84 Ram Trucks & Cruise Control #1534969
11/18/13 09:14 PM
11/18/13 09:14 PM
Tennessee
WyleECoyote Offline OP
Tennessee
I'm familiar with the Cruise Control on my 71-74 B-bodies with regard to the fact that it is pretty much a stand-alone bolt on unit easy to add or remove from a car.
How are they on the mid-80's Trucks? The same or are they more involved?
Thanks.
Ron
Wile E. Coyote
Super Genius, Lover of FCA US LLC Products
68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
Re: 84 Ram Trucks & Cruise Control [Re: WyleECoyote] #1534970
11/18/13 09:16 PM
11/18/13 09:16 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
S O S
I am truckless..
Re: 84 Ram Trucks & Cruise Control [Re: 340SHORTY] #1534971
11/18/13 09:28 PM
11/18/13 09:28 PM
Tennessee
Tennessee
So let me guess... You have one of those TOO!
Wile E. Coyote
Re: 84 Ram Trucks & Cruise Control [Re: WyleECoyote] #1534972
11/18/13 09:39 PM
11/18/13 09:39 PM
Northern MN
1E2C Offline
1E2C  Offline
Northern MN
Yeah, it's pretty much stand alone stuff, plug-n-play mostly. The worst part is snaking the wires down the column. The hard part is actually finding one that works yet. Mine's got a bad control unit and I've been through 4 without getting it working.
Mike
Re: 84 Ram Trucks & Cruise Control [Re: 340SHORTY] #1534973
11/18/13 11:13 PM
11/18/13 11:13 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Mine works, and you cant have it...
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 84 Ram Trucks & Cruise Control [Re: WyleECoyote] #1534974
11/19/13 01:06 AM
11/19/13 01:06 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Yep, and it works too. BUT same story, you gotta buy the truck to get it..
do you want the factory AM/FM casset player also??
I am truckless..
Re: 84 Ram Trucks & Cruise Control [Re: hp383] #1534975
11/19/13 01:16 AM
11/19/13 01:16 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The cruise still worked in my 77 CrewCab when I parked it
There's no rocket science to it if you have a fsm
on a side note while we're talking cruise
If you run an aftermarket carb/intake & want to use your cruise You can use these pieces from Bouchillion to do it
If you use their kickdown kit that little hole on the throttle adapter is to put your cruise cable stud/adapter from your original carb
