Page 3 of 3 1 2 3
Re: Who sells the most accurate green stamped coil? [Re: ScottSmith_Harms] #1541173
12/04/13 04:33 PM
12/04/13 04:33 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Who made this coil Bill?
I know there was a Made In Canada coil, but for the life of me I can't remember if it was Essex or Prestolite that had a Canadian assy plant
Re: Who sells the most accurate green stamped coil? [Re: gtx6970] #1541174
12/04/13 06:54 PM
12/04/13 06:54 PM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Interesting coil info found on fabo archive
"What is the diffrence in the 2 prong ballast resistor? I see some have .25ohm .75ohm or 1.45ohm is one better than the other? I no nothing about ohms. I have a 67 barracuda electronic ign, burned out what looks like may be the original ballast tonight just wondering what to replace it with.
The ballast should match the coil. So the waters are muddy. Here's the info right straight out of the 67 shop manual, with the coils and resistors ORIGINALLY used, so these are for "points" values
My 74 book, which is paper, is similar
Chrysler / Prestolite 2444242 coil, 1.6--1.79 ohms, 9400 to 1170 (must be 11700) secondary
Chrysler / Essex 2444211 1.41 to 1.55 primary, 8000 to 10200 secondary
Ballast (this is the dual one)
.5--.6 ohms (coil side)
4.75 to 5.75 for other side (feeds the ECU)"
Is it safe to decuct that if a car came with prestolite dist then a prestolite coil would be fitted? It's published in Herd's resto guide the above is correct, yet I know that book is full of errors.
Re: Who sells the most accurate green stamped coil? [Re: srt] #1541175
12/04/13 07:20 PM
12/04/13 07:20 PM
SE PA
MattMPA Offline
MattMPA  Offline
SE PA
The original coil from my Canadian built 1972 "A" body looked just like the 1970-71, etc coils...except it said "Made in Canada". When Performance Car Graphics made the new coil, they had never seen one marked like that before. This was around 2002..
I know, I know, pictures.... I took the pics on a camera that burned to little CDs and my current machine won't read them. I need to transfer from an older computer...then I'll put up a pic.
Re: Who sells the most accurate green stamped coil? [Re: MattMPA] #1541176
12/05/13 12:49 PM
12/05/13 12:49 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Okay, but what was the part number...it changed for the 1972 line...
Re: Who sells the most accurate green stamped coil? [Re: 1972CudaV21] #1541177
12/05/13 06:35 PM
12/05/13 06:35 PM
NB, Canada
moparfan53 Offline
moparfan53  Offline
NB, Canada
FWIW;
The Chrysler '72 parts book shows the coil as part# 2495531 (same as earlier years). The '72 FSM shows the same coil numbers as posted above by srt.
Re: Who sells the most accurate green stamped coil? [Re: moparfan53] #1541178
12/05/13 09:01 PM
12/05/13 09:01 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
part number remained the same up thru at least the mid to late 70's ( maybe later.)
It's the outward appearence that changed
Re: Who sells the most accurate green stamped coil? [Re: gtx6970] #1541179
12/15/13 02:52 PM
12/15/13 02:52 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
I posted these on the "Totally Anal 340 Thread" but thought they should be here as well.
I hoarded these coils up over the years. These are both from 71 Small blocks, the one dated 330 is from an early 71 340, the other might be from a 318, I'm not sure. They are identical in every aspect except the date codes (which are also pretty close). One of the brackets had a gold finish and one has a bracket with a silver finish, these have never been apart and enough original plating is visible to confirm both as genuine.
Re: Who sells the most accurate green stamped coil? [Re: ScottSmith_Harms] #1541180
12/15/13 02:54 PM
12/15/13 02:54 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Both of these have "Made in Canada" embossed in the tops. They are also quite a bit shorter than the other 69/70 coils I have
Re: Who sells the most accurate green stamped coil? [Re: ScottSmith_Harms] #1541181
12/15/13 02:55 PM
12/15/13 02:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Showing the two shorter coils next to two of the longer ones.
Re: Who sells the most accurate green stamped coil? [Re: ScottSmith_Harms] #1541182
12/15/13 02:55 PM
12/15/13 02:55 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Notice how the date codes run across the coils on the short versions and lengthwise on the taller coils. Also notice the gap in the part# ink stamping on the taller coils which is not present on the short coils.
Re: Who sells the most accurate green stamped coil? [Re: ScottSmith_Harms] #1541183
12/15/13 04:46 PM
12/15/13 04:46 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
fwiw... I've only seen the short coils on small blocks. So you have a coil collection too also have a electronic regulator collection
accurate green stamped coil? DATE CODE HELP [Re: 52savoy] #2380465
10/02/17 10:56 AM
10/02/17 10:56 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Speaking of coils, has anyone seen a 4 digit date? Is this 23rd week of 1970? Coil is NOS.
68 Charger
70 Cuda
Re: accurate green stamped coil? DATE CODE HELP [Re: ScottSmith_Harms] #2380653
10/02/17 03:46 PM
10/02/17 03:46 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
I've used 'Almost NOS' coils as well and felt they were extremely accurate.
Re: accurate green stamped coil? DATE CODE HELP [Re: ScottSmith_Harms] #2382671
10/05/17 09:24 PM
10/05/17 09:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Are the coils from M+H even still avail ?
Page 3 of 3 1 2 3
