Late modle transmission gurus, 545RFE problem #1522261
10/23/13 09:26 PM
10/23/13 09:26 PM
Friendly, WV
wedgeheaded Offline OP
Friendly, WV
I have an 06 QC 4x4 with a 4.7/auto and 160K miles. The other day the truck kind of shuddered and I got the little engine icon light. It was raining and I just figured I'd gotten something wet. When we scanned the code it was a transmission issue. (The guy reading the trouble code was reading it through the engine side and not the transmission side, so it only said I had a transmission trouble.) I had the filters and fluids changed but it did it again tonight. Any suggestions? I'm not wanting a rebuild right now.
Re: Late modle transmission gurus, 545RFE problem [Re: wedgeheaded] #1522262
10/23/13 09:31 PM
10/23/13 09:31 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Take it to a trans shop and have the codes read before you try anything else. I think some do it for free.
Re: Late modle transmission gurus, 545RFE problem [Re: wedgeheaded] #1522263
10/23/13 11:09 PM
10/23/13 11:09 PM
Temecula, Ca.
Z
zzyzxpat Offline
zzyzxpat  Offline
Z
Temecula, Ca.
If he was reading the engine side, he would have seen a P0700 code, which means there is a trans code on the trans side.
Stumpy is correct, you need the code(s) read properly to have a basis to start.
Pat
" The last official act of any goverment, is to loot the treasury" George Washington
Re: Late modle transmission gurus, 545RFE problem [Re: zzyzxpat] #1522264
10/24/13 07:43 AM
10/24/13 07:43 AM
Friendly, WV
Friendly, WV
Yep, that's my plan. I just was hoping to get a heads up on what might cause the shudder. It will be Monday before I can do it but when I know, I'll re-post. thanks
