How do you have your Holley Double Pumper tuned?
#1516132
10/12/13 02:45 PM
10/12/13 02:45 PM
Posts: 551 Great Lakes State
ONEBADBIRD
Great Lakes State
I have the car on the road and running good all summer. My question is is how do you have your Holley set up for good performance and the best mileage possible. I know every engine setup is different, just want to know what is working best for you? In my 69 Road Runner, I have a rebuilt 440 (30 over) with 9.5 compression,flat top zero decked forged pistons, rebuilt iron 906 heads, and a comp cam 268 xe cam, stock iron intake, and a Holley 4150 750 cfm double pumper with mechanical secondaries. I am hooked up to a 727 trans, and rear with 3:55 gears. My carb is set up like this: jet primary side 74 jet secondary side 80, pump nozzle primary side 35, secondary side 31, power valve on primary side 5.5 secondary side blocked off. Running a new fuel tank and 3/8 fuel line. Thanks
Re: How do you have your Holley Double Pumper tuned?
[Re: ONEBADBIRD]
#1516133
10/12/13 07:49 PM
10/12/13 07:49 PM
Posts: 12,019 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The DPs are essentially race carbs. And as such are rather rich in the transitions. The wide open is typically okay, but on a street car, the off idle and cruise are very rich.
On a milder engine, jetting down the slots will clean that up. And then going a few steps smaller on the mains, opening up the PVCRs to compensate and then getting a little quicker opening power valve will help clean the cruise up without sacrificing performance.
An O2 sensor makes this more accurate, but can be done without it. You will have to guess and then experiment on the main jets, but you can do the math to get the PVCRs to the right balance.
Master, again and still
[Re: Mr.Yuck]
#1516136
10/13/13 01:17 PM
10/13/13 01:17 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Guys are giving you vague suggestions. You need to have the timing set first, about 35 degrees total to possibly 38 degrees. That is a total all in by 2500 without vacuum advance. With vacuum around 45 to 50.
The 750 double pumper is a bit much for an automatic with your cam and gearing. A 650 DP would be better but don't throw out what you have. Set floats correctly first, front just under hole where you have to shake car slightly to drip out. Rear a tad (and I mean a tad) higher. Power Valve is determined by the engine vacuum. Car fully warm IN GEAR (brakes set and tires blocked)with a vacuum gauge hooked up adjust idle screws to highest vacuum reading. let's just say the highest steadiest is 18". Half that # and add .5 to it so in that case 9.5 is the optimum PV for the set up. In this case a PV with say 11 tamped on it would be too rich and a PV with a 4.5 on it would be too lean. The # stamped on them is the vacuum opening value. Jetting is determined by power test runs or dyno. I'd look up what Holley lists your 4779-? as stock jetting and go up or down two sizes with much testing. Squirter and accelerator cam/position is determined by throttle response.
Also many people don't know how to properly set the accelerator pump arm clearance which can either produce and off idle stumble or tear the diaphragm. With engine off holding throttle fully open you need to measure with a feeler gauge the clearance between the pump arm and the pump lever.
3 hands make this easier to do, OK so throttle is held at WOT and use something like a small open end to push pump arm down fully, now measure the clearance between that pump arm and pump lever. I like using 8 thousands but any thing between 1 th to 15 th is good. You just want to make sure there is a small clearance to not tear accelerator pump gasket. I've seen carbs. with 1/8" clearance and guy's wonder why does my car POP or stumble when I rev it.
