Re: Desert Cooling
[Re: savoy64]
#1524746
10/28/13 10:50 PM
10/28/13 10:50 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Before you put a new rad in, I'd do a thorough flushing of the coolant passages in the block and heads to get rust and sediment out.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Desert Cooling
[Re: DusterDave]
#1524747
10/28/13 11:58 PM
10/28/13 11:58 PM
Posts: 10,524 Freeport IL USA
poorboy
Freeport IL USA
And after you get the radiator of your choice, remember air has to be able to flow through the radiator, not around, over or under it, and then, after the air passes through the radiator, it has to get out of the engine compartment. If the air can't get in to flow through the rad, and back out of the engine compartment again, the biggest, baddest, radiator in the world is going to have problems. Gene
Re: Desert Cooling
[Re: 360view]
#1524750
10/29/13 11:42 AM
10/29/13 11:42 AM
Posts: 1,509 AZ
Mike P
AZ
As far as a radiator I've had good luck with the Champions radiators sold on E Bay. Pick the biggest one that will fit without major modifications.
For fans my recommendation would depend on how the majority of the miles will be put on it. If it;s mostly highway or non-stop and go miles a 7 Blade fan and Haden Heavy Duty (thick)fan clutch would probably be best. They hit lockup at 210 degrees and even during the summers down here I haven;t had an engine get above that. If you hit stopped traffic or very slow moving traffic, you may have to throw it in a lower gear or even neutral though to flow enough air to keep the engine cool.
If you get into that type of traffic on a regular basis then my suggestion would be to get the best electric fan you can find instead of a mechanical one.
In either case use a fan shroud.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: Desert Cooling
[Re: hemicop]
#1524751
10/30/13 11:29 AM
10/30/13 11:29 AM
Challenger 1
Cincinnati, Ohio
My 340 idled in Vegas this past July for over a hour in 110 degree temps. My car could idle all day long in those temps and not overheat. The cooling system is stock with a 26" radiator and a 7 blade clutch fan. The motor is not stock and tuned correctly, it has edlebrock heads, Victor jr 340 intake and a 474" MP cam. Oh yea it has AC too which was running the whole time in Vegas. There's no heat risers in edlebrock heads, just so you know. I have driven the car in Reno, Bonneville, Pikes peak all on 90+ degree days and it has never overheated. Stock is where it's at when it comes to mopar cooling, there's nothing better IMO. I just got done running 100+ mph into Bonneville on this 95 degree day, my AC is on now in this video. It stays on all summer. And my car is black! [image]http://s21.photobucket.com/user/challenger19711/media/2012%20Badlands/BonnevilleWendover2012049.mp4.html[/image] web page
