Will a newer LA engine transmission fit a poly 318?
#1518597
10/16/13 10:23 PM
10/16/13 10:23 PM
Posts: 12,043 State of Confusion
hp383
Just a normal tag again
State of Confusion
Does the Poly 318 share the same transmission bellhousing bolt pattern as the LA 316-360?
Join the Penguin Liberation Front!! Stop the Hippo Occupation!
Re: Will a newer LA engine transmission fit a poly 318?
[Re: hp383]
#1518598
10/16/13 10:38 PM
10/16/13 10:38 PM
Posts: 21,050 Niles , Ohio
therocks
Niles , Ohio
The same except one bolt dosent line up.Did the swap on the 66 Charger my kid had.We used the poly trans though.Rocky
Chrysler Firepower
[Re: dogdays]
#1518600
10/17/13 02:48 PM
10/17/13 02:48 PM
Posts: 2,826 NY usa
540challenger
NY usa
If you are using an auto trans the LA style convertor with not fit into the back of the crank. The crank opening is too small
[Re: 540challenger]
#1518601
10/17/13 02:58 PM
10/17/13 02:58 PM
hp383
State of Confusion
This would be for a manual trans. Have a line on a poly bell and wanted to know if it would fit a 360.
Looks like not to much to make it work.
[Re: hp383]
#1518602
10/17/13 03:57 PM
10/17/13 03:57 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Possible poly. What year did they stop production? Guy has a couple 4spds(bellhousing included)and tranfercases. 1 is suppose to be bigblock and the other small. He sounded like a much older gentleman and had no way to send pics si I have to drive about 2hrs to see them. He thinks their late 60s but one is supposedly a married setup. I didnt go into detail with him on them. Thanks
[Re: b1dartsport]
#1518605
10/17/13 05:37 PM
10/17/13 05:37 PM
Andrewh
