Re: EMC 2013 470 B stroker build
[Re: RAMM]
#1518988
10/24/13 09:16 PM
10/24/13 09:16 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
1. Plunger travel on these were limited to .015"
thanks for the info. one more question.....
so, are those lifters sort of like a Schubeck style lifter internally?(meaning there isnt really any check valve system in place......and the plunger just bottoms out when it starts working against the spring pressure) so instead of it really being a hydraulic lash compensator, its really just a means of providing a "cushioned lash".
Schubeck's have about .015 travel, but they arent a true hydraulic lifter. the Comp limited travel lifters are supposed to be a "real" hydraulic lifters, but they supposedly have .050 plunger travel(and arent available in a .904 version yet).
[Re: RAMM]
#1518990
10/26/13 11:38 AM
10/26/13 11:38 AM
Posts: 1,051 The Great White North
RAMM
Here is a trimmed video of our last pull at UNOH. J.Rob EMC2013finalpull
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
