^%$&* Stupid Brake shoe retainers #1515164
10/10/13 10:57 PM
10/10/13 10:57 PM
Hawaii
Dodgeballs Offline OP
Hawaii
How are you supposed to put these stupid things back on? The pin, 2 round pieces and spring thing. I somehow got one on. Can't get the other. Is there a special $800 tool? Did some engineer purposely design this to torture backyard mechanics for generations to come?
Re: ^%$&* Stupid Brake shoe retainers [Re: Dodgeballs] #1515165
10/10/13 11:04 PM
10/10/13 11:04 PM
St. John's Newfoundland
440newport Offline
440newport  Offline
They're easy with a retaining spring tool. Should be able to get one about anywhere for $10.
Re: ^%$&* Stupid Brake shoe retainers [Re: 440newport] #1515166
10/10/13 11:09 PM
10/10/13 11:09 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Ive always used a pair of pliers..
I am truckless..
Re: ^%$&* Stupid Brake shoe retainers [Re: 340SHORTY] #1515167
10/10/13 11:17 PM
10/10/13 11:17 PM
Hawaii
Hawaii
I finally got it on. I've always used needle nose pliers, but always have the hardest time. I'll check out that tool. But seriously, it could have been designed much better...
Re: ^%$&* Stupid Brake shoe retainers [Re: 340SHORTY] #1515168
10/10/13 11:23 PM
10/10/13 11:23 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Get the tool pictured above, and you'll be having fits of self flagellation about why you hadn't already gotten it long ago.
Same with this one too. Why fight when you can finesse?
Re: ^%$&* Stupid Brake shoe retainers [Re: kentj340] #1515169
10/10/13 11:27 PM
10/10/13 11:27 PM
Hawaii
Hawaii
dang it. I just realized that I have that brake multi-tool you have pictured. I never realized what the round thing on the end was. DOH!
Re: ^%$&* Stupid Brake shoe retainers [Re: Dodgeballs] #1515170
10/10/13 11:39 PM
10/10/13 11:39 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
"round thing on the end" is also for installing/removing the springs.
I just took apart a 39 Plymouth front brake assy. and they were using a very similar shoe retainer back then.
Re: ^%$&* Stupid Brake shoe retainers [Re: nomore65BelvJim] #1515171
10/11/13 12:01 AM
10/11/13 12:01 AM
Hawaii
Hawaii
I did use the tool to do springs. Didn't know it was also for the shoe retainers. At least I do now...
Re: ^%$&* Stupid Brake shoe retainers [Re: Dodgeballs] #1515172
10/11/13 12:26 AM
10/11/13 12:26 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
dont you hate it, when that happens?
Re: ^%$&* Stupid Brake shoe retainers [Re: Dodgeballs] #1515173
10/11/13 12:30 AM
10/11/13 12:30 AM
Me either . I've always use the seperate tool for the round retainers
Re: ^%$&* Stupid Brake shoe retainers [Re: RapidRobert] #1515174
10/11/13 02:18 AM
10/11/13 02:18 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I thought the round thingy was to unwrap the springs from the top post.
Re: ^%$&* Stupid Brake shoe retainers [Re: kentj340] #1515175
10/11/13 02:23 AM
10/11/13 02:23 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Yeah, I've always seen those giant multi-use plier looking things at different shops and hated even trying them. The little spring on and off tools(2 of them) get the job done almost always. Bought them 35 years ago at least.
Re: ^%$&* Stupid Brake shoe retainers [Re: kentj340] #1515176
10/11/13 02:31 AM
10/11/13 02:31 AM
Hawaii
Hawaii
Yeah - it didn't seem to work for the retainer. But I did use it for the springs.
Re: ^%$&* Stupid Brake shoe retainers [Re: buildanother] #1515177
10/11/13 03:32 AM
10/11/13 03:32 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Here's another use for them: restoring your wiper arms. Of course the real intended purpose is to handily stretch your brake springs. Works awesome.
I wonder if surgeons use these? Multi purpose.
Re: ^%$&* Stupid Brake shoe retainers [Re: kentj340] #1515178
10/11/13 04:53 AM
10/11/13 04:53 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
^^^^^^^^^ Slick.
I can't afford this. mark
Re: ^%$&* Stupid Brake shoe retainers [Re: kentj340] #1515179
10/11/13 02:22 PM
10/11/13 02:22 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
It is , it will not work on the hold down springs . Thats what the second tool is for
Re: ^%$&* Stupid Brake shoe retainers [Re: Dodgeballs] #1515180
10/11/13 05:59 PM
10/11/13 05:59 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I have found it easier to use a 1/4 or 9/32 nut driver. Grasp the rear side of the pin with needle nose pliers to hold it perpendicular to the rear plate. Push the retainer onto the pin with the nut driver aligning the slot to clear the end of the pin. Compress the spring completely and turn the pin with the pliers a quarter turn and you are done.
Craig
Re: ^%$&* Stupid Brake shoe retainers [Re: denfireguy] #1515181
10/11/13 07:24 PM
10/11/13 07:24 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
The first time you use the proper tool, you'll kick yourself for not buying one sooner. It literally takes less than two seconds with the tool.
Re: ^%$&* Stupid Brake shoe retainers [Re: burdar] #1515182
10/11/13 08:20 PM
10/11/13 08:20 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
True, get both tools shown and a set of shoes will take you less than 30 minutes.
Less than 20 after you've done a few, no drama.
Re: ^%$&* Stupid Brake shoe retainers [Re: burdar] #1515183
10/12/13 03:49 PM
10/12/13 03:49 PM
Hawaii
Hawaii
I've already kicked myself, my trash can, my dog...