Hope this helps Ron
[Re: RobX4406]
#1516139
10/13/13 11:39 PM
10/13/13 11:39 PM
Posts: 1,682 Philadelphia
radar
Philadelphia
I have mine tuned with thicker and thicker wires stuck in the IFRs until the idle mix screws came out to 1.5 turns from seated to best vacuum. Then slightly bigger IABs finished cleaning up the low throttle cruise which formerly fouled the plugs quickly unless I blew it out on the highway. The Power Valve and PVCRs are tuned to give sharp low throttle manners and economy until passing power is needed- then at the point where the conservative primary jets become too lean and vac drops with throttle opening the PV opens and richens the mix back up to max power. My secondary is opened along with the primaries at idle to reveal square sections of transition slot. I run a plugged 2nd PV and big jets for best times at WOT. I watch my vac on the big end to make sure my primary PV doesn't close at high rpm creating a lean condition. Good luck with yours
[Re: ONEBADBIRD]
#1516142
10/14/13 09:30 AM
10/14/13 09:30 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Since it is apart, now is the time to wire down the IFRs. That way you can get the idle screws out to the 1 1/2 range and clean up the off idle transition a little.
[Re: ONEBADBIRD]
#1516144
10/14/13 06:04 PM
10/14/13 06:04 PM
Posts: 43,123 Bend,OR USA
Cab_Burge
School me on what IFR's are? ,and why should I wire them down? In your earlier post, you mentioned PVCR's also? Power Valve Circuit something? Still learning these acronyms. Thanks, Jay
IFR can mean either the idle fuel feed or the intermediate fuel feed, they are part of the main body and to change them you need to drill and tap and use a blank brass set screw and drill it smaller than the stock passage was to lean them out, make them bigger to enrichen them, confused yet PVRC means the power valve restiction channels in the metering blocks behind the power valves, same process on them to change them. Holley has normally made the idle fuel feed, transition fuel feed and PVRC larger than needed to run clean and lean like most Mopars like it The transition slot is the rectangular slot in the throttle body that is centered where the throttle blades ride in the primarys, the four corner idle circuit carbs. have them on all four corners. Not all Holley carbs. have a intermediate circuit in them, some of the bigger race carbs do IHTHs BTW, if you look on the front of the choke tower you will see some numbers stamped into it like List 4779 or List 4779-4 or some other number after the dash if it is not one of the original 4779 before Holley started making modifications to the original design Let us know your carb and dash number
[Re: ONEBADBIRD]
#1516147
10/14/13 09:40 PM
10/14/13 09:40 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
IFRs are the Idle Fuel Restrictors. One for each barrel. They meter the fuel to the idle screws. The Idle Air Bleeds in the throat of the carb meter the air. Together, they provide the ratio for the idle mixture. The adjustment screws are simply a volumn adjustment. If your adjustment screws are only 3/4 turns or so out, then the mix is usually too rich. If so, then you can either size the IFRs down or you can open up the IABs. I like to size the IFRs down first, that way I don't mess with the timing of the main circuit. The proper way to adjust the jetting on the IFRs is to drill and tap them for jets. But what I do is to mike a bunch of strands from some 12 to 16 guage electrical wire and use pieces of that inserted in the IFRs to see what the engine likes. Quick, easy, cheap and effective. I leave them in when I get them about right, but a guy could go back and drill and tap them for the jets. PVCRs are the Power Valve Channel Restrictors. They are the holes under the power valve and are essentially jets. The main jets plus the PVCRs add up to the total amount of fuel being fed. Which is why you step the mains up when you block off the power valve. The mains must be larger to compensate for the PVCRs no longer flowing any fuel. The PVCRs can be drilled larger if the main jets are stepped down or can be wired down if they are too larger and providing too much fuel. Either way, the mix overall (mains + PVCRs) usually needs to remain about the same. Holleys, in my experience, are usually close at Wide Open Throttle. But need a lot of help in the low speeds, transitions and cruise. Which is where a street car spends most of it's time. There are many, many combinations in these circuits on any given size carb. Which is why all carb manufacturers make street and track versions of the same size carb. It is not just about mechanical or vacuum secondaries. Track oriented carbs like the DPs, are much richer in these areas than a street carb needs to be. For one thing, a track carb isn't too concerned about cruise. Do you have Emanuel's Holley book? You will need it. And if you are going to experiment with the IFRs, IABs, and PVCRs, you will need to get familiar with Pi x r2. That gives you the area of the holes you will be modifying. So you know how much bigger or smaller you have made the flow. This may be the longest post I have ever made. It had better help!
