New guy with a question
#1516285
10/12/13 07:45 PM
10/12/13 07:45 PM
Posts: 88 KS.
HairOtheDog
KS.
Hey guys, first post here and i wanted to say "hi". I've also got a bit of a problem that I've run into with my 67 Satellite, specifically the 727 trans. I'm trying to install a driveshaft, but it seems that the 2 driveshaft yokes that I have will not slip onto the output shaft of the two 727 transmissions that I have, it acts like the yokes are to small (?). I'm really baffled by this, i was under the assumption that, all 727's output shafts were the same (?). I went this morning and bought another driveshaft/yoke from a 1970-1972 duster with a 727, but it doesn't fit either. The One spare 727 I have, I was told, was from a 66 family car (big car) and the 727 in my 67, I was told, was from a truck BUT both output shafts on both trans are the same/identical. Neither trans has a brake (RV) and no transfer case mounting. Ill try to attach some pics, if I'm able but ANY help would be GREATLY appreciated, thanks.
Re: New guy with a question
[Re: HairOtheDog]
#1516289
10/12/13 09:05 PM
10/12/13 09:05 PM
RapidRobert
Welcome aboard! Yes some yokes have the splines at a differnt depth inside the yoke & not sure what the app/reason for that is but you want the most spline engagement you can. Any chance you are trying 904 yokes
[Re: RapidRobert]
#1516290
10/12/13 09:59 PM
10/12/13 09:59 PM
Posts: 88 KS.
HairOtheDog
KS.
Thanks! You may be onto something there, I know the 904 yokes are smaller (ID). I was wondering if the long yoke I have is for a 904 (?), (I wish there was a number on them to identify them). The shorter yoke I bought today was SAID to be for a 727, but now I'm starting to wonder (?). Is there anyway to tell them apart? I put some black multi grease on the beveled edge of my trans output shaft and spun the yoke around, you can see in pic 2 i think, the black grease ring (smear) around the beveled yoke edge, it looks to small.
Anyone have a spare KNOWN 727 yoke they'll swap me for one of mine?
[Re: HairOtheDog]
#1516291
10/12/13 11:14 PM
10/12/13 11:14 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The only Dusters with 727s that I have seen were 340 cars..
I am truckless..
