winterizing question #1528530
11/04/13 02:43 PM
11/04/13 02:43 PM
Medina, OH
dart440_72 Offline OP
Medina, OH
I am getting ready to store the care for the winter. What do you use, if anything, to seal your headers so critters don't crawl up into the engine? I was looking for a rubber type plug online but didn't see anything. I saw plenty for dirtbikes, but nothing larger.
Re: winterizing question [Re: dart440_72] #1528531
11/04/13 03:07 PM
11/04/13 03:07 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
my dragster has rain caps so i don't worry about that. personally i feel it's more important to oil/fog the engine and back off the rockers effectively sealing the cylinders. for actually capping/sealing the headers you could use just about anything from duct tape to a plumbers plug which should be easy to find
Re: winterizing question [Re: jamesc] #1528532
11/04/13 03:26 PM
11/04/13 03:26 PM
Medina, OH
Medina, OH
That's what I was looking for. I had a problem with mice crawling up in and building a nest. I just wanted something to close off the tubes
Re: winterizing question [Re: dart440_72] #1528533
11/04/13 03:50 PM
11/04/13 03:50 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
http://www.grainger.com/Grainger/CHERNE-INDUSTRIES-Pipe-Plug-1VNG2?Pid=search
This one goes from 3 1/4" to 3 3/4". May be able to get something similar at a plumbers supply as mentioned above. If you have flanges, could just bolt a flat plate on.
