Need help with 70 RR floor shift column>bearing/pic's #1532145
11/11/13 03:37 PM
11/11/13 03:37 PM
Manistee, Michigan.
High Impact Offline OP
Manistee, Michigan.
I just got a few 1970 dash parts today in trade for some of my 71 B-body stuff and now I have questions.
The steering column is more a core than a good column but I guess it'll have to do. The lower bearing is missing and what-ever holds it in is gone....>Does anyone have picutre's of what it should look like.
Also, the wiring harness is butchered so I;ll need to know where to get the correct one.
Is it hard to pull the main column shaft out to rebuilt the column? I;ve never done such a thing but can it be done without and super specical tools?
Thanks for the help.
Re: Need help with 70 RR floor shift column>bearing/pic's [Re: High Impact] #1532146
11/11/13 04:51 PM
11/11/13 04:51 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Not hard to do persay, but time consuming
Lower bearing looks like this.
Re: Need help with 70 RR floor shift column>bearing/pic's [Re: gtx6970] #1532147
11/11/13 06:24 PM
11/11/13 06:24 PM
Cleveland, Ohio
northcoastmopar Offline
Cleveland, Ohio
Take pics every step of the way
Re: Need help with 70 RR floor shift column>bearing/pic's [Re: northcoastmopar] #1532148
11/11/13 10:39 PM
11/11/13 10:39 PM
Manistee, Michigan.
Manistee, Michigan.
Who sells a new lower bearing? I looked on some of my other columns and they're all missing....must be common.
