Re: KB Street Hemi Block Oiling
[Re: Sammy]
#1530445
11/09/13 11:01 AM
11/09/13 11:01 AM
Posts: 10,384 Upstate NY
Bigcube
Upstate NY
By "up" I assume you mean up to the heads/rockers. Was the block drilled for Hydraulic lifters? It was the only extra cost item when I ordered my block. I had it done so I could use push rod oiling for the top end.
[Re: Bigcube]
#1530446
11/09/13 02:33 PM
11/09/13 02:33 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
No, it was not drilled for hydraulic lifters.I got a external oiling kit from Ray Barton to go from the side of the block up to the lifter galley behind the bellhousing area with -3an braided line and fittings. Tap that with 1/8" threaded T fitting and from inside go to each side of the Barton T &D rocker shaft. Not sure if I need anything else.
[Re: Sammy]
#1530447
11/09/13 10:03 PM
11/09/13 10:03 PM
Posts: 2,915 A shed in England
Tig
A shed in England
Were using -13 wedge heads with the spray bars on a KB block. I know a lot of folk prefer pushrod oiling but we've never had a problem in over 10 years. -3 line from the side of the block then to a t piece and the fitting (restricted) on the valve cover to the spray bars.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#1530448
11/09/13 10:18 PM
11/09/13 10:18 PM
Sammy
Wind Gap,Pa.
Where is your restrictor located in the line? This is good to know. This will be the first time I'm not using pushrod oiling and need to figure out which lifter to use.
[Re: Sammy]
#1530449
11/10/13 06:02 PM
11/10/13 06:02 PM
Tig
A shed in England
The restrictor is located in the t piece that goes to the valve cover. The T piece is tapped and a drilled grub screw is fitted. Don't know what size it is drilled, comes with the Indy kit. HTH's Tig
[Re: Tig]
#1530450
11/10/13 06:33 PM
11/10/13 06:33 PM
Sammy
Wind Gap,Pa.
You got any pictures of your indy kit.
Mine is from Ray Barton.I think they are different.IIRC
[Re: Sammy]
#1530451
11/10/13 07:38 PM
11/10/13 07:38 PM
Tig
A shed in England
Old pic but you can follow the lines if you look hard
[Re: Tig]
#1530452
11/11/13 11:23 AM
11/11/13 11:23 AM
Posts: 2,631 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
If you use the stock type hemi rockers it will be easier. Everything is already set up for that.
2011 Drag Pak Challenger
