
