Re: Ugh.. never ending! Front end alignment
[Re: cal_gecko]
#1519752
10/18/13 09:03 PM
10/18/13 09:03 PM
Posts: 549 WV
JohnH
WV
I aligned front ends in the 70s on these cars. You can lower the torsion bars down to lower the front end, this will change your camber, if you don't have any shock bounce your way too high. get it on the front end rack, lower your front end until the car is slightly lower in the front, first check your air pressure, then lower it,, bounce the front end several times, then go to the rear of the car, stand back several feet and see if the car looks level to you, then do your front end alignment, get all the pos. caster you can get, this keeps cars from road walking, if you can't get the camber to come in, raise or lower the car with torsion bar adjustment see if it will come in.. if you readjust the bars go to the rear again to see if it looks level..
[Re: Pacnorthcuda]
#1519755
10/18/13 09:38 PM
10/18/13 09:38 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Take the car to Linville Brothers on El Camino near I-80. They are the only ones I trust with my cars, and the Ram. Prices are fair and they do excellent work.
[Re: buildanother]
#1519758
10/19/13 10:11 AM
10/19/13 10:11 AM
Posts: 4,936 WI
Dcuda69
WI
They should be able to align it for you, and many A arm cars do become quite negative on camber when raised up too high.
This^^^ SLA(short/long arm suspension) cars will go negative camber when raised up. Drop it with a T-bar adjustment to where you want it and have it aligned..you'll be good to go.
P.S. Do not use the factory specs.....do what these guys are saying.
[Re: Dcuda69]
#1519759
10/19/13 01:13 PM
10/19/13 01:13 PM
Posts: 12,589 Sacramento, CA
cal_gecko
Sacramento, CA
Thanks guys!! This makes me feel better, knowing that it's normal for it to go negative when it goes too high. I'll work with the guys at the shop on getting the basic alignment set up the way you've suggested.. .Frankenduster, I may give your place a shot for the final recipe too.. thanks!!!
Guys - I'm getting stoked - the car is SO close to being done.. it's got ALL windows in it now, electrical/headlights/wipers all work, oil leak is fixed, exhaust is now done..
next up - alignment, install new (aftermarket retractable) seat belts, and check the rear end because they noticed it was whining a bit ... and then I'll get it back!!! I'll bring it back to them in a few weeks to have the rear seat finished up (I ordered a new cover from Dante, which will take a couple weeks to get to the shop).
I'm sure that when I get it back, there's still gonna be some things to work out, little gremlins and such.. so I'm sure I'll be posting more on the QA section. Can't wait to get it on the road - it's been 10 years since I bought the car and I've never driven it.. but SOON!
[Re: cal_gecko]
#1519760
10/19/13 02:10 PM
10/19/13 02:10 PM
Posts: 21,808 Kirkland, Washington
Pacnorthcuda
Mark, not that it really matters since you will be getting an alignment, but lowering the front will move camber to the negative, raising it will move it to the positive. In your case lowering the height will make your already excessive neg camber even worse.
[Re: ahy]
#1519765
10/21/13 10:38 PM
10/21/13 10:38 PM
Pacnorthcuda
Yes TB's need to come out for strut rod bushings. If other parts have not been replaced yet (tie rod ends, ball joints, LCA bushings, UCA bushings) now is the time to do it while its apart. As you have seen, the cost is mostly labor. As posted above, its not that bad to DIY. A factory service manual and a few tools make it straight forward. I use Mancini's front end tool kit with good results.
Exactly, it's a 40 plus year old car, do it all now, and put in offset bushings in the UCAs.
[Re: Pacnorthcuda]
#1519766
10/22/13 12:41 AM
10/22/13 12:41 AM
RapidRobert
If they're shooting you a quote of $600 then bring it home & do it yourself then get it close as I described then drive it back there to be aligned. EDIT I have my doubts that the strut rod bushings are bad & they are just trying to get over on someone (but I ain't there & they could be bad), save em & post pics
[Re: cal_gecko]
#1519770
10/22/13 01:05 PM
10/22/13 01:05 PM
Triple Threat
Renton Washington
MY opinion, just pay them to do it. To do the strut rods and Idler they're going to have a lot of it apart anyway. Just have them rebuild and align it, and you wont have to worry about it again for years. If they do half the work now, align it, and then you have to do more later, its going to need aligned again. You're better off spending the $600 to have it done. Then take that weekend you would have spent rebuilding it this winter and go snap some pictures to pay for it. Judging by the 10 years it took to get to this point, you're better behind the lense, then you are with a wrench. Play to your strengths, and let those guys do the same.
