gluing plastic grill #1518519
10/16/13 06:51 PM
10/16/13 06:51 PM
Streetsboro,Ohio
70dart318 Offline OP
Streetsboro,Ohio
Re-cracked one of the mounting tabs bolting the gril in, i need something GOOD that you have used on yours that works. I know someone here will have a solution.
Re: gluing plastic grill [Re: 70dart318] #1518520
10/16/13 06:52 PM
10/16/13 06:52 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
I would use epoxy. Maybe the regular kind, but probably a "stick" epoxy that you can shape and mold. Or both if you are quick! gotta scuff up and clean the area. you can easily re-attach the piece and even mold the stick epoxy around the break and shore it up
plus, epoxy can be sanded later and painted
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: gluing plastic grill [Re: 70dart318] #1518521
10/16/13 08:50 PM
10/16/13 08:50 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
Here's my post on repairing my 70 Superbee grills.
ABS Grill Repair
Special thanks to Scott Smith for the tips.
I’m listening.
Re: gluing plastic grill [Re: Big Bad Bee] #1518522
10/16/13 09:44 PM
10/16/13 09:44 PM
Loves Park, IL
HotRodRailroader Offline
Loves Park, IL
I cleaned mine well and used a clear Gorilla brand 1 min set clear epoxy. I made sure it squished out a bit when I put it on. then lightly sanded and touched up with paint still on and put on 15000 miles since then.
Re: gluing plastic grill [Re: HotRodRailroader] #1518523
10/17/13 05:23 AM
10/17/13 05:23 AM
MN
astrobuf Offline
astrobuf  Offline
MN
Use the 3M plastic parts repair material. Epoxy has inferior material properties. Not flexible enough for stressed parts.
Astrobuf
So, are you really a Rocket Scientist?
Re: gluing plastic grill [Re: 70dart318] #1518524
10/17/13 05:59 AM
10/17/13 05:59 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Bring that thing to me Lori, I'll fix it right no charge to you lady.
Re: gluing plastic grill [Re: HEMICUDA] #1518525
10/17/13 11:39 AM
10/17/13 11:39 AM
Jefferson State
srt Online content
ESYC
srt  Online Content
ESYC
Jefferson State
I'll toss this devcon product in the mix for others that check this thread.
Re: gluing plastic grill [Re: 70dart318] #1518526
10/17/13 09:11 PM
10/17/13 09:11 PM
tucson az
frank Offline
frank  Offline
tucson az
The grill in my 68 Charger was cracked in a couple of places. I used ABS cement and ABS plastic to reinforce the repair area. The repair area is stronger than the rest of the grill; much stronger
