70 B body bench seat ????'s #152256
11/17/08 12:12 PM
11/17/08 12:12 PM
La Grange, Ky
70rrclone Offline OP
La Grange, Ky
I am sitting in a hole now thanks to a broken seat spring. it looks like a whole section may be broke out. ( when it broke it flopped out into the rear floor board). can this be repaired? or will i have to find another seat.
is anyone using aftermarket seats in there B body.
if so what are you using.
thanks shane
Re: 70 B body bench seat ????'s [Re: 70rrclone] #152257
11/18/08 08:37 AM
11/18/08 08:37 AM
St Charles MO
70Coronet500Vert Offline
St Charles MO
You will have to replace the spring which means disassembling the seat.
I don't think a weld to a spring will really work very well.
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: 70 B body bench seat ????'s [Re: 70Coronet500Vert] #152258
11/18/08 09:02 AM
11/18/08 09:02 AM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Wow, I asked this same question yesterday in the restoration section. It was suggested to me that they actually can be welded. No matter what the seat has to be disassembled. You would have to disassemble the seat, though. It did not sound as if you could get the spring piece as a new unit. If you do find a source for the spring piece new please contact me.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: 70 B body bench seat ????'s [Re: David_in_St_Croi] #152259
11/18/08 03:46 PM
11/18/08 03:46 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I would think that all you would have to do is find a good spring from another seat. maybe one that also broke but still has good springs left.
And again you will need to disassemble the seat.
Do you need new covers now would be the time.
probably need new foam as well.This is the rear seat from a 68 b-body the springs should be about the same in a front bench.
