Dana 60 Chatter #1515001
10/10/13 03:17 PM
10/10/13 03:17 PM
Anonymous OP
Anonymous OP
Initially got a chattering from the rear when starting off making left turns. Now it happens when going straight. Not all the time; just sometimes. Any ideas? I've added the anti-slip additive a couple of times, but still happens. I don't believe the unit has ever been rebuilt. What is involved in a rebuild?
Re: Dana 60 Chatter [Re: ] #1515002
10/10/13 03:48 PM
10/10/13 03:48 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
Your best move at this time is to remove the rear cover and clean out the oil and any debris that you may find. As I remember the later Dana 60s use the TracLok (sp?) carrier (the weakest of the OEM models, single casting with big windows) and it has small parts that can break and become caught up in the ring & pinion. Open it up, clean & inspect with a fresh oil fill will cost less than $20.00 and at least you will know where you stand. Do it now!!
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Dana 60 Chatter [Re: ] #1515003
10/10/13 06:20 PM
10/10/13 06:20 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
yea maybe some condensation build up that will cause chatter.
make sure the vent is working!
I used to replace my own clutches borrowed and rear end spreader.
Re: Dana 60 Chatter [Re: Dodgem] #1515004
10/10/13 06:22 PM
10/10/13 06:22 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Make sure you use the right lube sure grips need the right lube plus additives.
Re: Dana 60 Chatter [Re: Dodgem] #1515005
10/11/13 11:38 AM
10/11/13 11:38 AM
Anonymous OP
Anonymous OP
Can replacement of the clutches be done with the rear in the car?
Re: Dana 60 Chatter [Re: ] #1515006
10/11/13 12:57 PM
10/11/13 12:57 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
yes, the clutches can be changed out in the car, not easy tho..
with the chatter on turns, it is most likely a wrong lube and or additive..
Must use the expensive additive, and premium lube...
Chatter going forward is not releated the clutches tho, like suggested, jack it up, pull the cover and inspect the gear teeth to see what is going on.
Re: Dana 60 Chatter [Re: sthemi] #1515007
10/11/13 09:59 PM
10/11/13 09:59 PM
Anonymous OP
Anonymous OP
Will do. Thanks.
