360 Timing for Emmision Testing #1518371
10/16/13 11:51 AM
10/16/13 11:51 AM
Tucson, Arizona
clonestocker Offline OP
Tucson, Arizona
I'm trying to get a 300/360 Crate motor to pass emissions. I put to dist. back to vacuum advance. What should the timing be set at w/Vacuum advance disconnected at idle?
thx matt
[img] [/img]
Re: 360 Timing for Emmision Testing [Re: clonestocker] #1518372
10/16/13 04:27 PM
10/16/13 04:27 PM
Maybe TDC. You want it pretty retarded which is what Ma did back in the 70's in some cases to pass emissions. Keeps the nitrogen (nitrides?) of oxides (NOX) to an acceptable level. Not sure if subbing in a tamer cam would be something you'd want to do to get it to pass or if that would even be needed but you gotta do what you gotta do. At TDC it may need a milder cam to even run somewhat. Keep searching & here's a BTT for ya
Re: 360 Timing for Emmision Testing [Re: clonestocker] #1518373
10/16/13 05:45 PM
10/16/13 05:45 PM
Truckville, the capital of NY
85_Ram_4speed Offline
If that is a magnum 300hp/360 crate, I think if I remeber right that is a bone stock magnum 360 long block with a carb intake on it. So not much really tamer could you get on the cam.
As said, retard timing to 0 TDC as Ma Mopar did, and lean the crap out of it. It will run absolutly terrible, but if it gets you by, then down the road after inspection you can break out the tools and fix it for the ride home.
Outcast Dodge guy.
Re: 360 Timing for Emmision Testing [Re: clonestocker] #1518374
10/16/13 05:47 PM
10/16/13 05:47 PM
Northeast
V
VincentVega Offline
VincentVega  Offline
V
Northeast
Changing the oil can also gives you a tiny boost to the emissions. Dirty oil WILL impact the test results.
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
Re: 360 Timing for Emmision Testing [Re: VincentVega] #1518375
10/16/13 07:46 PM
10/16/13 07:46 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Find out the maximum allowable idle speed. That will usually help if you set it up there along with the crappy real close to TDC initial timing setting
Re: 360 Timing for Emmision Testing [Re: RobX4406] #1518376
10/18/13 02:58 PM
10/18/13 02:58 PM
P
Paul_Fancsali Offline
P
I found removing the air filter actually lowers emissions on a carb engine hence pass
