low speed rpm launch #1524858
10/28/13 09:39 PM
10/28/13 09:39 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
I im trying to help a friend that is currently foot braking his car. we would like to launch off the line lock @ 1800-2000 rpm. this car is using a msd 6al box. I have not seen any chips that are less than 3000 rpm... any body have a good ideas thanks
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: low speed rpm launch [Re: WHITEDART] #1524859
10/28/13 09:51 PM
10/28/13 09:51 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Uses standard MSD chips - right?
If so, just use a 1.5k ohm pot. Go to radio shack or wherever and get a 1500 ohm potentiometer. Center tap to either one of the other tabs and you are good to go.
I would need to look better at my data, but I believe 1800 rpm would be around 650 ohms and 2000 rpm would be around 860 ohms.
You can also use regular resistors.
For my leave point, I use a modified potentiometer and use a 10 turn pot with a locking dial. I just look up the rpm I want on my spread sheet and set the dial and I'm pretty close.
Re: low speed rpm launch [Re: markz528] #1524860
10/28/13 10:06 PM
10/28/13 10:06 PM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
MSD Ignition 8677 a chip you adjust with a small screw driver from 1k to 3k
Re: low speed rpm launch [Re: markz528] #1524861
10/28/13 10:06 PM
10/28/13 10:06 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Tony
70 AARCuda Vitamin C
Re: low speed rpm launch [Re: markz528] #1524862
10/28/13 10:07 PM
10/28/13 10:07 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Re: low speed rpm launch [Re: markz528] #1524863
10/29/13 01:19 AM
10/29/13 01:19 AM
fresno ca
mikeysmopars Offline
fresno ca
I need him on my pit crew!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: low speed rpm launch [Re: mikeysmopars] #1524864
10/29/13 03:09 AM
10/29/13 03:09 AM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
As stated ,the adjustable MSD chip is what I used when I used a transbrake to run the wheelie thing at the nationals one year.
Word of CAUTION
If you are`nt running enough octane combined with that low RPM limiter it will beat your engine to death.
I have a set of pistons with the top ring lands that look like wafer-springs .
Car started running slower as soon as I started using a 2-step and brake.
Assumed it did`nt like the brake WRONG 2-step caused detonation against the converter
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: low speed rpm launch [Re: 6bblFLASH] #1524865
10/30/13 03:34 PM
10/30/13 03:34 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I used the air activated throttle. Push button pedal goes to floor to a set rpm, release button and air pulls throttle open, no stuttering very consistent. Can be run with box or off last light.
