4 spd clutch fork #15177
04/09/05 01:11 AM
04/09/05 01:11 AM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
A friend gave me a shift fork that he thinks is for a b body but he's not sure. There is no part numbers that I can find but I have attached a pic. I am getting ready to install a 833 in my '69 Coronet 500.
Who can tell me what this will fit?
Re: 4 spd clutch fork [Re: VITC_GTX] #15178
04/09/05 02:12 AM
04/09/05 02:12 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Can a mod put this thread under the Tech page.
Sorry...
Re: 4 spd clutch fork [Re: VITC_GTX] #15179
04/09/05 08:25 AM
04/09/05 08:25 AM
the length of the fork tells you what it fits the hemi (large flywheel) is 12.5 inches overall length. I have spare bell and fork for the 10.5 flywheel.
Re: 4 spd clutch fork [Re: VITC_GTX] #15180
04/09/05 08:40 AM
04/09/05 08:40 AM
Western Pa
farmboy70 Offline
farmboy70  Offline
Western Pa
Last week when installing clutch in my Roadrunner I talked to Brewers about fork length. He mentioned forks with sloted hole in the end were E- bodys. You may want to call them to be sure.They can answer any four speed question and have almost anything needed for manual cars.
Re: 4 spd clutch fork [Re: VITC_GTX] #15181
04/09/05 10:31 AM
04/09/05 10:31 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what enegine size and whats the part number of the bellhouing being used .
the big blocks used the short fork , for the most part , and small blocks used the long fork , that looks like the smallblock fork used with at least the 70's alum bell
Re: 4 spd clutch fork [Re: JohnRR] #15182
04/09/05 11:50 AM
04/09/05 11:50 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
The fork for SB and BB E/B bodies is the same. Like 10.75" The long forks, I'm pretty sure are for A bodies.
Re: 4 spd clutch fork [Re: 71TA] #15183
04/09/05 02:21 PM
04/09/05 02:21 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I was going with a 440 in this car. I don't know what kind of bellhousing I have right now. I need to figure out how to do that (see my other post regarding flywheel size).
Looks like I have the wrong fork.
Thanks for the help.
Re: 4 spd clutch fork [Re: VITC_GTX] #15184
04/09/05 04:57 PM
04/09/05 04:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
According to the factory parts book the choice of fork depends on the body, not the motor.
Re: 4 spd clutch fork [Re: John_Kunkel] #15185
04/09/05 06:22 PM
04/09/05 06:22 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Anyone have a fork for a 69 B body with a big block laying around? If so, can you measure/compare to the one in the pic I posted?
Thanks.
Re: 4 spd clutch fork [Re: VITC_GTX] #15186
04/09/05 06:56 PM
04/09/05 06:56 PM
Western MD
egros Offline
egros  Offline
Western MD
I can measure. Mine is all torn apart. Give me a little bit.
1970 Plymouth Road Runner, RM23N0A, 383 4-Speed
Re: 4 spd clutch fork [Re: egros] #15187
04/09/05 07:28 PM
04/09/05 07:28 PM
Western MD
egros Offline
egros  Offline
Western MD
70 B Body, egine and bellhousing is 69 Dated. 383, 4 speed, all stock. I have 10.5 inch bellhousing.
Looks to be about 10.5 inches.
Re: 4 spd clutch fork [Re: egros] #15188
04/09/05 07:47 PM
04/09/05 07:47 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Hey, thanks Egros. I appreciate the time you took to help me out.
Good luck with your engine bay.
